Old 02-21-2006, 05:14 PM   #1
ataac_flat04
Member#: 19050
2005 Black STi
Happily rowing 6 gears
Question TGV tuning
An idea maybe... Is it possible to make the TGV's follow the same opening as the throttle? I was wondering if slightly closing the TGV's during light load/cruise conditions would have any effect on fuel economy. I think they can function similar to the intake runner "throttles" on some ford DOHC dual intake runner intake manifolds. They essentially open another intake runner at certain RPM/load for increased breathing. I think the SHO engine does this. Is there any reason why we couldn't do this on our engines, but use it for torque gains or mixture velocities down low?
Right now I'm satisfied with upper RPM power with the TGV's in place (I don't see the need to remove them). I would like the ability to be able to experiment with them to see if there is any gains to be had by messing with them. Anyone have any input? -Chuck
ataac_flat04 is offline   Reply With Quote
Old 02-22-2006, 12:24 AM   #2
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
What you are thinking of is a dual intake runer set up. short tunnels for high rpm hp and long ones for low rpm torque. all the nissan vq30 and vq35 have this as well as many other suche as the last eclipse.
Tuning to stay open is the best best as they do not open all the way and is just another restriction in the airway.
Joe
scoobdude is offline   Reply With Quote
Old 02-22-2006, 02:58 PM   #3
ataac_flat04
Member#: 19050
2005 Black STi
Yes that's what I'm thinking of. Basically our intake becomes a two runner with the TGV assembly. I realize it's best for more power to leave them open or remove them for that last little bit. What I'm proposing is being able to leave them partially closed when you don't need eleventy billion HP( making that small "torque" runner), like under cruise conditions (where many people spend a lot of driving time). I wonder what the effect of introducing "tumble" in other parts of the rev range would be, other than just at cold idle. Would there be any benefit there? Think of it in the same sense of AVCS tuning, changing cam advance/retard in different places can have a small effect on idle quality and power. I wonder if adjusting the TGV's can have an effect also. -Chuck
Old 02-22-2006, 07:41 PM   #4
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I think you missunderstood what i said. there is a butterfly on the engines with a DUAL runner design which transfer airflow to a short or longer runner depending on rpm. However we only have ONE runner so tuning the TGVs to stay open is all you will want to do.
http://www.nissanusa.com/vehicles/ModelAttributes/0,,124716|31005|,00.html
click on "variable intake"
then click on fiew for a flash demo of the two runners in action.
Again we only have one runner per cylinder.
Old 02-22-2006, 08:08 PM   #5
ataac_flat04
Member#: 19050
2005 Black STi
Smile
Yes, I understand we only have one runner per cylinder. We also have a butterfly valve in each runner that directs/constricts that runner essentially the same way that multi runner manifolds do, it just does it with one runner. I'm after the same benefits that multi runner manifolds have when that butterfly valve is closed. Not really concerned with runner length at this time.
What I'm asking is....It's in there for cold start idle enhancement now, can we use it to gain low end torque or fuel mileage? Not everyone wants just high HP, some of us want strong daily drivers that perhaps sacrifice some peak numbers for area under the curve and efficiency. -Chuck
Old 02-22-2006, 08:51 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
simple answer is NO. better gas mileage can be had by modulating the TB better. The valve will add power ONLY if taken out.
Old 02-23-2006, 11:43 AM   #7
ataac_flat04
Member#: 19050
2005 Black STi
Question
I'm not trying to pick a fight here. I'm glad you chimed in scoobdude, but I'd still like to be able to experiment and confirm your standing for myself. You stated there's no gain to be had, yet offered no evidence or experience that you have tried to mess with them on a Subaru. I would like to determine if the restriction of the TGV being less than open is bad or good, not just listen to theory.
Back to my original question, more directed to the ECU tuning guys with access to the code, are the TGV tables or code able to be modified? -Chuck
Old 02-23-2006, 12:21 PM   #8
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i don't think that there are any torque gains to be had from keeping those valves closed any longer than they need to.
if there were, after all, don't you think it'd be programmed into the ecus already? changing a few lines of code which control a tgv is a hell of a lot easier than adding avcs!!! if there were appreciable gains it would have been done.
that's my take on it at least.
Old 02-23-2006, 12:53 PM   #9
diablerouge
Member#: 81199
02 WRX sedan
under certain conditions it would be helpful to have the tgv's close slightly to increase gas velocity into the head. have you ever noticed that when you go wot in the 1k-2.5k rpm range that the turbo lags and you have no power, but if you lift just a little bit (10-20%) in that range, you spool much quicker and can feel the power difference very distinctly? that is a direct result of gas velocity through the intake tract. closing the tgv's just slightly would help when the velocity of the air in the intake is quite a bit less than optimal. just as in porting heads, a bigger hole (throttle opening) does not always mean more power. gas velocity is much more important than port volume.
that said, tuning the tgv's would be a waste of time if you had to decompile the code and then experiment with different algorithms to get it to work just right. just use your right foot.
diablerouge is offline   Reply With Quote
Old 02-23-2006, 02:19 PM   #10
ataac_flat04
Member#: 19050
2005 Black STi
diablerouge... that was exactly my line of thought on this... gas velocity. As far as algorithims, I was going to start simple, with the TGV's following the same opening as the throttle. Or if they have a map in the ECU like fuel or timing, then it would be as simple as changing values, assuming the map has more than 1 RPM column. Also remember that they direct air to a different part of the intake port, I'm curious what effect that has as well.
ride5000... I understand what you are saying, but also just because the engineers can do something, doesn't always mean they do. Stage 1 reflash nets as much HP as adding AVCS, yet they didn't do that either . Engineers aren't the bottom line when it comes to fine tuning.
Overall, I think it should be something that's investigated, along the same lines as AVCS tuning. We have the parts installed, is there any tweaking that can be done that would extract drivability. That's what I'm trying to say. -Chuck
Tuning Out Knock After TGV Install - How To Obsessive Open Source Reflashes 15 04-18-2008 11:16 AM
06 wrx tuning for TGV delete... 06Limited Open Source Reflashes 8 04-17-2008 09:43 PM
TGV Deletes, Sti pinks modded 850cc need help tuning? wrxdragger UTEC 4 05-14-2007 08:21 PM
TGV elimination options, Tuning for decent idle? downshift1 Engine Management & Tuning 7 02-17-2003 10:33 AM
