Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-18-2006, 09:44 PM   #1
ejsportcom
Member#: 88905
Default 100% inj. duty on stock turbo 11psi
ok so im tuning with my utec on my 02' wrx and at 11psi with the stock turbo and injectors, raised fuel pressure, full custom fuel rails with -6an feeds, walbro 255lph, and 7000rpm im getting a bunch of 100% inj duty's. my a/f's are at about 11.2-11.4.... im just lost, any suggestions?
ejsportcom is offline   Reply With Quote
Old 02-18-2006, 09:48 PM   #2
Freon
Member#: 88322
2009 BMW 135i
You can consistently log this? Any gear? Can you post lots? Straight line acceleration?
I saw my injectors max out pretty bad once, and even got some knock due to it, but subsequently could never log it again, only see 88-92%. I think that incident was due to low fuel level and hard cornering.
Freon is offline   Reply With Quote
Old 02-18-2006, 10:02 PM   #3
ejsportcom
Member#: 88905
i'll throw up a log tomorrow. as for it not happening much, well if i was to say that, i would be lying. it happens everytime i log consistantly. the weird thing is that it never causes knock, ever. and i had gotten some pretty bad knock down low that i had tuned out.
Benefit for Walbro pump on stock turbo/inj SAABARU_92x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-06-2007 09:43 AM
I need a diagram of the stock vacume hoses where the restictor goes on stock turbo mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-16-2005 12:23 PM
Maxing out stock injectors on stock turbo OCD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2005 07:25 PM
300 WHP on stock turbo? Thoughts on Cobb? D'sScooby Newbies & FAQs 4 08-27-2003 05:20 PM
Question on boost on stock turbos 93coupe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-05-2002 12:33 AM
