Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 02-17-2006, 01:19 PM   #1
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Default pushing the envelope
rescaled the MAP reference to 0-22psi
dropped 1* in 100 col, 0.8 in 90, 0.6 in 80, 0.4 in 70, 0.2 in 60
dialled up the MBC two turns
2nd gear pull
40* f ambient
15 lines/sec
ic sprayer on, 60% methanol
NO open loop fueling on utec
same old mods
Code:
 1760  -2.0 2.4  69  10    00  14.8  +23.7   10.2 ECU.   -6.8 1.0    2.2  14.78
 1831  -1.0 2.4  94  10    00  14.5  +25.3    7.8 ECU.   -6.9 WGS.   2.2  14.49
 1833  -1.0 2.4  94  10    00  14.5  +25.7   12.2 ECU.   -6.9 WGS.   2.3  14.49
 1795  -0.2 2.4 100  10    00  14.3  +25.5   15.5 ECU.   -6.9 WGS.   2.3  14.33
 1905  +0.6 2.5 100  10    00  14.2  +27.4   12.4 ECU.   -7.0 WGS.   2.3  14.15
 1895  +0.6 2.5 100  10    00  14.1  +27.6   12.4 ECU.   -6.9 WGS.   2.3  14.05
 1922  +1.0 2.5 100  10    00  14.0  +27.6   12.0 ECU.   -7.0 WGS.   2.3  13.95
 2002  +1.2 2.5 100  10    00  13.9  +29.4   12.6 ECU.   -5.8 WGS.   2.3  13.92
 1991  +1.2 2.5 100  10    00  13.9  +30.6   12.6 ECU.   -7.0 WGS.   2.4  13.92
 2035  +1.2 2.5 100  10    00  14.0  +30.2   12.5 ECU.   -6.7 WGS.   2.4  14.00
 2042  +1.5 2.6 100  10    00  14.0  +31.5   13.4 ECU.   -7.0 WGS.   2.3  14.00
 2082  +1.5 2.6 100  10    00  14.2  +31.2   13.2 ECU.   -6.7 WGS.   2.4  14.15
 2097  +1.7 2.6 100  10    00  14.3  +31.1   13.2 ECU.   -6.5 WGS.   2.4  14.25
 2091  +1.7 2.6 100  10    00  14.4  +30.9   13.5 ECU.   -6.5 WGS.   2.4  14.37
 2161  +1.9 2.6 100  10    00  14.4  +31.5   15.2 ECU.   -6.2 WGS.   2.4  14.37
 2161  +1.9 2.6 100  10    00  14.4  +30.7   14.2 ECU.   -6.1 WGS.   2.4  14.42
 2214  +2.1 2.6 100  10    00  14.4  +31.0   15.0 ECU.   -5.8 WGS.   2.5  14.42
 2252  +2.1 2.6 100  10    00  14.4  +30.7   13.9 ECU.   -5.8 WGS.   2.6  14.42
 2255  +2.3 2.6 100  10    00  14.4  +30.8   14.2 ECU.   -5.6 WGS.   2.6  14.37
 2321  +2.5 2.7 100  10    00  14.2  +29.8   16.9 ECU.   -4.8 WGS.   2.6  14.22
 2292  +2.5 2.7 100  10    00  14.1  +29.8   15.6 ECU.   -4.6 WGS.   2.6  14.11
 2337  +2.5 2.7 100  10    00  14.1  +29.2   17.1 ECU.   -4.6 WGS.   2.6  14.11
 2420  +2.7 2.7 100  10    00  14.0  +27.7   18.6 ECU.   -4.3 WGS.   2.6  13.97
 2460  +2.9 2.7 100  10    00  13.8  +26.8   18.3 ECU.   -3.5 WGS.   2.7  13.81
 2452  +2.9 2.7 100  10    00  13.6  +24.3   19.9 ECU.   -3.8 WGS.   2.7  13.62
 2482  +3.1 2.7 100  10    00  13.5  +24.0   19.9 ECU.   -3.2 WGS.   2.7  13.47
 2540  +3.1 2.7 100  10    00  13.3  +23.2   20.3 ECU.   -3.0 WGS.   2.8  13.31
 2552  +3.1 2.9 100  10    00  13.2  +22.5   20.5 ECU.   -3.0 WGS.   2.7  13.17
 2540  +3.1 2.9 100  10    00  12.9  +22.5   22.1 ECU.   -3.1 WGS.   2.7  12.86
