Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-17-2006, 02:31 PM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Default Realtime Vs basemap
I understand that the basemap will not change unless you change it or unmarry it. My question is what is the realtime map?? If i want stage2 93 0ctane, i would make that my base map..What is the point of a realtime map..I read cobbs FAQ and dont understand..could you please point this out to me
ScoobySnacker is offline   Reply With Quote
Old 02-17-2006, 02:40 PM   #2
-Kevlar-
Member#: 82378
put stg 2 93 as your base and if you want valet mode, use switch map function to do it. then when you dont want it, do a reset. its so you can still switch maps without using up the ecu memory. you can only change base around 100 times. realtime is unlimited.
-Kevlar- is offline   Reply With Quote
Old 02-17-2006, 03:37 PM   #3
ScoobySnacker
Member#: 105303
2003 WRX
Thanks..its clear now
Old 02-17-2006, 04:04 PM   #4
theicewall
Member#: 70532
2004 WRX
A realtime map is for a situation like this... you have flashed the 93 octane base map and you are on a road trip. Dammit, this gas station only has 91, it sucks, what the hell do I do, my ECU will get detonation if I runn less than 93 octane now. Solution, grab handy dandy AP and load the 91 octane map without having to do a reflash. Oh, shoot, I autox and I have the 93 octane map loaded in, but I need the STX legal map, grab handy dandy AP and load up that map without a reflash. And like reviously mentioned, your wife/valet/mechanic, etc needs to borrow your car and you dont want them to have 280-300hp.
theicewall is offline   Reply With Quote
Old 02-17-2006, 07:49 PM   #5
ScoobySnacker
Member#: 105303
2003 WRX
Perfect!!! Thanks for the help...
Old 02-17-2006, 08:25 PM   #6
theicewall
Member#: 70532
2004 WRX
no problem, now just run the same realtime map as your basemap when you want to drive normally, ie. stage II 93 octane mentioned in your first post. Cobb states that your base map should be the highest map that you intend to run so that all of the basemap parameters are implemented. Some of the basemap parameters are not included in the realtime maps which is why it isnt a reflash, and in order to get the most out of stage II for instance you shouldnt run a stage I 91 octane map and then run a stage II 93 octane realtime map.
Old 02-17-2006, 09:27 PM   #7
-Kevlar-
Member#: 82378
i believe when you flash a base map it automatically flashes the same real time map.
Old 02-17-2006, 10:51 PM   #8
theicewall
Member#: 70532
2004 WRX
Real time maps aren't flashed though, they are selected. It can't hurt to check since it only takes 3 seconds right? Not to step on your toes over a technicality but I'd want to double check if it was my car.
Old 02-18-2006, 09:23 AM   #9
-Kevlar-
Member#: 82378
what do you mean? check which real time map is selected? if so you cant. you can only check the base map. but you could just reset and then do a switch.
Old 02-18-2006, 07:27 PM   #10
theicewall
Member#: 70532
2004 WRX
Plug in AP, go to select map, chose 93 octane stage II, push big button. Done. Check it by just pushing the select button and that gurantees 100% that the correct map is loaded.
Old 02-18-2006, 07:37 PM   #11
-Kevlar-
Member#: 82378
ok...
Realtime vs. Reflash justin24 Engine Management & Tuning 2 05-04-2010 06:55 PM
Cobb AP Stg2 basemap vs realtime DubUAreEx Newbies & FAQs 2 02-27-2007 01:16 PM
Need help!!!! QUICK...BASEMAP vs. REALTIME 06BlackSTIwith550WHP AccessPort 7 09-12-2006 12:04 PM
accessport wont flash new basemap or realtime map... wrxraaca Engine Management & Tuning 3 08-09-2005 10:05 AM
AccessPort RealTime vs. Base jnmarshall Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-02-2004 12:10 PM
