Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 02-21-2006, 09:59 AM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Default Comprehensive Componet Weight table
I want to start a all inclusive thread on weight of items...Please only post if you know EXACTLY what each thing weighs that you are taking off the car and what the weight of the item you are replacing it with...
I am doing struts tonight...so I will post weight on each strut assy tomorrow...
I searched and found nothing except the thing that Sport Compact Car did on their 04...Oh yeah...Please try to make this thread as informative as possible...contribute if you can....
Bill
I compiled everything (mostly) from this thread
http://www.spryracing.com/FAQS/techn...ntweights.html
http://www.spryracing.com/FAQS/techn...ghtsMaster.htm
http://www.spryracing.com/FAQS/techn...ghtsMaster.xls
Download XL file, measure component in lbs to whatever accuracy, highlight addition by filling cells with Red, I will update as I can, send file to my user id at yahoo.com
That is all,
Justin
Old 02-21-2006, 10:06 AM   #2
fliz
Member#: 30342
From http://forums.nasioc.com/forums/showthread.php?t=661486
Originally Posted by dwx
So I was bored today and figured I'd weigh some of my extra parts on our shipping scale. Here are some of the results:
STI rear diff mount (dogbone) - 3
Rearmost propshaft protector - 3.2
Stock WRX propshaft - 22
V7 STI propshaft - 21.2
Samco turbo inlet tube - 1.4
Sparco Prodrive (Corsa) seat with Sparco bracket - 23.8
Wedge Engineering sparco sliders - 11.2
WRX throttle body w/no sensors - 1.8
EJ257 left hand block half - 27.8
EJ257 right hand block half - 25.6
WRX front bumper cover (cut up for a fmic) - 11
Prodrive oval tip muffler - 13.6
Wrapped Borla header - 11.8
TXS midpipe w/catless pipe - 14.8
TXS Downpipe - 9.1
Vishnu uppipe - 4.6
PE1818 turbo w/fittings - 13
C&R Aluminum radiator - 7.4 w/overflow bottle, 9 with SPAL fans
Stock radiator plus fans - 17.4
JDM power steering pump - 7.2
Stock WRX AC compressor - 11.6
Stock AC condenser - 4.8
Stock WRX Alternator - 11.2
Cruise control module+cable - 2.4
ECU kickplate - 2.1
Tanabe Sustec RR coilover, front - 17.6
STI pink trailing arms - 4.2
Ground Control Advance Design coilover w/caster plates - 12.4
Ground Control Advance Design coilover rear w/grpn mount - 15.2
WRX airbag - 2.8
WRX steering wheel - 3.8
Wilwood 2-pot rear caliper - 2.8
Stock TMIC - 8
Front WRX knuckle with hub - 16.8
Front WRX hub with wheel studs - 3.8
Front WRX control arm w/transverse mount - 10.2
Front underbody protector - 2.2
Stock WRX side mirror - 2.4
Back seat bottom - 8.8
Back seat top - 11.6
Starter - 6.8
TGV block - 3.8
Pedal assembly - 7.2
Stock WRX front axle - 12.0
STI V7 front axle - 15.8
Stock WRX rear axle - 12.2
Stock WRX 5MT transmission - 129.8
I have a ton of other stuff inclunding AL control arms, steering rack, stock suspension and exhaust pieces, etc. The 6MT is too heavy to put on the scale. I would say it's right around 200 lbs. I'll add to the list tommorrow.
fliz is offline   Reply With Quote
Old 02-21-2006, 10:38 AM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Excellent......thanks...
Originally Posted by AtomicRacer
Let's see.
Cobb cat'ed downpipe (14lbs)
Magnaflow titanium cat back (9lbs)
17x8.5 SSR's (15lbs)
shaved Yok Neova's 245/40-17
KW Coilovers (less than stock but I don't know how much)
light weight battery (13lbs)
4 gallons of gas
Removed all the crap from the trunk (spare, jack)
empty (almost) intercooler bottle
empty (almost) windshield washer fluid
no floormats
no junk in glovebox or center console
K&N cold air
That is all I can think of off hand.