 2587  +3.3 2.8 100  10    00  12.9  +21.4   21.9 ECU.   -3.4 WGS.   2.7  12.86
 2645  +3.3 2.8 100  10    00  12.7  +23.2   22.0 ECU.   -3.6 WGS.   2.8  12.74
 2668  +3.7 3.0 100  10    00  12.7  +22.8   22.8 ECU.   -3.8 WGS.   2.9  12.68
 2679  +3.7 3.0 100  10    00  12.6  +22.7   22.5 ECU.   -3.8 WGS.   2.8  12.61
 2730  +3.9 3.0 100  10    00  12.6  +22.4   23.0 ECU.   -4.2 WGS.   2.9  12.61
 2780  +3.9 3.0 100  10    00  12.6  +22.4   23.2 ECU.   -4.2 WGS.   2.8  12.59
 2801  +4.3 3.1 100  10    00  12.6  +20.6   23.1 ECU.   -4.2 WGS.   2.9  12.61
 2808  +4.3 3.1 100  10    00  12.6  +20.4   25.4 ECU.   -4.2 WGS.   2.9  12.64
 2834  +4.3 3.1 100  10    00  12.6  +20.2   26.7 ECU.   -4.3 WGS.   3.0  12.64
 2896  +4.7 3.0 100  10    00  12.7  +19.6   27.4 ECU.   -4.3 WGS.   3.0  12.68
 2926  +4.7 3.0 100  10    00  12.7  +18.8   27.7 ECU.   -4.3 WGS.   3.1  12.68
 2936  +5.1 3.2 100  10    00  12.7  +18.5   28.3 ECU.   -4.4 WGS.   3.0  12.74
 2994  +5.1 3.2 100  10    00  12.7  +18.4   29.2 ECU.   -4.5 WGS.   3.0  12.74
 3022  +5.7 3.2 100  10    00  12.8  +18.1   27.2 ECU.   -4.5 WGS.   3.0  12.75
 3058  +6.3 3.3 100  10    00  12.8  +16.9   31.6 ECU.   -6.2 WGS.   3.0  12.78
 3129  +6.3 3.3 100  20    00  12.8  +18.4   30.8 ECU.   -6.3 WGS.   3.1  12.83
 3168  +6.3 3.3 100  20    00  12.9  +18.8   31.8 ECU.   -6.4 WGS.   3.1  12.92
 3171  +6.8 3.4 100  20    00  12.9  +18.4   30.0 ECU.   -6.4 WGS.   3.2  12.92
 3223  +6.8 3.4 100  20    00  13.0  +18.7   31.9 ECU.   -6.8 WGS.   3.2  12.99
 3258  +7.4 3.3 100  20    00  13.1  +18.7   34.4 ECU.   -6.8 WGS.   3.3  13.09
 3284  +7.4 3.3 100  20    00  13.2  +18.8   36.4 ECU.   -6.8 WGS.   3.3  13.17
 3293  +8.4 3.4 100  30    00  13.2  +17.6   37.2 +20.9  -6.6 WGS.   3.3  13.17
 3397  +8.4 3.4 100  30    00  13.2  +17.3   39.3 +20.9  -6.8 WGS.   3.4  13.20
 3408  +9.4 3.6 100  40    00  13.2  +15.6   43.7 +19.8  -7.7 100.00 3.4  13.17
 3542  +9.4 3.6 100  40    00  13.1  +15.1   45.1 +19.8  -7.9 100.00 3.5  13.09
 3561 +10.4 3.8 100  40    00  13.0  +14.8   49.0 +18.0  -6.8 100.00 3.6  13.02
 3716 +11.9 4.0 100  50    00  12.9  +12.1   57.8 +17.2  -7.4 100.00 3.8  12.92
 3741 +11.9 4.0 100  50    00  12.9  +11.9   63.4 +17.2  -7.5 100.00 3.8  12.92
 3796 +11.9 4.0 100  50    00  12.9  +12.2   65.4 +15.9  -7.5 100.00 3.9  12.89
 4020 +13.7 4.0 100  70    00  12.9  +14.0   75.1 +14.6  -6.9 100.00 3.9  12.89
 3996 +15.5 4.2 100  80    00  12.8  +14.2   77.7 +14.6  -6.9 100.00 3.9  12.83
 4040 +15.5 4.2 100  80    00  12.8  +14.8   78.1 +14.6  -6.8 100.00 3.9  12.83
 4130 +17.6 4.1 100 100    00  12.8  +14.4   81.9 +13.5  -6.3 100.00 4.0  12.78
