Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-15-2006, 08:49 PM   #1
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
Default Any power limitations with utec??
In the market for a new EM...i see people making big power with Hydra(is this sti only)out of my price range anyway
i have a wrx
I see some good numbers with AEM, but not usualy every day driven cars..
what about UTEC..can it be tuned and power worthy with big turbos..like gt35r, 40r, with worked blocks??
BuggeyEYED is offline   Reply With Quote
Old 02-15-2006, 09:00 PM   #2
Colin84
Member#: 57113
2009 Dodge Ram
Consider this- BV's 9.67 STi is using a UTEC.
I think it will be plenty for whatever you're going to be doing.
Colin84 is offline   Reply With Quote
Old 02-15-2006, 09:24 PM   #3
Physics Junkie
Member#: 65609
I'm pretty sure they switched to the Hydra...
Physics Junkie is offline   Reply With Quote
Old 02-15-2006, 09:33 PM   #4
S L O W W R X
Member#: 95109
I drive my AEM every day, My personal opinion is that it is by far the most tuneable standalone available for the wrx. I have seen a hydra being tuned, I didnt get to play with it myself. However I didnt care for the interface.
Matt
S L O W W R X is offline   Reply With Quote
Old 02-15-2006, 09:41 PM   #5
rotanner
Member#: 88781
Matt
They did, but they were doing 10 second passes with the UTEC before switching.
rotanner is offline   Reply With Quote
Old 02-16-2006, 07:39 AM   #6
alcrudojr #00
Member#: 20652
06 WRX STI
493whp @ 93oct fuel
If I remember correct they did 720whp with the UTEC, Gadiel once told me that were there might be a diference is at 30+psi with a GT35 or bigger turbo. So unless you are going to run in does parameters every day or every weekend I'll use the UTEC. Much more friendly!
alcrudojr #00 is offline   Reply With Quote
Old 02-16-2006, 08:02 AM   #7
moorebl
Member#: 59238
i think utec is garbage. it has no way of learning outside temps and different weather. . blinking light everyday. i use my utec on my sti simply for a race map and then use the trouble free ecutek with a turboxs knocklite. cant go wront there. just make sure whom ever does the tunning is pretty good at it.
moorebl is offline   Reply With Quote
Old 02-16-2006, 08:20 AM   #8
alcrudojr #00
Member#: 20652
06 WRX STI
493whp @ 93oct fuel
Remember that the UTEC its only as good as the tuner who set it up and obviosly UTEC its not the only ECU that is on the market. Depending on your need is it's the computer your going to use. I just think UTEC cover more needs than others.
Old 02-16-2006, 08:23 AM   #9
fastcarman
Member#: 107623
2005 impreza sti
black
are yo ulooking for a utec ? I have one i took off my 2002 wrx before i traded it for my 05 sti. I'll sell it cheap. I only used it for a month . still set up pre programmed from turbo xs
fastcarman is offline   Reply With Quote
Old 02-16-2006, 04:45 PM   #10
lilsix
Member#: 67185
2007 Audi S4
4.2l V8
Are you talking about the knock light??? If so, and If you see it everyday, I think your tune is garbage not the utec.
lilsix is offline   Reply With Quote
Old 02-16-2006, 05:11 PM   #11
sprx19
Member#: 51091
2006 Evo
The UTEC is *not* an ECU.
sprx19 is offline   Reply With Quote
Old 02-16-2006, 05:19 PM   #12
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
If your utec knocks everyday, get a new tuner, not a new em.
Javier is offline   Reply With Quote
Old 02-16-2006, 05:20 PM   #13
proflexsti
Member#: 88866
Big v made that 720whp on utec and made almost the same on the hydra. Many guys do not have good tuners and do not get the results that they are looking for.
proflexsti is offline   Reply With Quote
Old 02-17-2006, 01:20 PM   #14
keaniegenie
Member#: 94494
2005 Element 92x
i have a wrx
It is with a Wideband 02 sensor. The UTEC is capable of doing anything with this add on.