-Paul
ps: Currently I am running with the heavy Whiteline front and rear bars but I am changing that shortly, going to a strano bar up front and either back to my Cobb hollow rear bar or no rear bar at all, depends on how the new rear springs work out. So that could be another 10-15 lbs off.
Old 02-21-2006, 11:34 AM   #4
davis10
Member#: 70011
Thumbs up
Great info thanks
davis10 is offline   Reply With Quote
Old 02-21-2006, 05:22 PM   #5
Zoinks
Member#: 35924
Anyone know what the stock WRX wing weighs? Looks like it would be light.
Zoinks is offline   Reply With Quote
Old 02-21-2006, 10:04 PM   #6
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Stock 05 Strut assemblys front...19.9 lbs ea
Stock 05 Strut Assemblys rear....19.6 lbs ea
Megan Racing coilovers with tophats...
front 13.8 ea
Rear 11.6 ea
Bill
Old 02-21-2006, 10:58 PM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i am gonna crosspost some stuff from another forum with the understanding that I will also take info from this forum to repost over there.... here goes... integrate whatever you need...
nhluhr is offline   Reply With Quote
Old 02-21-2006, 10:59 PM   #8
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Some stuff may be irrelevant to you (like certain creature comforts), but those putting together race cars may find the listed weights for those items very useful.
Stock Aero/Style Parts
Front Bumper Cap
Rear Bumper Cap
Side Skirt
STi Wing
Hoodscoop
Grille with emblem
Stock Brakes
Front Brembo Brake Caliper -
Front Brembo Rotor ----------- ~22 lbs
Rear Brembo Brake Caliper --
Rear Brembo Rotor------------ ~18 lbs
Stock Driveline
Transmission as a whole
Driveshaft (2 piece)
Flywheel
Flywheel & Clutch
Axles
Stock Engine
Pulley--- ~5-6 lbs
Intake Box (with accordian pipe) ----- 3.75 lbs
Turbo -------13 lbs
Intercooler--
Battery ----- ~32 lbs
Gas Tank--- ~47 empty
Stock Exhaust
Uppipe
Exhaust Manifold
Downpipe + Midpipe ------- 23.25 lbs
Resonator
Axleback --------- ~22-25 lbs
Stock Exterior
Optional USDM Fog Lights ---- ~5 lbs
Front Bumper Beam -------- ~28.5
Rear Bumper Beam -------- ~30 lbs
Sub Frame ---> 25 lbs
STi Trunk with Wing
STi Trunk without Wing ----- ~30 lbs with WRX Wing
Hood
Front Door
Rear Door
Front Windshield
Rear Windshield
Driver's Window
Driver's Window Track System
Passenger's Window
Passenger's Window Track System
Stock Interior
Stock mirror
Autodimming Compass mirror
Steering Wheel with airbag
Steering Wheel without airbag
Passenger Airbag
Armrest extension
Center Console
Radio
Subwoofer
Front Door Speaker
Rear Door Speaker
Floor Mats-------------------------- ~11 lbs
USDM Driver Seat with brackets and rails ----- 46.6 lbs
USDM Passenger Seat with brackets and rails - 41.2 lbs
Rear Seat
Door Panel
Carpet
Rear Seat belts
Glove Box
Driver's Side Dash (under wheel)
Dashboard
Steel Brace running under the rear seat bottom ----- 7lbs
Interior Paneling and bolts
Stock Suspension
2004
Front Aluminum Control Arm
Springs, Struts, and Stut Top Mounts
Front Swaybar (with bushings)----- 7lbs
Rear Swaybar (with bushings) ----- 8.5 lbs
End Links
Trailing Arms
Stock 2005
Front Swaybar (with bushings) ----- 7lbs
End Links
Trailing Arms
Stock Tires
2004 Potenzas ----- 27 lbs
2005 Potenzas ----- 27 lbs
Stock Wheels
2004 BBS 17x7.5 ---> ~16.5 lbs
2005 BBS 17x8 ---> ~17.0 lbs
Old 02-21-2006, 10:59 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Aftermarket Engine
<u>Pulley</u>
Autospeed Lightweight----1.5 lbs claimed
GFB Lightweight &amp; Underdriven----
Perrin Lightweight Not Underdriven----1.2 lbs claimed
Unorthodox Lightweight
<u>Battery</u>
Braille Super Lightweight Battery-----11.5 lbs claimed&amp;confirmed