 4208 +17.6 4.1 100 100    00  12.8  +14.3   82.9 +13.5  -6.3 100.00 3.9  12.78
 4208 +19.4 4.2 100 100    00  12.7  +14.1   83.4 +13.5  -6.5 100.00 4.0  12.71
 4374 +19.4 4.2 100 100    00  12.4  +12.8   90.3 +13.5  -6.5 100.00 4.0  12.42
 4368 +21.0 4.3 100 100    00  12.4  +12.2   91.8 +13.5  -6.5 100.00 4.0  12.42
 4409 +21.0 4.3 100 100    00  12.3  +12.3   91.4 +13.5  -6.6 100.00 4.0  12.33
 4572 +22.3 4.3 100 100    00  12.2  +13.1   90.5 +13.5  -6.7 100.00 4.1  12.21
 4528 +22.3 4.3 100 100    00  12.1  +12.9   91.8 +13.7  -6.8 100.00 4.1  12.06
 4597 +23.7 4.3 100 100    00  11.9  +13.3   93.5 +13.6  -6.8 100.00 4.1  11.93
 4675 +23.7 4.3 100 100    00  11.8  +13.6   93.4 +13.9  -6.9 100.00 4.0  11.76
 4761 +24.5 4.4 100 100    00  11.7  +13.9   92.6 +14.1  -7.0 100.00 4.1  11.71
 4816 +24.5 4.4 100 100    00  11.7  +14.1   93.8 +14.5  -7.0 100.00 4.1  11.71
 4960 +24.7 4.4 100 100    00  11.7  +15.8   94.6 +15.1  -7.0 100.00 4.1  11.71
 5058 +24.7 4.4 100 100    00  11.7  +15.4   96.3 +15.1  -7.1 100.00 4.1  11.67
 5184 +24.3 4.5 100 100    00  11.7  +15.3  100.0 +15.3  -7.0 100.00 4.2  11.68
 5224 +24.3 4.5 100 100    00  11.7  +16.4   97.7 +15.5  -7.2 100.00 4.2  11.71
 5216 +24.1 4.5 100 100    00  11.7  +17.1  100.0 +15.5  -7.2 100.00 4.2  11.71
 5249 +24.1 4.5 100 100    00  11.7  +17.2  100.0 +15.6  -7.2 100.00 4.2  11.68
 5249 +23.9 4.5 100 100    00  11.7  +17.3  100.0 +16.0  -7.1 100.00 4.2  11.71
 5359 +23.9 4.5 100 100    00  11.7  +17.6   96.9 +15.9  -7.1 100.00 4.2  11.73
 5527 +23.9 4.5 100 100    00  11.7  +17.8   98.5 +16.2  -7.1 100.00 4.2  11.73
 5630 +23.3 4.5 100 100    00  11.7  +18.0   98.6 +16.2  -7.1 100.00 4.2  11.73
 5727 +23.3 4.5 100 100    00  11.8  +18.2   98.6 +16.3  -7.1 100.00 4.2  11.77
 5717 +23.3 4.5 100 100    00  11.8  +18.4  100.0 +16.5  -7.2 100.00 4.2  11.77
 5698 +23.1 4.5  99 100    00  11.8  +18.7   99.8 +16.5  -7.2 100.00 4.2  11.80
 5837 +23.1 4.5  99 100    00  11.9  +19.1   98.3 +16.6  -7.2 100.00 4.2  11.87
 5868 +23.1 4.6 100 100    00  11.9  +19.5  100.0 +16.8  -7.2 100.00 4.2  11.87
 5952 +23.1 4.6 100 100    00  12.0  +19.5   98.9 +17.0  -7.2 100.00 4.2  11.96
 5931 +22.9 4.6 100 100    00  12.0  +19.5  100.0 +16.9  -7.2 100.00 4.2  11.96
 6105 +22.9 4.6 100 100    00  12.0  +19.5   99.8 +16.9  -7.2 100.00 4.2  11.96
 6150 +22.7 4.6 100 100    00  12.0  +19.5   98.4 +17.1  -7.2 100.00 4.2  12.00
 6105 +22.7 4.6 100 100    00  12.0  +20.2   97.7 +17.3  -7.2 100.00 4.2  12.02
 6172 +22.3 4.6 100  90    00  12.1  +20.7  100.0 +17.9  -7.0 100.00 4.3  12.05
 6325 +21.9 4.6 100  90    00  12.1  +22.9  100.0 +18.8  -7.2 100.00 4.3  12.06
 6459 +21.9 4.6 100  90    00  12.1  +23.1  100.0 +19.2  -7.1 100.00 4.3  12.06
