Old 02-21-2006, 09:38 AM   #1
vadim
Member#: 31981
2003 WRX Sedan
Default What is the quitest Downpipe and exhaust?
Hey Everyone,
I'm sure this has been covered somewhere before, but there are way too much results for it. I'm also quite sure the quitest exhausts are horla hush and prodrive but what is the quitest downpipe? I'd like everything to sound stock and pass inspection. What could you guys suggest?
vadim is offline   Reply With Quote
Old 02-21-2006, 09:49 AM   #2
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
I would guess that the quietest downpipe would probably have to be a shorty downpipe with the stock 3rd cat. My shorty with a high-flow 3rd cat and stock catback isn't much louder than it was stock.
-Bryce
Carnot is offline   Reply With Quote
Old 02-21-2006, 10:50 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
That's why there are sticky posts at the top of each thread buddy, try reading them next time. To save you the effort, a downpipe will not do poop to what comes out of your tailpipe. EVERY downpipe will do the same which is next to nothing as to the level of noise. The only differences I've seen in all my testing/experience is that the TurboXS downpipe, due to its thin walls, puts more noise into the cabin than other downpipes. As to what comes out the back end, they are all the same.
Old 02-21-2006, 10:55 AM   #4
UM-WRXer
Member#: 44623
go with a full length dp with a high flow cat. some sort of 3" midpipe with a resonator and the sti genome axle back. That should free up some of the restriction as well as keep the stock sound levels.
UM-WRXer is offline   Reply With Quote
Old 02-21-2006, 11:03 AM   #5
Farnsrocket
Member#: 83567
08 Outback
Obsidian Black Pearl
+1 for an MRT TBE.
Cat in the DP, resonator in the Mid and good axleback muffler......quiet!
Farnsrocket is offline   Reply With Quote
Old 02-21-2006, 11:21 AM   #6
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
get a DP that has cast top part, as the thicker cast material will cut down on the turbo noises you are going to pick up with a downpipe.
you can find plenty of options for cat back that will reduce noise coming out of the tailpipe, I am completely catless and it is quiet, the turbo is very loud though.
I have catless, stock midpipe, and prodrive axleback.
loud when I get on it though
Old 02-21-2006, 12:41 PM   #7
shogun90
Member#: 54858
2004 WRX Premium
Platinum Silver
Default Maddad V2
I have the Maddad V2 downpipe with a gutted stock uppipe and a STI catback on a MY04 WRX. I was pleasantly surprised to find that it is no louder than with just the STI catback. The only difference is that if you have the radio off you hear a little more turbo noise, which is probably due to the gutted uppipe.
shogun90 is offline   Reply With Quote
Old 02-23-2006, 01:30 AM   #8
vadim
Member#: 31981
2003 WRX Sedan
if you have stock midpipe doesn't that mean you have a cat in there? So how can you be completely catless?
Old 02-23-2006, 01:54 AM   #9
MabWRX
Member#: 68787
I have the TurboXS Stealth-back (catless) mated to a factory STi muffler, and it is pretty quiet, passes PA state inspection (with a few cell fixes ) Prior to the STi muffler I had that system with the stock WRX muffler and it was even quieter. It is your best bet for performance/subtle noise. It does get loud when you beat on it however, but only engine/turbo noise from the 4inch DP.
-Marc
MabWRX is offline   Reply With Quote
Old 02-23-2006, 05:37 AM   #10
kellie00
Member#: 80965
2012 STI
I have to go in for the MRT dual tip myself, it doesn't sound much louder than stock, just deeper.
kellie00 is offline   Reply With Quote
Old 02-23-2006, 08:03 AM   #11
nsucdm_wrx
Member#: 39771
02 FPRed 2.5l WGN
Built heads ;)
I have the Borla "Hush". I put it in quotations because it isn't so hush. My opinion is it is quite a bit louder than the stocker. However I think it is a great sound. Low and rumbly, gotta love that boxer rumble Anything you do is probably only gonna make it louder and sound less stock, I say search for sound clips and choose the one that sounds the best to you.
nsucdm_wrx is offline   Reply With Quote
Old 02-23-2006, 10:19 AM   #12
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Here's a quiet DP.
WRX03 is offline   Reply With Quote
Old 02-23-2006, 10:35 AM   #13
Lachlan
Member#: 19470
1981 Brat GL
^ Sounds stock, passes inspection. Meets all your requirements.
Lachlan is offline   Reply With Quote
Old 02-23-2006, 10:49 AM   #14
Carnot
Member#: 34596
'05 WRX Wagon PSM
Originally Posted by WRX03
Here's a quiet DP.
Interesting. Is that welded to the pipe or secured some other way?
-Bryce
Old 02-23-2006, 11:10 AM   #15
REX8
Member#: 24038
-Bryce
He has the welding ground still on it!
Interesting choice though, hope it works out for you.
Old 02-23-2006, 11:40 AM   #16
Carnot
Member#: 34596
'05 WRX Wagon PSM
I saw that, but it could just be used to weld the heatshield back together, not necessarily to weld it to the pipe. Thanks for the insight though.
Fall and winter is comin up so what is the best mud and snow tire?? waitandbleed92 Tire & Wheel 6 09-04-2003 09:51 AM
What is the best downpipe for the STi? offset STi Forum Archive 31 08-25-2003 01:48 AM
what is the best downpipe & uppipe ? omega Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-28-2002 09:53 PM
Simple question: What is the BPM downpipe made of? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-25-2002 03:53 PM
what is the best downpipe in market sinassassin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-04-2002 09:49 AM
