Old 02-16-2006, 04:00 PM   #1
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Default Where did my fuel go?
I've been running on a pretty steady tune that's been keeping my AFRs in the neighborhood of 11.2-11.5:1. I arrived at that tune incrementally over the last six weeks or so.
Today, it's been about 20-30 degrees warmer than usual, and suddenly, I'm running about 0.7 AFR points leaner than normal. My short term fuel trims are at zero when wide open, and the long term trims are around -2.34% (where they've been pretty consistently).
What gives? The tune seems to be running leaner and leaner by the minute... it was running at virtually normal AFRs this morning, and has lost more than half a point of fuel in 20 miles of driving.
Any ideas?
/Andrew
Kha0S is offline   Reply With Quote
Old 02-16-2006, 04:03 PM   #2
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Note, idle and cruise are both centered happily around stoich, idle shows -3.13% LT trim, and cruise shows -0.78% LT trim.
Old 02-16-2006, 04:51 PM   #3
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
... update... this might all be moot. I'm getting a new sensor for my wideband... it might have finally crapped out.
I made a plot of MAF g / injector duty %, and plotted it against RPM, with data from a few days ago versus now... the curves match. That makes me pretty sure that the same amount of fuel is going into the cylinders... it's not guaranteed, but I'll just go easy on the throttle tonight until I can get a new sensor in and check my AFRs in the morning.
/Andrew
Old 02-16-2006, 05:08 PM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
If the temp changed 30 degrees, it could be your coolant enrichments
mrbell is offline   Reply With Quote
Old 02-16-2006, 05:18 PM   #5
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Coolant temps have been virtually identical (180-190F). Good idea, though.
I found a local VW parts dealer that has the 7057 sensor for my wideband controller... I'm picking it up and putting it in tonight. Hopefully that'll assuage my fears.
Old 02-16-2006, 05:38 PM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
Tuned with...? Looks like AccessPort?
Did you happen to fill up with gas that has more ethanol content than you're used to?
x99percent is offline   Reply With Quote
Old 02-16-2006, 05:53 PM   #7
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Tuned with OpenECU tools. I ran one tankful of a different brand of gas last week and found that I was getting some incipient knock (due to the variances between regional additives for winterization). I'm back onto the same fuel that I have been using for the previously and the timing is back to full advance.
The gas uses MTBE, but I've been tuning against the same blend for a while now.
/Andrew
Where, oh where, did my lowbeams go? rjp Electrical & Lighting 7 09-17-2005 02:22 AM
Oh where oh where did my oil go? Rubasu Normally Aspirated Powertrain 15 04-25-2002 07:23 PM
Street racing, where did my thread go? Subie Gal General Community 0 11-03-2001 10:01 AM
Where did my thread go? pleiades South East Region Forum 3 09-17-2001 03:29 PM
('93-'01) Where did my post go??? KoKo Impreza Forum 2 05-29-2001 08:08 AM
Message Board Statistics All times are GMT -4. The time now is 06:06 AM.
