Old 02-17-2006, 02:40 PM   #1
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Default WD-40 vs. PB Blaster
I've seen people recommend one over the other and vice versa.
Which one is better?
Maybe one of them is better for one thing and another for another?
Ideas?
kainam00 is offline   Reply With Quote
Old 02-17-2006, 02:43 PM   #2
Amazake
Member#: 9889
ZEP is better than both
Amazake is offline   Reply With Quote
Old 02-17-2006, 02:45 PM   #3
kleggo
Member#: 105294
Default wd-40?
wd-40, no matter what their claims are, is a cleaner, not a lubricant i.m.o.
it might also be a decent water displacer.
no clue what pb blaster is.
be safe
kleggo
kleggo is offline   Reply With Quote
Old 02-17-2006, 02:47 PM   #4
BoneStockTS
Member#: 80670
WD-40 is crap for penetration, it's OK for cleaning and short-term lubrication.
BoneStockTS is offline   Reply With Quote
Old 02-17-2006, 02:47 PM   #5
TheLegacy
Member#: 47615
2007 BMW 335XI
Saphire Black
pb blaster is awesome
TheLegacy is offline   Reply With Quote
Old 02-17-2006, 02:48 PM   #6
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
pb blaster is a rust penetrant.
Danny Boy is offline   Reply With Quote
Old 02-17-2006, 02:49 PM   #7
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Anyone who has any automotive knowledge will tell you that PB Blaster is roughly 1000x better than WD-40 for loosening bolts. PB Blaster has corrosive properties that eat through rust. WD-40 is really only for cleaning. It is not a lubricant, in fact, after about 2 days it has a reverse effect when you try to use it to lubricate something and it does nothing for lossening rusted/stuck parts.
02BlueSuperRoo is offline   Reply With Quote
Old 02-17-2006, 02:50 PM   #8
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
WD-40 and PB Blaster were designed to do different things.
WD-40 dries and degreases... it's mean to coat metals so that they resist corrosion, not break nuts free with.
PB Blaster is a purpose built penetrating fluid that eats away at corrosion to break the surface tension between two rusty parts.
Old 02-17-2006, 02:51 PM   #9
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
Very different purposes. PB Blaster for breaking bolts (like taking off your exhaust), WD40 for lubricating (like removing exhaust hangers).
fireball_jones is offline   Reply With Quote
Old 02-17-2006, 02:54 PM   #10
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Zep owns all, but PBBlaster is OK.
W-D 40 is a water displacer (that's what the W-D stands for.), and is virtually useless as a penetrating oil.
VpointVick is online now   Reply With Quote
Old 02-17-2006, 03:02 PM   #11
BraveUlysses
Member#: 93205
There's something better than PB? I'll have to try it!
BraveUlysses is offline   Reply With Quote
Old 02-17-2006, 03:03 PM   #12
-Kevlar-
Member#: 82378
liquid wrench and PBlaster did the job for me....
-Kevlar- is offline   Reply With Quote
Old 02-17-2006, 03:07 PM   #13
Davenow
Member#: 23676
no contest
Zep FTW
But in liu of zep, PB blaster.
Old 02-17-2006, 03:07 PM   #14
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
Smile
PB Blaster has helped me out a couple of times.
SilverSubaab is offline   Reply With Quote
Old 02-17-2006, 03:10 PM   #15
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
+1!
Good. Now I have it cleared up! Thanks!
Is this the Zep stuff you were talking about: http://store.yahoo.com/tri-maxx2000/bizpenoil.html ?
Kinda expensive
Old 02-17-2006, 03:16 PM   #16
fireball_jones
Member#: 67536
00 AW GM6
Do they make an aerosol liquid wrench? I just picked up a squirt bottle, and it's pretty much useless once it's half empty.
Old 02-17-2006, 03:17 PM   #17
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Originally Posted by kainam00
+1!
Kinda expensive
That's the stuff.
Think about all the Tylenol you won't have to take, that should help offset the cost.
Old 02-17-2006, 03:20 PM   #18
-Kevlar-
Member#: 82378
yes....i have almost a full can at home...
Old 02-17-2006, 03:31 PM   #19
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Originally Posted by VpointVick
That's the stuff.
Mm... interesting...
Any local-type stores have it? I.e. Autozone, Walmart or something?
Old 02-17-2006, 03:36 PM   #20
VpointVick
Member#: 93193
'03 325iT
Mysticblau
I haven't looked for it in some time.
Depot carries Zep products, but I'm not sure about the Zepreserve.
Here's the MI branch info, they should be able to tell you where you can buy it.
34462 Glendale Ave.
Livonia, Michigan - 48150
(734) 525-0800
Old 02-17-2006, 03:37 PM   #21
Amazake
Member#: 9889
I use Zep 45
Old 02-17-2006, 03:53 PM   #22
dj_booduh
Member#: 70861
2005 Scoobie WRX
pb blaster saved my life!!!!
dj_booduh is offline   Reply With Quote
Old 02-17-2006, 09:16 PM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
LPS1 or LPS2.....
http://www.lpslabs.com/Products/Lubricants/LPS1.asp
http://www.lpslabs.com/Products/Lubricants/Lps2.asp
LPS products are used in avation, worldwide......and are da bomb
ACE hardware usually has the above.
Old 02-17-2006, 09:22 PM   #24
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
/87 FJ60 /Hewes Redfisher
quadturbowrxgtr-s is offline   Reply With Quote
Old 02-17-2006, 09:35 PM   #25
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Yes, $1.78?
WD-40 is what you use to take gum off your shoe.
"Liquid Wrench" is good & inexpensive (read longer soak time)
"PB" is better & reasonably priced
I have had to reapply Liquid Wrench for some Turbo nuts, but they have always come loose (knock on wood) Figure 1/2 hour soak time.
Both are avalible at the local hardware store (on a weekend, when you magically run out, & you though you had another can, & you can't find it, & need it NOW kind of thing)
If you need a lubricant, Silicone or Teflon baised is way better than WD-40
GLwagon is offline   Reply With Quote
Is PB Blaster safe to use on the rear swaybar bushing mounts? skydes Newbies & FAQs 2 07-07-2007 03:49 PM
I love PB Blaster Spheris Off-Topic 6 11-15-2005 11:35 PM
PB Blaster 2 for 7.00 Pep Boyz Bundyboyz Mid Atlantic Impreza Club -- MAIC 6 07-03-2005 10:16 AM
Best penetrating oil? WD40, Liquid Wrench, PB Blaster... JoeTX Newbies & FAQs 39 05-26-2005 09:00 PM
PB Blaster is fastAr plunk10 Off-Topic 15 01-17-2004 01:01 PM
