Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 02-18-2006, 12:23 AM   #1
the_poser
Member#: 106234
'o8 5.7 Tundra
'07 sv650s
Default Does a ECU fix the CELs?
Just wandering...
If you go catless on your exhaust, does an ECU reflash [EcuTek, Cobb, etc...] fix the CEL?
say for instance when it comes to inspection, and they plug in th ECU to check for CELs.
the_poser is offline   Reply With Quote
Old 02-18-2006, 01:21 AM   #2
turboscooby13
Member#: 56280
2003 M3
Cobb AP clears CELs...
turboscooby13 is offline   Reply With Quote
Old 02-18-2006, 01:37 AM   #3
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
yes if you are reflashing you can disable any cel
Hitokiri is offline   Reply With Quote
What does it mean when the cel flashes josh04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-08-2006 07:03 PM
Will COBB AP fix the CEL with HELIX DP? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-03-2006 12:07 AM
Anyone with Borla header and CEL, did the ECU recall fix the CEL? Suba_Roo Normally Aspirated Powertrain 14 01-25-2003 01:53 AM
Does anyone here know the answer to this CEL FIX resistor question?(LINK) Rick G Tri-State Area Forum 1 09-25-2002 11:21 AM
Fixed the CEL rallysquirrel Legacy Forum 8 10-01-2001 06:09 PM