Optima Lightweight
Dynabat Lightweight -------------------13.8 lbs (rebadged Hawker, Genesis)
Spoon
Aftermarket Exhaust
<u>Titanium</u>
STi S202 Axleback - ~ 7 lbs
Fujitsobo
Greddy Catback ---- ~10lbs alleged
JIC Catback
Kakimoto Catback
Magnaflow Catback
<u>Stainless Steel</u>
STi Sport Axleback
Borla Catback
Injen Catback
Aftermarket Exterior
JDM Fog Lights
JDM Bumper Beam ------ ~ 10.5 lbs
Aftermarket Suspension
<u>Sway Bars</u>
Cusco front
Cusco rear 22mm (with bushings) ------ 10.5 lbs
Zerosports front
Zerosports rear
Whiteline front
Whiteline rear
Perrin front
Perrin rear
Cobb tubular front ----- 5.5 lbs
Cobb rear
Hotchkiss front
Hotchkiss rear
STI V.7 front 19mm swaybar (with bushings) ---- 6.5 lbs
<u>Springs</u>
STi Pink Springs- ~26 lbs
Eibach Springs
Tein Springs
<u>Coilover</u>
STi Front Coilover ----- ~19 lbs each
STi Rear Coilover ----- ~19 lbs each
Prodrive Front Coilover
Prodrive Rear Coilover
Cusco Zero1 Front Coilover
Cusco Zero1 Rear Coilover
Cusco Zero2 Front Coilover
Cusco Zero2 Rear Coilover
Tein Front Coilover
Tein Rear Coilover
DMS Front Coilover
DMS Rear Coilover
Zerosport Front Coilover
Zerosport Rear Coilover
Ohlins Front Coilover
Ohlins Rear Coilover
Bilstein Front Coilover
Bilstein Rear Coilover
Front Coilover
Rear Coilover
Front Coilover
Rear Coilover
Front Coilover
Rear Coilover
<u>End Link</u>
<u>Trailing Arm</u>
<u>Chassis Stiffening</u>
STi Spec C rear Trunk Floor Bar - 3.5 lbs
Old 02-22-2006, 09:12 AM   #10
boxered
Member#: 61884
Suggestion: either agree upon a make/model scale for weighing items or list the scale used to weigh items for accuracy purposes.
boxered is offline   Reply With Quote
Old 02-26-2006, 06:47 AM   #11
STi-JDM
Top Scoob 023
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
Amuse R1 titan from midpipe until muffler = 12.3lbs (claimed 12.9lbs)
STi-JDM is offline   Reply With Quote
Old 02-28-2006, 09:50 PM   #12
BIGSKYWRX
Member#: 7958
09 GH B+
I'll add some (if they are repeated I apologize)- these are on a 50 lb postal scale- accurate to within 0.2 oz (or so it says) - it is very repeatable
WRX oe front rotors- 14', DBA 5000 two piece rotors 12.7 lbs
WRX oe rear rotors (266x10) - 9' 9oz, DBA 2- pot rotors (290x18)- 11' 3 oz
WRX oe front calipers w/ pads (2 pot) 13' 2 oz, FHI 4 pots w/ pads 12' 1oz
WRX oe rear calipers w/ pads (1 pot) 6' 11oz, FHI 2 pots w/ pads 4' 2 oz
WRX wagon front arm (complete) 9' 13 oz, GC aluminum front arm (complete) 8' 6 oz
04 fog lamps/brackets 1' 11 oz each
front dust shields/ hardware 9 oz each
oe intake silencer 1' 9oz
oe catted uppipe 7' 7oz, STi catless uppipe 5' 10 oz
oe catted downpipe 12' 13 oz
oe wagon front lateral link 2' 8 oz, 05+ aluminum front lateral link 1' 6oz
oem battery 32' 2 oz, Odyssey 680 (metal jacket w/ terminals) 15' 13 oz
oe wagon front bumper beam 27' 9oz, jdm bumper beam 12.2 lbs
oe wagon front sway bar 6' 15oz
oe wagon front sway link 8oz
RCE camber plates 1' 14oz
Old 02-28-2006, 09:52 PM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
woops- one more STi 21mm front sway bar 7' 13oz
Old 02-28-2006, 10:07 PM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
few more
WRX oe rear knuckle w/ hub 18' 6 oz
glove box weight 1' 13oz
weight under drivers side steering wheel 1' 10oz
day running lights module (underhood) 7 oz
rear metal strut top "noise isolators" 3 oz
STi underbrace 1' 10 oz
oe side cowl brace 11 oz, STi cowl brace 9 oz- 2 oz savings
Old 03-13-2006, 05:02 PM   #15
aspera
Member#: 7879
17.4 pound stock radiator/fans vs. 9 pound C&R radiator with Spal fans? I might have to do this mod before doing the cowl braces.