 6373 +21.9 4.6 100  90    00  12.1  +23.3   98.5 +20.5  -7.1 100.00 4.3  12.06
 6680 +21.2 4.6 100  80    00  12.1  +23.6  100.0 +21.4  -7.3 100.00 4.3  12.11
 6626 +21.2 4.6 100  80    00  12.1  +23.4   98.3 +21.5  -7.3 100.00 4.3  12.11
 6459 +21.2 4.6 100  80    00  12.1  +23.4   99.2 +21.4  -7.2 100.00 4.2  12.14
 6653 +20.8 4.6 100  80    00  12.1  +23.9  100.0 +21.3  -6.9 100.00 4.3  12.11
 6775 +20.4 4.6 100  80    00  12.1  +24.1   99.7 +21.4  -6.9 100.00 4.3  12.11
 6600 +20.4 4.6 100  80    00  12.1  +24.2  100.0 +22.0  -6.9 100.00 4.3  12.11
 6747 +20.4 4.6 100  80    00  12.1  +24.6   99.6 +22.0  -6.9 100.00 4.3  12.09
 6523 +20.0 4.6 100  80    00  12.1  +24.5   98.6 +22.1  -6.8 100.00 4.3  12.06
 7032 +20.0 4.6 100  80    00  12.1  +24.9   97.7 +22.5  -7.0 100.00 4.3  12.06
 7077 +20.0 4.6 100  90    00  12.7  +25.2  100.0 +22.8  -7.0 100.00 4.3  12.67
 7077 +20.0 4.6 100  90    00  13.1  +25.5   83.8 +26.0  -7.0 LCM.   3.1  13.12
torque is good!
20 psi at redline on vf23
4.5mafv @ 5180
4.6mafv @ 5870
no knock.
already richened up the spoolup region (4k - 4k5) and the high end (6k6 - 7k) a bit.
ken
ps. look at how close the utec and oem timing #s are. stupid old bugeye ecu...
ride5000 is online now   Reply With Quote
Old 02-17-2006, 01:33 PM   #2
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRB WRX Wagon - Stg 2+
that's pretty sweet... what are you using to datalog that you can get that many lines /sec???
jstbstn is offline   Reply With Quote
Old 02-17-2006, 02:36 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
uti, coded by our very own navybluesubaru:
http://www.dezignduo.com/UTI/phpBB2/
Old 03-07-2006, 09:42 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the bigger ebay intercooler http://forums.nasioc.com/forums/showthread.php?t=825869 seems to be doing its job... (1-2 pull, 35* ambient):
Code:
 4415  -0.2 3.9  74  10    00  14.0  +16.9   47.9 ECU.   -5.7   1.00 3.7  14.00
 4426  -0.2 3.9  74  10    00  13.6  +16.7   62.8 ECU.   -5.7   1.00 3.8  13.56
 4610  -0.2 3.9  74  10    00  13.1  +17.2   69.8 ECU.   -5.7   1.00 3.8  13.12
 4873  +1.7 4.0  94  10    00  12.2  +18.2   79.4 ECU.   -5.6 WGS.   3.9  12.23
 5136  +3.9 4.1 100  20    00  11.9  +20.4   86.9 ECU.   -5.5 WGS.   4.0  11.87
 5350  +6.3 4.3 100  40    00  11.6  +20.0   97.5 +19.7  -6.6 100.00 4.1  11.56
 5537  +6.3 4.3 100  40    00  11.3  +20.7   99.8 +19.9  -6.6 100.00 4.1  11.28
 5574  +9.0 4.5  99  40    00  11.1  +21.4   99.8 +18.5  -6.7 100.00 4.2  11.14
 5797  +9.0 4.5  99  60    00  11.1  +21.6   99.8 +19.1  -6.9 100.00 4.2  11.12
 5952 +11.4 4.6 100  60    00  11.1  +21.8   99.8 +18.7  -7.4 100.00 4.2  11.11
