Old 02-14-2006, 11:52 PM   #1
sidewayz
Member#: 5810
2001 S366 2.5RS
Default 2 questions about swap Gurus needed!!
This is all in a 01 RS with an '04 motor, harness and an '03 ECU
where the hell does this guy go its the yellow with blue stripe in the top of this pic.
accordingly to my diagrams, it goes to the main relay..
Im using an '04 harness which doesnt have the SMJ
Second. My fuel pump relay isnt on the passenger side of the car. I need to know where to hook up the black with yellow stripe from the FP controller.
She cranks and cranks But I get zero ignition.
Thanks in advance!!
sidewayz is offline   Reply With Quote
Old 02-14-2006, 11:58 PM   #2
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Yellow/blue goes to main relay power, the same ones for the ecu power. There should also be a green/red which is ignition power. Fuel pump relay is on the drivers side.
Ver.III is offline   Reply With Quote
Old 02-15-2006, 09:59 AM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
thanks for replying....but I think I already established what you said in my first post.
I need to know where most of you have that wire going. And with that green with red wire... that thing branches off like 5 other times..where do they go??
Old 02-15-2006, 05:08 PM   #4
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
I dont under stand what you are saying, In the picture you provided, that big gray plug is the smj. As for the yelow/blue wire you need to splice it in with another yellow/blue wire. there are a bunch of them under the dash, and they all tie together. The green and red wire I think is your ignition on for the ecu, you can weed wack out some of them if they arent going to anything. Fuel pump relay is located on the left of the car, but the wires run to the right of the car. There is a a connector down near the right foot well where you can tie in your FPC wires. It is tricky to explain with out seeing what you have done with the wiring because everyone does it a little different.
JeremyRS is offline   Reply With Quote
Old 02-16-2006, 07:42 PM   #5
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
newbie question here, but what exactly is the smj?
josh...just josh is offline   Reply With Quote
Old 02-16-2006, 11:25 PM   #6
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
Super Multiple Junction. It's basically a big funnelling connector built into some Subaru harnesses.
Last edited by UTCiv; 02-17-2006 at 10:44 AM. Reason: My Lack of Ability in the Field of Spelling
UTCiv is offline   Reply With Quote
Old 02-17-2006, 02:06 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Originally Posted by UTCiv
Super Multiple Junction. It's basically a big funnelling connector built into some Surbaru harnesses.
what he said but i like to refer to it as subaru's bass ackwards way of wiring a car. I will never understand why they don't seperate the body harness from the engine harness.
Speed Sensor Issue After Swap! Gurus needed snowcrzy Subaru Conversions 2 05-22-2008 12:39 PM
2.2L-2.5L na swap help needed ASAP!!!!!! impreza4show Subaru Conversions 14 08-20-2005 02:58 AM
question about swapping a 2.0 for a 2.0 BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-25-2005 02:39 AM
Questions about swapping in V4-V6 5mt's into V7. AZScoobie Transmission (AT/MT) & Driveline 4 12-29-2003 08:23 PM
Question about swapping in JDM EJ20 turbo engine and gasoline requirements edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2001 11:39 AM
