Old 02-20-2006, 12:35 AM   #1
aren040
Member#: 74215
Silver-ish
Default 04 & 05 AP Questions
Hey guys and gals I have some questions for you guys and any help will be appreciated.
Now as for as I know the 04 AP can be run on the 05, but I have also read that sometimes this does not work and the AP ends up killing the car and the car stalls out or something. I was just wondering if anyone has any thoughts about this or has gone through it themselves.
The thing is that COBB even has different model numbers for the 04 and 05 so is there something different between the two APs? Or is it the maps that you run that have to be designed for a 04 or 05 and the AP does not matter?
The only reason I am asking is because I have a 05 and got a good deal on an AP for a 04. Thanks for any help.
aren040 is offline   Reply With Quote
Old 02-20-2006, 12:41 AM   #2
Rymep
Member#: 77812
2006 WRX TR
Just load it up with the 05 maps and *insert hand motion here* you'll be good to go.
Rymep is offline   Reply With Quote
Old 02-20-2006, 02:05 AM   #3
aren040
Member#: 74215
Silver-ish
So then I take it that there should be no problems...? Also has anyone tried running just a stg 1 realtime map without changing the base map at all? Is that even possible?
Old 02-20-2006, 12:28 PM   #4
Clark Kent
Member#: 75682
2004 WRX
this has been covered many times! just make sure you have the model year specific software for your car (04 or 05) and you'll be fine. why would you even want to just load the real time map? just load the basemap and enjoy the newfound power :-D
Clark Kent is offline   Reply With Quote
Old 02-20-2006, 01:00 PM   #5
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
Quack is offline   Reply With Quote
FS: 04 & 05-07 STI struts & springs, tophats, WRX rotors ten80 Suspension/Brakes/Handling 22 02-19-2011 03:42 AM
FS in Bothell: 04 & 05-07 STI struts & springs, tophats, WRX rotors ten80 NWIC Private Classifieds 20 03-08-2010 08:37 PM
FS: 04 & 05-07 STI struts & springs, Prodrive 02-03 spring, tophats boots nuts misc! ten80 Suspension/Brakes/Handling 21 09-02-2009 11:40 PM
04 4eat cobb ap questions??? red04eat Factory 2.0L Turbo Powertrain 2 02-22-2009 03:10 PM
How much do the 04 & 05 STi's cost in MD? Undepelo General Community 4 07-14-2004 04:33 PM
Message Board Statistics All times are GMT -4. The time now is 10:15 PM.