However, the cost of a wideband 02 sensor and UTEC alone cost the same as a Hydra. If your power goals are that high and you don't have a EM yet, go Hydra. I don't know much about the AEM unit.
keaniegenie is offline   Reply With Quote
Old 02-17-2006, 11:04 PM   #15
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
Well I have tuned Utec , Hydra, AEM , Cobb Accesports, Motec and others
I have to say that Utec is a good product but at this moment I like more others products.
If you want high horspower use a AEM or a Hydra.
The first thing that you want on a good ECU specially on a high horspower aplication is a reliable knock control.
Other thing are a good speed procesor, good resolution, and good dataloging.
If you use a good tuner is possible to reach good number with the UTEC but I think that you reach the same numbers and more safe with other ECU like Hydra and AEM.
I know that every body wants to know the diference between Hydra and Utec.
With both computer I reach similar horspower up to 700whp. I test both comp. at the dragstrip on a back to back pass on the Big Valley car and always the car run between .3 to .4 faster on the 1/4mile with the Hydra.
Why this happen? the answer is better resolution. With better resolution you refine more the power over the whole rpm range.
If you see my car I run 10.7@129mph with my STI . I run my car on boost only. I dont think that I could reach thats numbers with the Utec on my car. Thats the reason I switch to Hydra on my car.
If you are going to install a Gt35 or Gt40 and build block on a Subaru use Hydra or AEM and dont look back.
If you have more question send me a PM.
Gadiel
Gadiel is offline   Reply With Quote
Old 02-17-2006, 11:42 PM   #16
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
..yeah.......really.....bad juju if it blinks all the time....sniff----poor motor dying a blink at a time.....sniff
Old 02-18-2006, 12:46 AM   #17
Gethin
Member#: 2998
Also v5 of the firmware has temp compensation for timing and fuel...blinking CEL = knock.
Gethin is offline   Reply With Quote
Old 02-18-2006, 10:35 PM   #18
kay95
Member#: 45494
95 impreza L awd
green
utec=maf
stand-alone=map
kay95 is offline   Reply With Quote
Old 02-19-2006, 11:20 AM   #19
BuggeyEYED
Member#: 101691
97 Supra TT
which equals more money and having to convert it over to map...right??
now im considering a hydra but i also need a map sensor and a wideband(whichever route i go)
Old 02-19-2006, 01:12 PM   #20
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
The hydra include the Map sensor. And the wide band you can ask the tune or the dyno to bring the wide band for the tunning session.
By the way the Utec use the MAF but also use the stock Map sensor.
Gadiel
Old 02-19-2006, 01:25 PM   #21
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
Or just put your utec over an Ecutek tune.....tis fun!!!
gcm05 is offline   Reply With Quote
Old 02-21-2006, 08:42 AM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
this is very powerful.
Old 02-21-2006, 12:46 PM   #23
gcm05
Member#: 105948
yeah...i love it.
safety and ecu learning with some more crazy map tuning on top of it!!!
Old 02-24-2006, 12:34 PM   #24
gaby
Member#: 94097
2004 WRX Hybrid GT35
11.2@130.7
Can you tunne the utec to eliminate the oem maf.
gaby is offline   Reply With Quote
Old 02-24-2006, 12:59 PM   #25
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Or put it on top of a free ECU reflash using the tools out there. Just as powerful.
cdvma is offline   Reply With Quote
Power limitation with Utec?? BuggeyEYED UTEC 1 02-15-2006 11:50 PM
any power gains with a turbo inlet hose? WrexFactor36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-06-2004 07:55 PM
UTEC capacities or power limits... jared nelson Engine Management & Tuning 14 10-27-2004 01:00 AM
Rev limiter adjustment with Utec annointed Engine Management & Tuning 8 08-31-2003 01:33 AM
any power gains with stock intake and a k&n filter SnowSubaru15 Normally Aspirated Powertrain 13 07-09-2002 08:43 PM
