Old 02-16-2006, 08:55 PM   #1
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
Default Accessport/Boost help!
Alright i know this problem has been talked over plenty of times, but i cant seem to fix it! I recently bought a cobb accessport for my 04 wrx, which also has a cat-back exhaust and a BOV. I put the base map & real time map as the stage1/91. When i put it on live boost read, the highest i ever get is 9.8 psi!! I see everyone posting their stock wrx's reaching 13-14 psi and mine is no where close! I have done the Ecu reset, but with no effect, i also looked for boost leaks but there are none that i can see, does anyone know what to do? (Wrx Stock boost is 13-14psi right?) thanks!
-Andrew
redrex04 is offline   Reply With Quote
Old 02-16-2006, 09:01 PM   #2
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
what gear are in? you may need the HWG map
Quack is offline   Reply With Quote
Old 02-17-2006, 08:42 AM   #3
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
I have tried it in 1st, 2nd, & 3rd gear, its the same in all three..., ill try that tho, but does anyone know the exact stock boost for wrx's?
Old 02-17-2006, 08:45 AM   #4
-Kevlar-
Member#: 82378
around 13.5 and dont reflash realtime over base if its the same map i was told (Cobb AP issues thread) that it can cause problems.....
-Kevlar- is offline   Reply With Quote
Old 02-17-2006, 11:32 AM   #5
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Maybe the boost leak is your BOV... Try running it with the stock one.
STirocket is offline   Reply With Quote
Old 02-17-2006, 11:35 AM   #6
dvang
Member#: 84188
05 legacy
caravan full of kids now
also max boost should be read in 4th gear. did you used to have a boost controller of any sort MB or EBC
dvang is offline   Reply With Quote
Old 02-17-2006, 11:36 AM   #7
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
get a mechanical boost gauge and see what happens with that
anthonyrb98 is offline   Reply With Quote
Old 02-17-2006, 12:36 PM   #8
kenzo415
Member#: 106346
2003 WRX Stage 2
Don't have a BOV unless you have it properly tuned or have a turbo swap.
kenzo415 is offline   Reply With Quote
Old 02-17-2006, 12:40 PM   #9
supermarkus
Member#: 6971
2008 WRX STi
SSM
I would definitely swap the stock BOV back on and check the BOV gasket for leaks.
supermarkus is offline   Reply With Quote
Old 02-18-2006, 06:39 AM   #10
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
Default hwg
Hey is the HWG maps safe? if not why?
thanks
jeremey
wrxtuner13 is offline   Reply With Quote
Old 02-18-2006, 08:19 AM   #11
-Kevlar-
Member#: 82378
not sure why but they just say "use at your own risk".
Old 02-18-2006, 01:42 PM   #12
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
I did have a mbc and then switched to an ebc, but they are both removed now because i decided to be nice to my car . I have tried to switch bov's but that doesnt help at all. if i shouldnt have the base & real maps the same but i want to be stage 1\91, how should i set it up, thanks!
Old 02-18-2006, 02:15 PM   #13
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
do you have the pill?
try the stock map to make sure you its not the map you are using
scoobdude is offline   Reply With Quote
Old 02-18-2006, 03:22 PM   #14
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
sounds like you are missing the restrictor pill in the 1 st little vacume hose off the turbo. Check if it's there, squeez it in the midle and you should feel it there.
wrxdrvr is offline   Reply With Quote
Old 02-18-2006, 05:38 PM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
Would have been helpful if you listed aftermarket boost control as one of your mods in the first place. Post 14 is probably dead on. This is a classic mistake new owners make, I hope you kept your original hoses.
Old 02-20-2006, 02:49 AM   #16
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
i do not have aftermarket boost control, i DID months ago but took it off., I have tried everything, but nothins worked, im lost.
Old 02-20-2006, 03:40 AM   #17
supermarkus
Member#: 6971
2008 WRX STi
SSM
By "everything" do you mean you followed the advice in post 14?
2006 WRX AccessPort boost question??? Bala AccessPort 9 05-12-2006 12:54 PM
Accessport boost reading, accurate? 18.9psi eviltwin AccessPort 3 05-08-2006 12:42 AM
Accessport Boost Controller Question HD-sw20 Engine Management & Tuning 4 09-21-2005 09:20 PM
Accessport boost psi reading high?? ASpec818 Engine Management & Tuning 1 07-31-2004 05:56 AM
STi Stage 2 AccessPort boost creep comments... dsmperformance Engine Management & Tuning 3 06-10-2004 09:10 PM
