Old 02-19-2006, 12:19 AM   #1
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Default EGT problem???
I have been trying to install some Gruppe-s headers this afternoon, and while trying to install the EGT probe I come up with a little problem.
I removed the stock exhaust headers & installed the tap for the EGT probe into the Gruppe-s headers with out a problem... When I began to tightened the set screw I noticed that it was kinda hard to turn so I tried to back it out to see if it was cross-threaded and it did not budge... so a long story short the set screw is some how stuck inside the tap and I can't tighten or loosen the set screw because the alen key is striped. soooo I sent AutoMeter an e-mail tonight telling them my situation and to request a new tap, but my question is what do I do in the mean time???
I might try to take some exhaust rap and strap to hold it into place for the next few days until I get the replacement, or should I get a ride down to the hardware store to get a bolt that will fit the hole in my header to plug it?
I just need a temporary fix for the next few days to get too and from work...
Thanks for looking
Surfer Steve is offline   Reply With Quote
Old 02-19-2006, 12:41 AM   #2
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
would you be able to JBweld the allen key on just to remove the tap since it's ruined anyways?
crystalhelix is offline   Reply With Quote
Old 02-19-2006, 01:34 AM   #3
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
yea that is not a bad idea...
I was thinking of using JBweld to hold the probe in please but its only rated at 300 degrease.
I'll try the JBweld and let you know
Old 02-19-2006, 10:28 AM   #4
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
well that didn't work, the JBweld could not hold the set screw...
so now I'm down to eather exhaust wrap or a plug
Old 02-19-2006, 11:15 AM   #5
wrx2k4
Member#: 68632
2004 wrx/xtra hybrid
psm
I have the gruppe-s headers and had no problem If left with no choice i would go with the plug.
wrx2k4 is offline   Reply With Quote
Old 02-19-2006, 11:32 AM   #6
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
it has nothing to do with the headers every thing went fine installing them, but getting this dame EGT probe to work is a pain.
went to the hardware store and they don't have a 1/8 NPT to fit the hole all they have is one size too big. do you guys think if I use a stainless steel strap to hold the probe in place would work???
Old 02-19-2006, 03:36 PM   #7
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
No idea, I wasted all my brain power on the jbweld idea, lol
Old 02-19-2006, 04:07 PM   #8
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
I'm installing my egt today and have a quick question, sorry to hijack. The cylinder that runs the leanest is #4 (driver side [US] rear), correct?
Trunk_Monkey is offline   Reply With Quote
Old 02-19-2006, 11:39 PM   #9
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
I am trying the strap thing, seems to be working for now...
Yet another EGT problem. Prosport EGT. kirkeemonster Electrical & Lighting 28 09-29-2008 01:06 AM
EGT Problem or ECU Problem??? STUDAndring Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-29-2006 10:01 PM
Strange EGT problem. Blown cyl4 getting worse, or bad egt probe/wiring?? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-30-2005 09:32 PM
HELP..EGT problem forced4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-05-2002 04:04 PM
EGT problems...Shiv's Temp solution (long) Daidae Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 01-04-2002 11:12 AM