 6082 +11.4 4.6 100  70    00  11.2  +22.0   99.8 +19.0  -7.4 100.00 4.2  11.17
 6242 +14.3 4.6 100  80    00  11.3  +23.9   99.8 +19.1  -7.2 100.00 4.3  11.28
 6397 +14.3 4.6 100  80    00  11.4  +24.3   99.8 +19.3  -7.1 100.00 4.2  11.42
 6548 +16.3 4.6 100  90    00  11.6  +24.3   99.8 +19.9  -7.2 100.00 4.3  11.58
 6548 +16.3 4.6 100  90    00  11.8  +25.0   99.8 +19.7  -7.0 100.00 4.3  11.76
 6706 +18.8 4.6 100  90    00  12.0  +24.8   99.8 +20.2  -6.9 100.00 4.3  12.02
 6802 +18.8 4.6 100  90    00  12.5  +26.0   99.8 +16.5  -6.9 LCM.   4.3  12.45
 7524 +20.0 4.6 100 100    00  13.3  +26.3    1.0 +16.8  -6.5 LCM.   4.3  13.28
 7342 +20.0 4.7 100 100    00  13.3  +25.9    1.0 +17.3  -6.5 LCM.   4.3  13.28
 7262 +21.4 4.7 100 100    00  14.6  +26.1    1.0 +18.9  -6.5 LCM.   4.2  14.58
 6988 +21.4 4.7 100 100    00  17.4  +26.4    1.0 +18.5  -6.5 LCM.   4.2  17.43
 6600 +21.8 4.5 100 100    00  21.9  +26.5   92.5 +17.1  -6.6 LCM.   4.1  21.93
 6497 +21.8 4.5 100 100    00  20.0  +25.7   88.2 +17.2  -6.6 LCM.   4.1  20.00
 6127 +21.2 4.4 100  90    00  20.0  +23.3   89.5 +16.5  -7.2 LCM.   4.1  20.00
 6006 +21.2 4.4 100  90    00  20.0  +22.4   86.8 +16.1  -7.2 LCM.   4.0  20.00
 5797 +21.6 4.4 100  80    00  20.0  +22.0   84.7 +15.6  -7.2 LCM.   4.1  20.00
 3813 +20.6 4.2 100  80    00  20.0  +14.5   69.9 +14.0  -4.7 100.00 4.0  20.00
 3898 +20.6 4.2 100  70    00  20.0  +13.4   66.5 +14.2  -5.0 100.00 4.1  20.00
 4357 +20.6 4.2 100  70    00  20.0  +12.8   82.8 +14.0  -6.1 100.00 4.1  20.00
 4504 +20.8 4.3 100  80    00  20.0  +13.4   11.5 +13.4  -6.4 100.00 4.1  20.00
 4426 +20.8 4.5 100  90    00  15.5  +13.4   98.7 +13.4  -5.8 100.00 4.2  15.50
 4357 +20.8 4.5 100  90    00  13.5  +13.0   99.4 +13.4  -5.6 100.00 4.0  13.47
 4510 +21.2 4.3 100 100    00  12.2  +13.1   95.1 +13.0  -6.5 100.00 4.1  12.21
 4468 +21.2 4.3 100 100    00  12.2  +13.3   95.3 +13.0  -6.6 100.00 4.0  12.21
 4604 +21.2 4.3 100 100    00  11.7  +13.6   92.7 +13.0  -6.6 100.00 4.0  11.73
 4585 +21.2 4.3 100 100    00  11.5  +13.4   93.9 +13.1  -6.7 100.00 4.1  11.45
 4681 +21.8 4.4 100 100    00  11.3  +14.0   95.1 +13.3  -6.9 100.00 4.1  11.28
 4755 +21.8 4.4 100 100    00  11.2  +14.4   96.8 +13.6  -6.8 100.00 4.1  11.23
 4830 +23.1 4.4 100 100    00  11.2  +14.7   96.2 +13.7  -6.8 100.00 4.1  11.23
 4852 +23.1 4.4 100 100    00  11.3  +15.4   98.5 +14.0  -6.9 100.00 4.1  11.34
 4945 +23.7 4.4 100 100    00  11.4  +16.9   99.1 +14.5  -7.0 100.00 4.1  11.39
 5104 +24.3 4.5 100 100    00  11.4  +17.9   98.0 +14.6  -7.0 100.00 4.1  11.39
 5208 +24.3 4.5 100 100    00  11.4  +19.5   96.9 +14.7  -7.0 100.00 4.2  11.42
 5274 +24.3 4.5 100 100    00  11.5  +19.5   99.0 +14.7  -7.0 100.00 4.2  11.49
