Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 02-18-2006, 02:54 AM   #1
terrenceseet
Member#: 107542
1993 Toyota MR2
Default Help!!! New project car Impreza L 95 2WD 1.8 Conversion and mods ?
I have just purchased an IMPREZA 1.8 2WD L and i am new to SUBARU. I need some opinions on how to make it a better car. i was thinking of doing an
-AWD swap / or 2wd with rear disc brake conversion
-engine transplant.
I need more info on doing the AWD SWAP and is it practical ?
Which engine do NASIOC members recommend ?
EJ22 ? EJ25 ? EJ20T ?
What do i need for the following engines ? as in terms of wiring and things ? i heard that it is a pain to wire EJ20T
Finally, WHERE CAN I GET THE FACTORY SERVICE MANUAL FOR the impreza ?
PLEASE HELP .... THANK YOU
terrenceseet is offline   Reply With Quote
Old 02-18-2006, 03:06 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 02-18-2006, 04:49 AM   #3
terrenceseet
Member#: 107542
1993 Toyota MR2
THankS for the info...
Where would be a good place to find engines ?
Old 02-18-2006, 09:03 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
check the classifieds on here and ebay...
Old 02-18-2006, 10:07 AM   #5
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
The ej251 out of the RS is probably the easiest swap you can do. I did that swap to your exact same car. Piece of cake.
subbyspeed is offline   Reply With Quote
Old 02-18-2006, 10:36 AM   #6
93L-RS
Member#: 105753
I swapped an '01 RS motor into my '93. Easiest swap in the world. If you convert to AWD, be ready for a LOT of work. I think it's worth it, but it all depends on your point of view...
93L-RS is offline   Reply With Quote
Old 02-18-2006, 11:05 AM   #7
terrenceseet
Member#: 107542
1993 Toyota MR2
thank you again for the tips,
does awd conversion require alot of work ? or all bolt ons ? to convert to a 2.5rs do i need to do alot of wiring ?
can i work on the car without a huge hydraulic lifter ?
Old 02-18-2006, 11:35 AM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
very little wiring needed.. There is some, but its pretty straight forward.. Theres a decent amount of info out there on it. This is of course using the 1.8ecu and wiring for the 2.5 engine.
You have to wire up the coolant temp sensor to accomodate the 2.5rs. involves using the RS plug, and taking the 2 sensors from the 1.8 and combining into 1 plug. Its easy.
The injectors you have to fiddle with the plugs. easy.
use the 1.8 throttle body on the 2.5 intake manifold.
I took the time to wire up the coil for the 2.5, instead of using the 1.8 coil and ignitor and getting custom plug wires made.
Otherwise, its pretty straight forward. the engine drops right in, you can use the accessories from the 1.8 on the new engine.. its cake.
Old 02-20-2006, 12:11 AM   #9
terrenceseet
Member#: 107542
1993 Toyota MR2
THANK YOU FOR ALL THE APPROPRIATE INFO ... I HAVE decided to go for the 2.5 rs engine but i cant find it anywhere... T_T
Old 02-20-2006, 08:37 AM   #10
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i saw one from an 02 for sale in the classifieds. Make sure you get the engine harness with it.
Old 02-20-2006, 02:18 PM   #11
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
would an 02 engine swap as conveniantly as one from a GC chassis? wouldnt he still want to use the 1.8 engine harness and sensors if hes using that ECU? i used my 1.8 engine harness on a turbo motor and yeah, its really easy if your not changing the ECU
Natoe is offline   Reply With Quote
Old 02-20-2006, 05:15 PM   #12
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i would think the 02 is the same.. Just a few differences. If it were me, i'd go pre-02. Mine is from my 01 RS. I used the 1.8 engine harness, but used a few of the connectors off the RS harness to utilize the 1.8. Like the coolant temp sensor plug, and injector plugs.
Old 02-20-2006, 08:54 PM   #13
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
please watch the caps in the subject lines, thanks.
Jay
Finnally got my new rims on the GC and a pic of my new project Car for next year bstoehr83 Member's Car Gallery 25 04-13-2010 07:57 PM
WTB 5 speed 95-97 1.8 impreza AWD tranny or 97-99 legacy outback AWD tranny mellow65 NWIC Private Classifieds 5 08-23-2008 04:43 AM
Would this be a good conv car? 2wd 1.8 elegal Subaru Conversions 10 01-15-2004 10:18 PM
Was looking for a new project car and found this: Akirasoft Mid West Subaru Owners Club Forum -- MWSOC 23 10-10-2003 12:09 AM
New Project Car Boxer4Racing SVX Forum Archive 2 11-28-2000 07:32 PM
