#1 |
Member#: 19470
SWIC
Vehicle:1981 Brat GL Blue |
As the next step in figuring out my mysterious throttle-position-related hesitation, I've decided to take a look at the throttle position sensor. Is the TPS the same for all GCs or is there one specific to the EJ20K?
#2 |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
my guess would be the same as a G
#3 |
Member#: 19470
SWIC
I imagine getting one for a G would be as hard as getting one for a K. What about USDM models?
#4 |
Member#: 21764
RMIC
Vehicle:Some GDM V8, JDM Flat 4 X2 |
hook up your volt meter to the TPS signal wire and move the throttle and look at the voltage. it should change the V reading you are seeing. it should change smoothly as your moving the TPS sensor. if you have an abnormal reading thrue the range you more then likely have a bad TPS sensor.
#5 |
Member#: 1185
Vehicle:I flap my gums and now I'm a specialist |
I think its 2-2.4V idle , 4-3-4.8 wot . I missed out but what is your hesitation problem ?
#6 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
well, they have told you how to test it...if that fails, post a pic of what she looks like...many parts were shared with the old EJ18's and the earlier wrx/sti motors...just how subaru does it
| Thread Tools | |
| Display Modes | |
| WTB: TPS / Throttle Positioning Sensor / TGV Sensor off of turbo car | Eyeflyistheeye | Private 'Wanted' Classifieds | 1 | 05-06-2010 08:54 AM |
| MAF/O2 Sensor/ Throttle Position Sensor?!? | tanner12 | Service & Maintenance | 8 | 01-18-2010 12:52 AM |
| wtb: Tumble Generator Valve (TGV) sensor / Throttle Position Sensor (TPS) Sensor | simprezl25 | Private 'Wanted' Classifieds | 0 | 01-10-2007 04:25 PM |
| Throttle position sensor and speed sensor pinout 04 WRX? | snowcrzy | Electrical & Lighting | 7 | 12-05-2006 04:51 PM |
| FS: 2.5L throttle body + throttle position sensor + air/idle speed controller. | SjYankee006 | Private 'For Sale' Classifieds | 3 | 02-15-2005 12:26 PM |
