Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 02-15-2006, 10:37 AM   #1
-Kevlar-
Member#: 82378
Default Cobb AP issues....
ok just installed my AP on the car and put the base map as "stock mode". then i flashed a real time "stage 2 93" map to the car. i literally feel NO performance increase whatsoever. boost guage is reading between .1 and .11 . i know thats about 15 psi. did everything the instructions said. what could i have done wrong? all i ever heard was it was supposed to be this HUGE increase in power, and i got nothing (butt dyno).....
-Kevlar- is offline   Reply With Quote
Old 02-15-2006, 10:40 AM   #2
dmah
Member#: 77590
2004 wrx sedan
Cobb recommends putting the stage 2 93 base map as well as the realtime map. Some people say it takes a bit of time for the car to learn.... but I felt a difference right away going from stage 1 to stage 2.
Don
dmah is offline   Reply With Quote
Old 02-15-2006, 10:42 AM   #3
-Kevlar-
Member#: 82378
Don
so just change the base map to stage 2 93 and switch real time again or leave it?
Old 02-15-2006, 10:43 AM   #4
-Kevlar-
Member#: 82378
what boost is everyone else seeing? i think its supposed to be 16.5 give or take .5 right?
Old 02-15-2006, 10:47 AM   #5
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
Don
+1. Make stage 2 your base map. Dumb question, but you have at least a higher flow downpipe right? Cobb recommends TBE. For stock hardware you can only do stage 1.
PJC1909 is offline   Reply With Quote
Old 02-15-2006, 10:57 AM   #6
-Kevlar-
Member#: 82378
true true i have a DP and cat back. just changed the base map. heres a real dumb question. in the book to read live boost it says make sure key is in the on position but doesnt say anything about starting the car. this is ok right? i just dont want to muck anything up.
Old 02-15-2006, 11:01 AM   #7
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
HA HA, yes the car must be on to read live boost.
Do u have a boost gauge as well???
what map are u coming from??
u need to load base map Stage 2 93 & realtime map Stage 2 93 no matter what.
markuswelby is offline   Reply With Quote
Old 02-15-2006, 11:04 AM   #8
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
What I've done, since I'm a belt and suspenders kind of guy, is start the car, then plug into the OBD port then scroll through the menus to get live boost. Make sure you unplug the little Cobb connector thingy and the test connectors before you do that.
Good luck
Old 02-15-2006, 11:08 AM   #9
-Kevlar-
Member#: 82378
ok thanks...... yeah im coming from NO map (read <<<profile -.5 ) so target should be 15.8 +/- .5 ...... well i guess ill give her another go. do i need to re flash the stage 2 real time now that ive changed the base again?
Old 02-15-2006, 11:21 AM   #10
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
Yea, i believe target is right around there.
Coming from no map to stage 2, u will definitely feel a big difference.
Old 02-15-2006, 11:42 AM   #11
-Kevlar-
Member#: 82378
just took it for a test drive.....its a little better but not what i was expecting i cant believe i paid 600 bucks for it. if i knew i would have paid 300 tops. i read live boost and its hitting 16.3psi. but alas butt dyno says im an idiot for spending that much....
Old 02-15-2006, 11:44 AM   #12
Christian.
Member#: 87604
wrxblubayou,
Most of our map notes contains the following:
"Features such as defeated CELs and Closed Loop tables are not changed with Realtime. This is why we highly recommend you running the Stage Base Map that best matches your car's modification. Running the Stock Mode Base Map with a Stage Realtime map over it will get you some of the improvements but no where NEAR what you would get if you were to run the proper Stage Base map.
Revised Electronic Throttle Mapping. We did this to improve the throttle response. We changed the delays in how the throttle actually reacted to your right foot in an effort to reduce some of the "drive by wire" feel.
Again, you should have no reason why you will want to run the Stock Base map, unless of course you're the type that doesn't like extracting the full potential of your vehicle."
We highly recommend that you use the base map that best matches your vehicles hardware because too many improvements are made in the base map to not use it.
Take care,
Christian.
