Old 02-20-2006, 10:38 AM   #1
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Default What is the best way to make a cast in order to make a fiberglass mould?
What is the best way to make a cast in order to make a fiberglass mould? I had been thinking about using sculptors clay to make one side of the mould, then firing it to keep it the same shape, but size distortions may take place.
I donít have access to a plastic press, so thatís out of the picture.
Any other suggestions? Iím trying to make a cast of a panel piece on our cars so I can experiment with reshaping or restyling it without destroying a fairly expensive piece.
Thank you in advance!
Bry.
BrysImpreza is online now   Reply With Quote
Old 02-20-2006, 11:21 AM   #2
LastResort
Member#: 99289
First of all, what are you trying to do? You probably could make a wood sub frame, if it's a big item like a subwoofer enclosure. You might try to find some large pieces of styrofoam, cut/shape it, then cover it with Saran wrap. Cover it once with a thin layer and let it harden completely, then go to town.
LastResort is offline   Reply With Quote
My mom wants to send a monetary gift to someone in Germany - what is the best way? Cjchaps Off-Topic 18 12-14-2007 08:03 AM
What is the best way recalibrate MAF & tip-in? 69_Lex AccessPort 1 11-08-2006 09:43 AM
What is the best way to lost the last of the gut koolaid Off-Topic 16 11-23-2003 02:08 PM
what is the best way to send $$$ to hk? Benjamin Tang Vancouver Impreza Club Forum -- VIC 11 09-03-2002 12:48 AM
What is the best way to bleed the brakes? WRXwannbe Brakes, Steering & Suspension 4 10-27-2000 08:24 PM
