Old 02-14-2006, 11:44 PM   #1
SubyDan05
Member#: 92860
02 wrx
yellow
Default fuel pressure regulator?
when do i need a fuel pressure regulator? i am planning on upgrading my injectors and fuel pump, and do i need the fuel pressure regulator? or can i upgrade the injectors and just get a fuel pressure regulator? i have a few mods and utec. please help me out. thanks
SubyDan05 is offline   Reply With Quote
Old 02-15-2006, 07:46 AM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The stock RRFPR is commonly used with upgraded pumps and new injectors to get higher fuel flow for turbos larger than stock.
For mildly aggressive tunes using a stock turbo, you still might find yourself running out of headroom in the stock fueling system. I'm running a stock TD04, and I'm seeing injector duty cycles over 90% from 5000RPM to redline. With an upgraded fuel pump (the 255lph high pressure pump) and an FPR at 10psi higher static pressure, I expect to get an additional 15% or so of headroom on my injectors.
Kha0S is offline   Reply With Quote
fuel pressure regulator with OBX high flow fuel rails question subypal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-09-2009 10:39 PM
FS: MA Perrin Fuel Rails & Aeromotive Fuel Pressure Regulator climberd Engine/Power/Exhaust 5 05-05-2009 12:07 AM
BDL fuel rails and fuel pressure regulator living4surf Engine/Power/Exhaust 2 09-29-2007 09:38 AM
Fuel Pressure Regulator and/or Fuel Rails? mav1c Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-19-2003 03:23 PM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