I have a question about the gas tank weight. What is included? Is that a wagon, sedan, or STi tank? IIRC, there are 50 and 60 liter kinds. Is it really 47 pounds empty?!?
aspera is offline   Reply With Quote
Old 06-29-2006, 10:23 PM   #16
BIGSKYWRX
Member#: 7958
09 GH B+
RCE brake ducts .4 lbs for the pair- a savings over the dust shields they replace
Old 06-29-2006, 11:06 PM   #17
hotrod
Member#: 14141
2002 Impreza WRX
www.oakos.com has a detailed component weight list on their website for the early generation USDM WRX (2002).
http://www.oakos.com/wrx/weights.htm
I was the source for the weights at the bottom of the page.
Larry
hotrod is offline   Reply With Quote
Old 06-29-2006, 11:31 PM   #18
BIGSKYWRX
Member#: 7958
09 GH B+
I always wondered who this anonymous person was - thanks
Old 07-03-2006, 07:34 AM   #19
aspera
Member#: 7879
Hi Larry! I just got back from your part of the country. Pike's Peak was a little different this year. There were only a few rally cars in the race, but still lots of Subarus in the parking lot at Devil's Playground.
THE, I repeat THE highlight for me this year was inspecting Nobuhiro "Monster" Tajima's Suzuki after the race. Okay, maybe seeing him chain drift and almost plow into the crowd was cooler. But it was like an alien spaceship, only cooler. That car should be studied.
One thing that made me smile was the foam under the front splitter. (I wouldn't even call it a splitter. That thing is a damn PORCH.) Anyway, the foam is painted black so scrapes show up as white marks. That lets the splitter get as close to the ground as possible to choke off airflow. It also lets the crew know how low it can go. Plus, foam is really light. (Duh)
The most beautiful part of the car is the CNC'd aluminum bulkhead between the engine and the transmission. That's pretty much the motor mount/tranny mount/crossmember all-in-one.
Anybody care to guess the size of the front tires?
Trivia: There appeared to be a plastic Subaru windshield wiper fluid bottle mounted to the right of the driver's seat. I think it might have been for wiper fluid, but I'm not sure. The car had a wiper shaft, but no wiper arm fitted for this race.
The wiper fluid bottle was right next to the oxygen tank.
Old 11-07-2006, 01:24 PM   #20
DuckStu
Member#: 124060
2004 WRX STI
Weights in this post were measured using a TIF 9010A digital charging scale, acurate to .5% (1.6 oz at 20 lbs). Reads to 110 lbs in 1/10 oz increments. Also reads in 1/100th lb increments.
