Old 02-18-2006, 09:12 PM   #1
RollingOnAll4
Member#: 30109
2000 full blown
Dirty Whore
Impreza GC8 will a WRX oil pump and water pump
work on an EJ22T block....
RollingOnAll4 is offline   Reply With Quote
Old 02-18-2006, 09:17 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Yes...
jamesfacts is offline   Reply With Quote
Old 02-19-2006, 12:46 AM   #3
99WRXEJ20
Member#: 34545
1999 GC8
74f
Err....
OK. but it all depends. Will it fit? yes. Will you have to mess with your cooling lines?yes. Nothing major.
99WRXEJ20 is offline   Reply With Quote
Old 02-19-2006, 12:58 AM   #4
redwagon
Member#: 2181
2008 SpecB
If I'm not mistaken, the EJ22T had a beefier oil pump to feed those piston squirters. The WRX pump will probably not make enough pressure if it has to run the squirters, even if it does fit.
redwagon is offline   Reply With Quote
Old 02-19-2006, 04:44 AM   #5
Skully
Member#: 48990
98 Impreza RS
RBP
a WRX oil pump and EJ22T oil pump are physically identical in peices parts. The only thing different between the two is the EJ22T pump has shims down in it to raise the oil pressure. We have put these on WRX motors and it raises the oil pressure by 10-15psi. You can buy the shims from subaru if you just want to shim your WRX oil pump.
-Thomas
Skully is offline   Reply With Quote
Old 02-19-2006, 05:01 AM   #6
02Toyowrx
Member#: 56520
Skully are you sure that the EJ22 pumps internal gear isnt wider, resulting in more volume?
02Toyowrx is offline   Reply With Quote
Old 02-19-2006, 12:33 PM   #7
RollingOnAll4
Member#: 30109
2000 full blown
Dirty Whore
thanks for to quick response....just sorting out a quick3er way of getting my build up going...
Old 02-20-2006, 01:58 AM   #8
Skully
Member#: 48990
98 Impreza RS
RBP
im 100% sure, we took them apart and measured them with a set of calipers. The internal rotors are identical. Only difference is the shims in the pump spring housing.
-Thomas
Sold! Jubert39 NESIC Private Classifieds 4 05-27-2010 04:17 PM
Sold! Jubert39 Engine/Power/Exhaust 5 05-27-2010 04:16 PM
Aftermarket Blitz BOV, '02 WRX Oil and Water Pump, BOV, and Stock TMIC *NEEDS TO GO* Rextion Engine/Power/Exhaust 5 03-29-2010 04:43 PM
What oil pump and water pump for Spec C EJ207? moss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-27-2006 02:06 PM
NC: WRX Oil and Water Pumps FS crazyhorse Private 'For Sale' Classifieds 3 02-22-2004 10:38 AM
