Old 02-17-2006, 04:56 PM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default About COBB and AccessPort
Their customer service is great. However, the AccessPort product is average. First, the AccessPort user interface is not that good. Things like resetting your ECU. When you perform a reset, it does not say if its done. Also, when using real map, did not tell us what real map we are using.
In addition, if you look at their map notes, http://www.cobbtuning.com/sti/access...2093%20oct.txt
At the bottom, it says if you receive a P0422 OBD code, should use the LWG version of the map. Should it be P0244
Well, overall, they are ok ok..
- Charles
chaddeus is offline   Reply With Quote
Old 03-07-2006, 01:07 PM   #2
kevin2.5rs
Member#: 67518
2013 Focus ST
TB
- Charles
It takes like 3 seconds
Do not use the AP to reset the ECU. Pull the neg cable.......
It does not reset everything
Thats an easy one. look at the map before flahing or
> SHOW CURRENT MAP
Also flash the base map only. REAL TIME map is sent along with it
kevin2.5rs is offline   Reply With Quote
Old 03-07-2006, 02:47 PM   #3
chaddeus
Member#: 56624
2004 Subaru WRX STi
> SHOW CURRENT MAP
Showing current map will ONLY show u the map base and not the real time. So if you base is say xyz map, and you use abc real time map, and when you check your current map, it will show xyz
- Chalres
Old 03-07-2006, 02:48 PM   #4
parker/slc/gc8fan
Member#: 46241
- RIP
SDF-1
I'd prefer to reset my ECU and keep the radio presets.
The AccessPorts ECU reset clears all of the engine related memory on the ECU.
parker/slc/gc8fan is online now   Reply With Quote
Old 03-07-2006, 02:51 PM   #5
chaddeus
Member#: 56624
2004 Subaru WRX STi
Yes. That is the reason why I do not want to pull the battery cos I'll need to waste time setting up the audio
- Charles
Old 03-07-2006, 05:18 PM   #6
elucas730
Member#: 42714
'07 BMW 335i E90
The user's manual states that using the RESET ECU function on the AccessPort does not reset the learning of the ECU. Hence, kevin's statement that the reset does not clear everything.
elucas730 is offline   Reply With Quote
Old 03-07-2006, 08:30 PM   #7
chaddeus
Member#: 56624
2004 Subaru WRX STi
So what is the reset there for? To reset what? If my base is say 93 Oct and real time is Economy, then if I reset, it will go back to 93 Oct right?
Now, if my base is 93 Oct and I set to Economy mode, should I reset OR should I change my real time to 93 Oct?
- Charles
Old 03-07-2006, 08:33 PM   #8
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Yes...
If you want to go back to your base 93 map, you could reset...or flash the realtime 93. (I personally would reset...it's just as easy and the base maps have more in depth parameters than the realtimes).
Reset ECU only clears the volatile memory. Base map is stored in non volatile memory. You dont have to flash the base map again, but you will lose your real time map. (if using one)
darkstarmoto is offline   Reply With Quote
Old 03-10-2006, 09:00 AM   #9
chaddeus
Member#: 56624
2004 Subaru WRX STi
I have a question about the reset function. How do I know its being resetted? There is no indicator that the reset is successful or whatever.
I think the user interface of AccessPort is very poor
- Charles
Old 03-10-2006, 10:49 AM   #10
-Kevlar-
Member#: 82378
you dont really know by it telling you. but rather load the valet map and then do a reset and you can clearly see its working.
-Kevlar- is offline   Reply With Quote
Cobb DP Borla hush and Perrin UP and Accessport FS! Ej205scoob Engine/Power/Exhaust 17 10-11-2009 12:05 AM
FS: Cobb catback and AccessPort v1 for 04 STi and tranny mount 801_STi RMIC Private Classifieds 5 09-30-2009 12:32 AM
Cobb Tuning Accessport Version I Cobb Accessport WRX0520 Engine/Power/Exhaust 0 07-18-2007 03:02 AM
Gauging interest: 04 Cobb AP / Accessport and 04 ECU Bishop SCIC Private Classifieds 4 05-03-2006 04:48 AM
Questions about UTEC and Accessport/AccessECU anti.team Engine Management & Tuning 1 04-22-2004 02:07 PM
