Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 02-18-2006, 03:15 PM   #1
gkbrowne89
Member#: 107869
Default Engine Noise - Cold Engine
Hi all-
My wife owns a 2003 Impreza 2.5 Sport with roughly 37,000 miles. Within the last couple of months we've noticed an engine noise that sounds (at least to my ears) like improperly adjusted valve(s). We took it into the dealership and the first pass they found that the timing chain tensioner needed replaced which seemed pretty reasonable. They replaced it and the noise persisted. We went back and we were informed that nothing was wrong. It was explained that "That's the way these engines are". They attached a bulletin from Subaru explaining that some technical changes were made to the engine to reduce friction and therefore improve efficiency, this noise was the byproduct of these changes. Most notably the piston skirts had been shortened, resulting in Piston Slap. My question being, is anyone else experiencing this noise, and does the explanation seem reasonable. I don't want to get past the drivetrain warranty and find out that we've been had.
Thanks for reading
gb
Seattle, WA
gkbrowne89 is offline   Reply With Quote
Old 02-18-2006, 03:20 PM   #2
orndog
Member#: 34670
2013 No gears!
Saltine American
Very common in cold weather.
orndog is offline   Reply With Quote
Old 02-18-2006, 05:13 PM   #3
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
sounds like a sewing machine
moogoob is offline   Reply With Quote
Old 02-19-2006, 02:23 AM   #4
kamil212
Member#: 90596
2009 Scrambler
Bitches love Scramblers
when the engine is cold it will make that noise, knocking sound, just ^^ like he said, a sewing machine.
kamil212 is offline   Reply With Quote
Old 02-19-2006, 11:00 AM   #5
orndog
Member#: 34670
2013 No gears!
Saltine American
You guys have some loud industrial sewing machines then
Old 02-19-2006, 02:39 PM   #6
buyos1717
Member#: 82377
2003 S2000
Grand Prix White
I was just about to post something similar to this. However, mine isnt only when its cold. Its when im around the 2500~3000 RPM marks. Usually when im in a higher gear when i shouldnt be or just accelerating around those marks. Mine sounds kind of like a squeaking or a belt slipping. Im not too sure what a sewing machine really sounds like but is that the type of sound you get at all? i found that when i have new oil or i put in premium (91 octane) as opposed to regular (87 octane) the sound goes away or is diminished drastically. Is this what you have?
This isnt a hijack!
buyos1717 is offline   Reply With Quote
Old 02-19-2006, 07:13 PM   #7
moogoob
Member#: 7101
00RS I want to fill
[crock dundee]Thats not a hijack.... THIS is a hijack![/crock dundee]
ok, i dont have anything else....
Old 02-19-2006, 07:26 PM   #8
sha_zapple
Member#: 41012
1998 Legacy L
It sounds like a stick running along a fence, or the wheel of fortune. A squeaking sounds more like belts slipping than anything.
Put a lighter oil (5w-30) in the engine during the winter months and the noise will go away faster.
sha_zapple is offline   Reply With Quote
Old 02-19-2006, 11:10 PM   #9
buyos1717
Member#: 82377
2003 S2000
Grand Prix White
Are you answering the first post or mine?
Old 02-19-2006, 11:35 PM   #10
klug
Member#: 4133
'01 2.5RS Sedan
'05 LGT Wagon
I have the same noise. Last winter I took it in and they replaced the timing best tensioner (under warranty) and no change. The colder it is the more prevalent it is. Now that it's dipped to -27C, it takes about 10-15 min to go away. I took it to the dealership and thay said it's OK. I think they're using the criteria that if it doesn't go away, it needs to be fixed. It only happens when you load the engine 1800-2500 RPM when cold. Only does it for 30 sec to 1 min at idle for a cold start, and then you can hear it when you load the engine. Can't hear it at all when the engine is completely warm. I'm not too worried. If it fails down the road I'll look at it as an opportunity to upgrade...
Hope this helps.
klug
klug is offline   Reply With Quote
Old 02-20-2006, 08:12 PM   #11
AWDimprezaL
Member#: 94061
1996 impreza
red mica
its called piston slap, and any and all n/a 2.5's are notorious for it
AWDimprezaL is offline   Reply With Quote
Old 02-21-2006, 12:24 PM   #12
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Hey, buyos1717, I have a 98 dohc that does exactly what you are describing...at temp, and under partial throttle at higher revs(3500-5000) there is a horrible noise... almost sounds like a bearing about to spin, but it has been doing it for 3 years now,about 75K miles. Im only guessing here, but from all i have heard and read, it has something to do with the piston and oiling systems design. Ive resigned to the fact that it is one of those and it helps me to sleep a little bit better everynight(I still lie awake and ponder the ulitmate RS but at least im not thinking about bad main bearings)
snoopyone8 is offline   Reply With Quote
"knocking" noise when engine is cold Dons Soobie Doo Service & Maintenance 33 05-27-2008 06:09 PM
Ticking noise when engine is cold nsnguyen Legacy Forum 8 06-08-2004 02:11 PM
Engine noise, ticking sound when cold Zuffy Canada Region Forum 12 11-03-2003 09:54 AM
Cold engine noises. obs_commuter Normally Aspirated Powertrain 1 01-26-2003 07:54 PM