Christian. is offline   Reply With Quote
Old 02-15-2006, 11:46 AM   #13
-Kevlar-
Member#: 82378
Originally Posted by Christian.
wrxblubayou,
Take care,
Christian.
wow thanks.... thats exactly what i just did
base: stage 2 93
realtime: stage 2 93
what are you saying? dont do the realtime over the base????????????
Old 02-15-2006, 11:54 AM   #14
-Kevlar-
Member#: 82378
anything else i could try? missing anything?
Old 02-15-2006, 12:06 PM   #15
hondaeater69
Member#: 60324
base: stage 2 93
i wouldn't. . .i've seen some in the past have problems running the same RT over base. Only time you need to run a real time map is when it's DIFFERENT from your base.
Old 02-15-2006, 12:08 PM   #16
-Kevlar-
Member#: 82378
so i guess a reset will fix it then right?
Old 02-15-2006, 12:09 PM   #17
hondaeater69
Member#: 60324
16 is target for stage 2, i'm not sure what you are expecting
keep in mind these are very conservative base maps, in order to really get the power out of your map you'll need a custom tune.
Old 02-15-2006, 12:11 PM   #18
hondaeater69
Member#: 60324
yes..
Old 02-15-2006, 12:13 PM   #19
-Kevlar-
Member#: 82378
well it just doesnt feel like it pulls any harder. 1-5 feel a LITTLE better but thats it. i guess i just expected too much maybe? from hearing everyone else "stg 2 iz da bomb fast3r"....... i will say its a lot smoother.
Old 02-15-2006, 12:18 PM   #20
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
I think that my car with Stage 2 dyno's at roughly 210ish whp, but the boost comes on earlier, like u said smoother.
With a Pro Tune i went to 235ish..
to maximize ur car a Pro Tune is the way to go, just do all ur mods before because those tuners are expensive!!!!
Old 02-15-2006, 12:21 PM   #21
-Kevlar-
Member#: 82378
nothing else is needed for a pro tune? just AP and a tuner that does em? (TopSpeed)
Old 02-15-2006, 12:24 PM   #22
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Yup. And the parts that you want tuned for .
mcowger is offline   Reply With Quote
Old 02-15-2006, 01:18 PM   #23
Christian.
Member#: 87604
I was not being a smart ass. I just wanted to make sure you were aware of the recommendations we publish. Some people do not read any of the instructions and are not familiar with the AccessPORT and its purpose. I was doing what I could to assist, educate, and make you aware of something that you might have not known about. You always have the option of unmarrying the AccessPORT and return it if you are not satisfied. I believe we limit that to a 30-day trial. I will double check.
Take care,
Christian.
Old 02-15-2006, 01:55 PM   #24
-Kevlar-
Member#: 82378
Take care,
Christian.
no problem but i stated that's what i did in the previous post and i was really pissed at the time. thanks for helping. AND now that ive drove around a bit it feels a lot better. seems the biggest gain is at 50 or 60% throttle though. at that throttle position im running almost stock boost (~11psi). any ideas why? normal? and i also notice that if im cruising in fourth or fifth at 2500 rpm or so and go WOT the boost doesnt shoot up like normal. good i guess since before the AP that was causing a boost spike up to .12 or so. all in all i guess a couple more days and ill be happy with it. just for broke ****s like me 600 is a lot to pay for something and like i said i guess i was expecting 800 hp.
Old 02-15-2006, 02:01 PM   #25
Christian.
Member#: 87604
Normal, you are not at full TPS so the ECU is not going to target maximum boost.
Good luck with that on an a close-to-stock vehicle
Take care,
Christian.
Cobb AP v1 issues (wrong ecu message) Grammar Police AccessPort 3 01-23-2009 03:57 PM
cobb ap v2 issue mxpunk409 Newbies & FAQs 1 09-25-2008 10:28 PM
cobb AP stage 2, DP to stock back issue! tk686 Newbies & FAQs 16 09-14-2005 10:58 AM
04 STi Cobb AP Initialization issues SubaruBen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-10-2004 05:10 PM
04 STi Cobb AP Initialization issues SubaruBen Engine Management & Tuning 2 12-10-2004 01:43 PM
