Old 02-16-2006, 12:11 PM   #1
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Default What the hell do I have here?
Just received a used engine here at work. Supposedly it is a 98 EJ25. The intake manifold, a.c compressor and exhaust header are rather different.
The compressor is smaller, intake manifold looks more like a 96ish Outback and the header looks a lot like the header on the new 06 Impreza 2.5, or perhaps a turbo, but it is equal length. I'll take pics later, I am pretty sure it is not a U.S spec engine. Any thoughts?
Ben.
Old 02-16-2006, 12:19 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've seen a few of those. They are JDM Forester engines. They are generally the HLA heads like the '96-97 DOHC Ej25's we got here, and phase I...
Old 02-16-2006, 01:20 PM   #3
Hondaslayer
Member#: 4562
1995 Legacy LSi
Thanks Matt,
The long block is going into a 98 Impreza RS, I am pretty sure it will work (after we swap intake & exhaust manifolds,water pump etc...)
Weird thing is it came out of Virginia!
Old 02-16-2006, 05:37 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
is it the 2.5 na w/ avcs?
Old 02-16-2006, 07:55 PM   #5
snowjob
Member#: 59357
2009 Forester XT
pics please
snowjob is offline   Reply With Quote
Old 02-18-2006, 09:24 PM   #6
Hondaslayer
Member#: 4562
1995 Legacy LSi
Not a 2.5 with AVCS, it is supposedly out of a 98 Impreza.
Old 02-19-2006, 03:03 AM   #7
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Any intact VINs?
US2JDM is offline   Reply With Quote
Old 02-19-2006, 04:20 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sure looks like that manifold has an upward slope to it, maybe they just use the DOHC turbo cross member in Japan and route the exhaust over the cross member instead of under
Old 02-19-2006, 06:34 AM   #9
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
That's what I was thinking.
Wayne_Coots is offline   Reply With Quote
Old 02-19-2006, 10:15 AM   #10
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
thats a crazy ass lookin manifold.. Pretty neat
subbyspeed is offline   Reply With Quote
Old 02-19-2006, 10:56 AM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its gotta be a turbo headder it looks to bolt up to a standard up pipe
vs.
the flange is in the correct place
have you done a compression check?
Old 02-19-2006, 11:44 AM   #12
Hondaslayer
Member#: 4562
1995 Legacy LSi
vs.
Compression is good.
The engine is definately not from a turbo car, there is no oil feed or return ports for it.
The water pump is a turbo style but the secondary coolant feed port is not drilled out.
Also it is standard piping underneath the heatshields, it is not a cast item.
Old 02-19-2006, 11:45 AM   #13
Hondaslayer
Member#: 4562
1995 Legacy LSi
Thats what I was thinking,
or perhaps it is from a Aussie spec fozzy and they route it up and over to increase ground clearance.
Old 02-19-2006, 01:46 PM   #14
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
those motors hang out all the time in usa JDM engine depot warehouses. supprised noone here has played with one.
wonder what it takes to run that funny mani. someone should..
swapstar is offline   Reply With Quote
Old 02-19-2006, 02:01 PM   #15
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
This is an NA manifold. I don't know for sure exactly which engines this came on but the EJ20D was one of them. They had to use a water pump that fed from the front instead of the bottom because of the exhaust. All the exhaust that come around the front use the front fed water pump. I was under the impression that the exhaust went under the crossmember, but after HndaTch627's post I'm not so sure.
THAWA is offline   Reply With Quote
Old 02-20-2006, 02:50 PM   #16
Wayne_Coots
Member#: 70481
95 Impreza
Semi-Flat Black
How much do you want for it? I was looking at doing somthing similar so I can go ahead with my cross member swap.
Clutchpacks Shot -- What the Hell Do I Do Now?! JohnnyWas Transmission (AT/MT) & Driveline 11 02-10-2007 02:30 PM
What the hell do they tell the SRT-4 owners at the dealership? :confused: MidnightSti05 Off-Topic 69 06-01-2005 10:19 PM
Can someone please tell me what the hell is going on here!? CrazyMike13 Off-Topic 8 04-14-2005 02:40 AM
Finally got a website...now what the hell do I do?! STR8OUT Off-Topic 45 10-14-2004 01:07 PM