 5232 +24.3 4.5 100 100    00  11.5  +19.5   99.6 +15.0  -6.9 100.00 4.2  11.53
 5274 +23.9 4.5 100 100    00  11.6  +19.5   99.5 +14.8  -7.0 100.00 4.2  11.56
 5446 +23.9 4.5 100 100    00  11.6  +19.5  100.0 +15.0  -7.0 100.00 4.2  11.61
 5546 +23.7 4.5  99 100    00  11.6  +21.0   98.8 +15.0  -6.9 100.00 4.2  11.58
 5455 +23.7 4.5  99 100    00  11.7  +20.7   98.4 +15.0  -6.9 100.00 4.2  11.65
 5621 +23.7 4.6 100 100    00  11.7  +21.4   98.8 +15.1  -6.9 100.00 4.2  11.68
 5688 +23.7 4.6 100 100    00  11.7  +21.7   98.5 +15.1  -6.9 100.00 4.2  11.73
 5777 +23.1 4.6 100 100    00  11.8  +21.7   98.0 +15.3  -6.8 100.00 4.2  11.77
 5984 +22.7 4.6 100 100    00  11.8  +22.2   99.8 +15.3  -6.8 100.00 4.2  11.77
 6337 +22.3 4.6 100  90    00  11.8  +22.4   98.7 +15.9  -7.2 100.00 4.2  11.81
 6105 +22.3 4.6 100  90    00  11.8  +22.9   99.6 +15.9  -7.2 100.00 4.2  11.81
 6049 +21.8 4.6 100  90    00  11.8  +22.6   98.6 +18.1  -7.2 100.00 4.2  11.84
 6093 +21.8 4.6 100  90    00  11.9  +23.1   98.6 +17.1  -7.2 100.00 4.2  11.87
 6277 +21.8 4.6 100  90    00  11.9  +24.4   98.3 +17.0  -7.2 100.00 4.3  11.92
 6218 +21.8 4.6 100  90    00  12.0  +23.5    1.0 +17.2  -7.2 100.00 4.2  11.96
 6385 +21.6 4.6 100  90    00  12.0  +25.8  100.0 +17.6  -7.2 100.00 4.3  11.98
 6459 +21.6 4.6 100  90    00  12.0  +26.3   99.0 +17.8  -7.0 100.00 4.3  12.02
 6361 +21.2 4.6 100  90    00  12.1  +26.3    1.0 +18.2  -7.2 100.00 4.3  12.05
 6410 +21.2 4.6 100  90    00  12.1  +26.3   98.8 +18.4  -7.0 100.00 4.3  12.06
 6435 +20.8 4.7 100  90    00  12.1  +26.6   99.6 +18.5  -7.2 100.00 4.2  12.11
 6548 +20.8 4.7 100  90    00  12.1  +27.0   98.1 +18.7  -7.2 100.00 4.3  12.14
 6640 +21.4 4.7 100  90    00  12.1  +27.1   99.0 +18.5  -6.9 100.00 4.3  12.14
 6775 +21.4 4.7 100  90    00  12.1  +27.3   97.8 +18.4  -6.9 100.00 4.3  12.14
 6872 +21.6 4.6 100  90    00  12.1  +27.5    1.0 +18.6  -6.9 100.00 4.3  12.14
 6680 +21.6 4.6 100  90    00  12.1  +28.2   98.1 +18.9  -6.9 100.00 4.3  12.11
 7017 +21.4 4.6 100 100    00  12.3  +28.8    1.0 +18.6  -6.5 LCM.   4.4  12.25
 6747 +21.4 4.6 100 100    00  13.1  +27.3    1.0 +19.2  -7.0 LCM.   3.6  13.06
first 4.7mafv ever for me!
Pushing the offset envelope?? purduephigam Tire & Wheel 15 07-30-2008 03:19 PM
To date: Who has pushed the most out of the v7 sti longblock? DoctorNick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-26-2004 10:48 AM
do i have to push the clutch all the way down? b_tapper Off-Topic 29 04-21-2003 04:16 PM
My first monkey goes too.... and the envelope please! 98kPa Bay Area Impreza Club Forum -- BAIC 13 07-13-2002 05:18 AM
black dot on the envelope? Rallyboy Newbies & FAQs 1 02-21-2002 10:26 PM
