Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 02-16-2006, 06:56 PM   #1
killthelights145
Member#: 88071
1985 Defender 90
Default 04 sti lag with utec
Im running stage 2 with a fmic and im getting a ton of lag....Im boosting at like 4,000 ..anyone out there have a map for the stage 2 with a fmic????? please
also when i look at the map in the edit map stage it says. "stage 2 map. 16 psi" which is the same as the stage 1 map. should it not be differnt?
killthelights145 is offline   Reply With Quote
Old 02-16-2006, 09:11 PM   #2
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
dude, I could do a session or two with you to do the tuning if you want
firstly, IMHO the timing in the UTEC ST2 map sucks worse than a stock ECU
secondly, you need to redo all your boost values to make everything work well
3rd - we could play with your timing to get you spooling a little quicker, do you have at least an EGT gauge? It would be even better if you had a WB because chances are with the cold to hot streaks we've had lately your A/F's are all over the place.
Oh and if I remember correctly the stage 2 16psi map is a stage 1 with 2 degrees more timing advance across the board.
Justin
crystalhelix is offline   Reply With Quote
Old 02-16-2006, 10:36 PM   #3
killthelights145
Member#: 88071
1985 Defender 90
you got a pm
Old 02-16-2006, 11:00 PM   #4
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
you got a pm
Udo2
12345
anti-lag with UTEC?? kalescustom UTEC 0 06-25-2009 12:26 PM
04+ STi Turbo XS UTEC with Map switch Turbo XS Turboback mattyb123 Engine/Power/Exhaust 4 08-11-2006 02:33 AM
FS: Slightly used 04+ STI/05LGT/OBXT UTEC $800 OBO my05legacy Private 'For Sale' Classifieds 4 03-08-2006 09:21 PM
04 sti ap vs utec comparison...unfair for sure chrisfranklin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 08-29-2004 02:37 AM
04 ECU problems with UTEC Brewmaster Engine Management & Tuning 79 01-21-2004 08:42 AM
