Old 02-21-2006, 04:31 PM   #1
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Question Any ideas of what's different between manual and auto ECUs?
I'm trying to figure out the actual difference between the automatic and manual ECUs in the WRX, specifically related to the MY02 WRX. I've previously done a manual transmission conversion on my AT WRX, including grounding the appropriate pin on the ECU harness. This prevented the car from getting communication failures with the TCU and started behaving just as an MT car should.
However, upon reflashing my ECU, I found that the car insisted on using the AT boost maps, not the MT maps. My ECU, an AF411, has identical CPU and TPU ROM to an AF421 MT ECU.
Is there a physical difference between the two ECUs that will inform one ROM that it is running on an AT car, and the other that it's on an MT car? Are the ECus physically identical? Can they be swapped between vehicles and behave just the same as the original ECU in the car?
That is, has anyone here actually used a factory automatic ECU in a factory manual car, or vice versa?
TIA,
/Andrew
Kha0S is offline   Reply With Quote
Old 09-07-2006, 01:30 AM   #2
Hawko73
Member#: 125238
G'day Kha0s, just wanted to say that you and I are like minded in that, I too want to convert my MY02 Automatic Impreza to have manual transmission. I have yet to do it however, I was interested to find out specific details such as the third pedal addition (clutch). Did you have any problems with the general conversion and so on. How did you go with the ECU MT mapping??
Hawko73
Hawko73 is offline   Reply With Quote
what's difference between LWG and HWG in ap2? EJ20_lee AccessPort 4 04-27-2008 06:55 PM
Any ideas what the difference in insurance would be between an sti and a legacy gt? sumfoo1 Off-Topic 18 07-11-2007 10:02 PM
Running out of gas - differences between diesel and gasoline engines? edkwon Off-Topic 3 04-10-2007 04:03 PM
90-94 Legacy Ecus Manual And Auto Paul V Engine Management & Tuning 2 03-07-2006 05:07 PM
Difference between manual & auto HAL1 Newbies & FAQs 11 10-05-2004 09:41 PM
