Old 02-20-2006, 08:53 PM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default I really need help and advice. (lopg)
ok, so my99LOB 2.5dohc blew the HG's and got kinda hot a few times. well mostly just once, but it was really bad. temp pegged for about 8miles coming back from mt. hood meadows. So i went out and found a 2000 2.5 sohc outa a 2.5RS with 8k on it that i wanted to swap in. Now the problem is some of the sensors will not transfer over. so i stopped by rallitek and they said to just to the hybrid thang, which i was really thinking about before i got the new motor. And now knowing that i have to do it and i'll need to replace the HG's on the 2000RS motor I almost might as well rebuild the HG's on my old motor. what do you guys think?
I'd love to just do the hybrid thing, but i feel bad about tearing apart this really nice 2.5sohc motor just for the shortblock. is it worth just redoing the HG's on my old motor as well as the valve cover gaskets and the rear oil plate and main seal. my orig motor has 100K on it and its already outa the car.
thanks..
-ben
spdracr00 is offline   Reply With Quote
Old 02-20-2006, 09:35 PM   #2
Skully
Member#: 48990
98 Impreza RS
RBP
I would just put new head gaskets on your current 98 engine. You can use the same head gaskes as a new STI engine. Call subaru and ask them if they updated the head gaskets for the 98 RS motor. It should be a 3 layer metal gasket. If they did not, then just order a set of gaskets for 04 STI. should be around $60 bucks for gaskets.
-Thomas
Skully is offline   Reply With Quote
Need help and advice SubyLoooon Southern California Impreza Club Forum -- SCIC 9 06-14-2008 04:04 AM
NEED HELP AND ADVICE ON LCD FLAT SCREEN TV's... WHICH COMPANY IS THE BEST.... NotoriousD Off-Topic 13 01-19-2006 11:24 PM
got Utec tuned: Need help and advice Brettnrs423 Engine Management & Tuning 7 09-27-2004 10:09 AM
Got car tuned: need help and advice Brettnrs423 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-25-2004 09:04 AM
I need help and advice SSFRACER Transmission (AT/MT) & Driveline 4 10-10-2002 02:04 AM
