Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-18-2006, 02:54 PM   #1
JDMSUBAROO
Member#: 106823
2000 v8 rsti
Default 2.0 to 2.2 storker?
would it be a possibility to take the crank out or a ej22 and put in into an ej20 to stroke it? what combination of pistons and rods would i need to make this work? i already have the ej22 crank and rods avalible for me so i would rather use those parts, considering theyare alreeady forged, rather then go spend 3k on a cobb stroker kit.
JDMSUBAROO is offline   Reply With Quote
Old 02-19-2006, 01:40 AM   #2
foolio
Member#: 9351
2006 trailblazer SS
black
2.0L Block, 2.5L (sti) 79mm crank. 2.0l wrx rods. Custom pistons, Stroked.
foolio is offline   Reply With Quote
Old 02-19-2006, 02:43 PM   #3
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
a ej22 is a bored motor, not stroked. ej22 rods and cranks are identical to ej20.
swapstar is offline   Reply With Quote
Old 02-19-2006, 08:11 PM   #4
JDMSUBAROO
Member#: 106823
2000 v8 rsti
if this is tru then it sounds like it would be a waste of time considering i have the ej22 closed deck block avalible to me. do you think i would be able to use ej20g heads on the ej22?
Old 02-19-2006, 11:53 PM   #5
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
sure. thats a trick thats been used forever.
rebuild the bottom end on that ej22....
when stroking from a 2.0 to a 2.2l hagood22 Built Motor Discussion 13 12-23-2008 11:51 AM
2.0 to 2.5L with blown 2.0 ecu????? AUTO DjKlown UTEC 1 11-20-2008 08:58 PM
Boring out a 2.0 to a 2.2? reddevil Built Motor Discussion 3 08-09-2007 07:25 PM
Going from 2.0 to built 2.5. EM Questions Big-Sexy907 Engine Management & Tuning 3 05-19-2006 07:43 PM
Want to switch from a blown stock 2.0 to an 2.5 sti short block jaltman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 02-01-2006 07:40 PM