2004 STI
Drivers SEAT W rails 46.480
Passanger seat W rails 41.360 lbs
Stock "U" shaped front SUBFRAME, 24.625 lbs (26.54 with bolts)
M1 subframe from Renick Motorsports, 13.93 lbs, (14.81 lbs with bolts) Saves 11.73 lbs
Small square front center JACKING PLATE 1.225 lbs
Turn In Concepts aluminum FENDER BRACES (pair) 1.34 lbs
Stock 04 STI fender braces (pair) 1.26 lbs
Stock CRANK PULLEY, 5.63 lbs
Perrin lightweight pulley, 1.256 lbs (saves 4.375 lbs)
Stock '04 STI WHEEL, (17x7.5 5x100 10 spoke BBS) 15.95 lbs
Stock '05 STI wheel, (17x8.0 5x114 10 spoke BBS) 19.48 lbs
Stock TIRES, Bridgestone REO70 with 9,000 miles ish 25.54 lbs
Pirelli P Zero Nero M&S with 70% tread left 225/45/17, 23.75 lbs
Continental Conti Extreme contact 225/45/17 new, 20.34 lbs
(NOTE THAT MY CONTI'S ON 04 RIMS WEIGH NEARLY 9.5 LBS LESS PER WHEEL, THAN STOCK '05 WHEELS AND TIRES)
Stock '04 STI front SWAY BAR with rubber bushings 6.985 lbs
Stock '04 STI rear sway bar with mounts, bushings 10.36 lbs
Perrin 22mm front sway bar w bushings 9.115 lbs
Perrin 22mm rear sway bar W Perrin mounts
Stock front ENDLINKS (pair w/ nuts) 0.815 lbs
Stock BATTERY 31.40 lbs
Deka lightweight battery model ETX20L (same as larger Braille 2015) 15.39 lbs (saves 16.01 lbs)
Stock FLYWHEEL with 50,000 miles on it 18.931 lbs
Stock USDM front BUMPER BEAM, 27.75 LBS
JDM front bumper beam, 10.535 lbs, (saves 17.215 lbs)
STI TOPHATS pair 4.505 lbs
STI pink STRUTS bare (no springs, pads, or top mounts)
Front 9.960 lbs
Rear 9.955 lbs
04 WRX strut bare, (no springs, pads or top mounts)
Front 10.10 lbs
Rear 9.838 lbs
KONI single adjustable inserts
Front 4.76 lbs
Rear 5.42 lbs
'04 WRX gutted housings, with Koni inserts installed
Ft 10.825 lbs
Rear 10.61 lbs
PRODRIVE SPRINGS
Front 5.16
Rear 7.225 lbs
All 4 = 24.77 LBS
Right rear KNUCKLE with trailing arm bushing, but no bearing or hub, 10.55 lbs
Much more to come.
DuckStu is offline   Reply With Quote
Old 11-07-2006, 01:32 PM   #21
Chiketkd
Member#: 71634
In hibernation...
Was this question ever answered? I'd like to know the answer as well.
I saw someone posted that a stock STI trunk w/ WRX wing weighs 30lbs.
Chiketkd is offline   Reply With Quote
Old 11-07-2006, 01:45 PM   #22
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Well since Chiketkd bumped the thread (albeit legitimately with a question), I'll add some data to it. I did some weighing on an analog bathroom scale when I swapped out my axleback last weekend and got the following data:
Stock 2006 WRX axleback exhaust: 21 lbs
Maddad Whisper 2.5" axleback exhaust: 19 lbs
Warp3 is offline   Reply With Quote
Old 02-03-2007, 10:25 PM   #23
BIGSKYWRX
Member#: 7958
09 GH B+
spec C/USDM STi 04-06 front aluminum arm w/ ball joint and rear bushing 8.9 lbs (one arm)
Old 02-05-2007, 03:07 AM   #24
Alex_Kors
Member#: 139773
Built by Andys Mom!
does anyone know:
how much the actual motor weighs complete with manifolds/turbo?
heater core/BS from under the dash?
complete stock wiring harness?
Alex_Kors is offline   Reply With Quote
Old 02-05-2007, 07:30 AM   #25
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Originally Posted by Alex_Kors View Post
does anyone know:
With all that....about 250 lbs...or so...
FS: Solid Oak Dining Table w/ 8 chairs and 2 leafs, end table, and sofa table grimwagon RMIC Private Classifieds 0 08-31-2009 03:32 PM
Brakes componets for most Subarus from 1990-present(pads, rotors, lines, fluid, BBKs) iON Performance Inc Suspension/Brakes/Handling 2 10-08-2004 11:16 PM
Rockford Componets question creature546 Car Audio, Video & Security 3 01-25-2004 12:31 PM
Found a site with comprehensive list of wheel weights. Cosworth Brakes, Steering & Suspension 2 12-07-2001 05:59 PM
Suspension componets 2002WRXvs2001 impreza Romanikque Brakes, Steering & Suspension 2 10-11-2001 06:35 PM
