Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 02-15-2006, 11:03 AM   #1
greysave
Member#: 62395
2005 STI
Default Nitrous on STI
Is anyone sparying on there STI? I have an sr55 and am going to a axis stage 3 block. I want to know the difference in power and 1/4 mile times if possible. With the sr55 I was able to squeeze out low 12's but I was expecting more. It seems like there are alot of disappointing times with the STI and was wondering if anyone solved the problem with nitrous.
greysave is offline   Reply With Quote
Old 02-16-2006, 12:14 PM   #2
greysave
Member#: 62395
2005 STI
I guess people don't do nitrous on subarus?
Old 02-16-2006, 12:24 PM   #3
-Kevlar-
Member#: 82378
not to often.
-Kevlar- is offline   Reply With Quote
Old 02-16-2006, 01:33 PM   #4
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
post in 2.5L forum for more results. What does this have to do with EM?
rjrutzky is offline   Reply With Quote
Old 02-16-2006, 02:04 PM   #5
shemoves
Member#: 80663
2005 STi
Why would you NO2 an AWD car If you wanted good quarter mile times, you should've bought a V8. I can understand wanting to make something fast...but its almost an oxymoron to NO2 an STi unless it is for some specific, model-restrictive competition (like evo vs. sti), but even then, it still seems like a waste of money.
shemoves is offline   Reply With Quote
Old 02-16-2006, 02:07 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
There is a guy on iwsti.com who has been playing with nitrous on a stock turbo STI. I don't think it blew up yet.
You should be able to go faster than low 12's with an SR55, provided you practice a lot. It took me 80+ quarter mile passes before I ran my 12.4 on the stock VF39.
jays05 is offline   Reply With Quote
Old 02-16-2006, 02:46 PM   #7
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
i do not support Nitrous on the evo or sti either... im just more like ...how to say...you wanna be fast...build the engine up and tune... nitrous just seems like a quick way out and sometimes unsafe.. i know one guy whos used it for his wrx and possibly his evo afterwards(but he stopped using it at all)..but hes pushing over 400+hp and running low 12's(without it) ..just personaly preference i suppose..
EvolvedAK is offline   Reply With Quote
Old 02-16-2006, 05:50 PM   #8
BLK REX
Member#: 102673
2000 Legacy GT LTD
Well, if you had a big turbo and were planning on Drag Racing (Umm....FYI People DO Drag Race AWD cars), you could use the N2O to spool the turbo.
Or if youre highway racing and the bottle just happend to be open and youre losing, you could arn the system for the extra advantage..
You guys are ignorant if you think people ONLY AutoX, RallyX, Raly, etc etc, where N2O is not used.
BLK REX is offline   Reply With Quote
Old 02-16-2006, 06:27 PM   #9
-Kevlar-
Member#: 82378
do you use it? whats your experience?
Old 02-16-2006, 06:28 PM   #10
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
This section is Engine Management & Tuning, so I can see why it belongs.
N2O is a cheap reliable power adder if used correctly. Proper timing controls, AFR, and a good set of spark plugs will work. I think you could use the Hydra Engine Management to set it so the Nitrous activates under a certain amount of boost and rpms. Zex has their own spark plug line they recommend for use with Nitrous and Forced Induction.
If you are seriously concidering Nitrous, I would check out all the Nitrous kit Manufacturers. Read their FAQs and check out their kits. Also check out the forums for several different EM manufacturer's, see how they recommend using nitrous with their systems and ask some questions there.
If you educate yourself and do it right the first time, then you won't have any problems using it.
Old 02-16-2006, 06:39 PM   #11
ryanpietro
Member#: 101803
2005 gt35r sti
blue
im going to run a 75wet shot of nitrous express. im using hydra and a gt65 turbo kit. phil said its ok for me to spray on c16 with no problems, but im trying to let me spray with just alcohol injection. i dont know if hell do it for me yet, but i know its safe on c16.
ryanpietro is offline   Reply With Quote
Old 02-17-2006, 09:04 PM   #12
greysave
Member#: 62395
2005 STI
The latter was exactly what I was thinking of doing? I was also considering a 75 wet shot which was recommended to me by doug at top speed.
Old 02-17-2006, 09:15 PM   #13
greysave
Member#: 62395
2005 STI
With a 75 shot doug said I should see a very nice hp number combined with the 55lb turbo. I was at first considering doing a larger turbo like a gt35 but am shying away from it for 2 reasons. One for daily driveability purposes I don't want to be at 600 hp all of the time. Second I still would like to use my car for autox occasionally and the gt35 is enough said. With a stage 3 block and a I should be well over 550 whp which is where I want to be.
Nitrous on my '06 STI 06mattsti Water/Methanol Injection, Nitrous & Intercooler Cooling 26 06-11-2008 10:45 AM
Who uses Nitrous on their sti? All4bSpinnin Water/Methanol Injection, Nitrous & Intercooler Cooling 26 02-12-2007 10:54 AM
Nitrous on STI? Once more... Inprogress Water/Methanol Injection, Nitrous & Intercooler Cooling 28 02-28-2005 04:17 AM
Has anyone run Nitrous on the STi yet? silverscooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-27-2003 12:08 AM
Nitrous on a 2004 STI TonySTI STi Forum Archive 22 08-11-2003 07:38 PM
