Old 02-17-2006, 07:33 PM   #1
NYCshopper
Member#: 5126
Default NEW BMW Turbo Engines @ 2006 Geneva Show
Web Translation from German BMW Press Site:
Thus BMW in Geneva presents a world premiere also on the drive sector: the first row six cylinder engine with Bi-turbocharger, gasoline direct injection High Precision Injection and full aluminum crank case. The new engine combines unusual leistungskraft with an economy unknown for engines of this building method. It is thereby a particularly fascinating example of efficient dynamics. The new turbo engine extends the drive program, which provides again and again with its varieties and the high technical level for fascination. BMW presents the current engine versions of all performance classes in Geneva, among them directly several drive units, which were distinguished only recently with a "engine of the Year Award".
http://www.e90post.com/forums/showth...4&page=1&pp=22
N54 Bi-Turbo engine with HPI direct injection.
306HP, 400Nm available in range 1500 to 5800rpm. Max 7000 rpm. With full alluminium crankshaft casing, Bi-VANOS, electric water pump. 70kg less weight than 4.0L V8 NA engine. No turbo lag.
Tested in E90:
80-120kmh in 6.3s (eg. 330i in 8.2s)
0-100kmh in 5.7s (eg. 330i in 6.3s)
NYCshopper is offline   Reply With Quote
Old 02-17-2006, 08:27 PM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Very interesting...
Old 02-17-2006, 08:40 PM   #3
someguyzero
Member#: 102173
Bi-Turbo from 0-100km/h in 5.7s???? With only 306hp? That's a lot of 'detuning' there. Though the no turbo lag is very interesting.
Is this for the upcoming 335i?
someguyzero is offline   Reply With Quote
Old 02-17-2006, 08:44 PM   #4
FunkyBoost
Member#: 70614
2005 WRX
Crystal Gray
That looks like a parallel setup, not sequential.
FunkyBoost is offline   Reply With Quote
Old 02-17-2006, 09:35 PM   #5
BigFatGeek
Member#: 31215
2001 VW EuroVan MV
03 Legacy L-SE Wagon
"unusual leistungskraft"
I couldn't agree more.
BigFatGeek is offline   Reply With Quote
Old 02-17-2006, 09:36 PM   #6
Len
Member#: 39937
2011 328i 6MT
LMB
No, that is not "detuning". They use smaller turbo to eliminate the turbo lag and improve the throttle response. It's not easy to make a turbo engine that provides maximum torque from 1500RPM. This N54 engine is supposedly one of the most advaced F/I engines in the world, just a very different animal compared to the WRX/STI turbo.
Len is offline   Reply With Quote
Old 02-18-2006, 12:43 AM   #7
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
Exactly. Ever see the puny little K03 and K04's on the AUDI's ? This is exactly how they use to achieve full boost at such low RPM's. Don't know what Turbo the 2.0T's are using. Pathetic little Honeywell units
Old 02-18-2006, 02:54 AM   #8
FrostyAK
Member#: 84835
306hp? Doesn't that exactly mirror the Lexus 350IS?
- Chris
FrostyAK is offline   Reply With Quote
Old 02-18-2006, 03:55 AM   #9
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Yeah, what is it, 3L? 3.5L? Still should make a lot more than 306hp when turboed.
bemani is offline   Reply With Quote
Old 02-18-2006, 04:11 AM   #10
NismoSkylineGTR
Member#: 94622
looks like bimmer can't hange with audi's new V8 turbo in the RS4 and gonna rack up a turbo engine in the next m3
NismoSkylineGTR is offline   Reply With Quote
Old 02-18-2006, 07:18 AM   #11
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
ahhh, NO.. Next M3 will be V8 version of M5s v10... no turbo..
amdmaxx is offline   Reply With Quote
Old 02-18-2006, 09:13 AM   #12
brandon
Member#: 1183
09 Legacy, 76 Mini
64 Lotus Elan, 70 Elan +2
I've said it before, and I'll say it here again. Until someone comes up with massless turbines and compressors, purely exhaust driven systems will always have turbo lag. Simply having boost does not mean there is no lag. Lag is is amount less boost the turbo produces on accelleration as compared to the boost it would be producing at steady state. Having no turbo lag would be akin to saying you car can do 0-60 in zero seconds... not possible. There is nothing all that interesting about getting boost and peak torque at such low rpms. Given a small enough turbo, you could have boost at idle if you wanted (and there would still be lag). It's always give and take though, lots of boost at low rpm will mean the turbo will run very inefficiently at high rpm.
brandon is offline   Reply With Quote
Old 02-18-2006, 10:02 AM   #13
Len
Member#: 39937
2011 328i 6MT
LMB
Good point Brandon. I should've said "reduce" instead of "eliminate", but I think people would know that it's impossible to truely "eliminate" inertia from a physical system, and I meant it in the asymptotic sense.
As far as the term "turbo lag" goes, it seems to me like it can be used for two somewhat different but related things. People use it to describe the delayed throttle response on boost, and also to describe the lack of boost below certain RPM. Either way, this new N54 engine is supposed to "reduce" it greatly.
Old 02-18-2006, 02:27 PM   #14
wallyman424
Member#: 60357
#17 NASA ST2 Z06
my wang > your wang.
ewwwwwwwwwww plastic end tanks!
wallyman424 is offline   Reply With Quote
Old 02-18-2006, 02:56 PM   #15
CapeRex
Member#: 81070
RS4 is a naturally aspirated 414hp V8...NO turbos.
CapeRex is offline   Reply With Quote
Old 02-18-2006, 03:00 PM   #16
Freon
Member#: 88322
2009 BMW 135i
Still trying to figure out how the rear turbo compressor gets its air.
And the intake to thr front turbo looks horribly constrictive.
I'd imagine if you can figure out how to add more fuel (who knows how you "upgrade" direct injectors), lots of power would be possible with intake and exhaust work, and obviously larger turbos.
Freon is offline   Reply With Quote
Old 02-18-2006, 11:39 PM   #17
someguyzero
Member#: 102173
Damn looks like e46 M3s may still hold their value yet. I was hoping the turbos would push it into the e46 M3's range, therefore it would cause them to depreciate faster so I can buy one!!!!
Old 02-19-2006, 04:46 PM   #18
NismoSkylineGTR
Member#: 94622
well top gear when they tested the new rs4 they said its packed with bi turbo
Old 02-19-2006, 05:19 PM   #19
senomar
Member#: 47636
01 rsti v7
blue
this was talked about 5 or 6 months ago... i remember hearing it's gonna be an "in between" motor for the top end of the 3 series (not counting the M), and the M...
senomar is offline   Reply With Quote
Old 02-19-2006, 06:11 PM   #20
o2sys
Member#: 43842
200? WRX STI
wasnt that the RS6? V8 bi-turbo
o2sys is offline   Reply With Quote
Old 02-19-2006, 06:14 PM   #21
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
RS6 is using Gallardo's V10.. Guys, get your facts straight..
Old 02-19-2006, 06:15 PM   #22
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
no they didn't.
SubasaurusWrex is offline   Reply With Quote
Old 02-19-2006, 06:20 PM   #23
o2sys
Member#: 43842
200? WRX STI
yea ok and ur 2000 VW must have the V12 right?
http://www.fantasycars.com/sedans/html/rs6.html
Old 02-19-2006, 06:29 PM   #24
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
worst belt system ever +1
Bundyboyz is offline   Reply With Quote
Old 02-19-2006, 06:33 PM   #25
BillT
Member#: 16169
2002 WRX Wagon
The previous generation RS6 used a bi-turbo V8 rated at around 450hp.
BillT is offline   Reply With Quote
