Old 02-21-2006, 06:04 PM   #1
Tullin
Member#: 66658
Default Deceleration noise problem
After installing ACT clutch and lightweight flywheel I get a grinding noise when I lift my foot off the throttle (I believe that the sound comes from the tranny). Is there an easy fix to the problem - e.g. gear oils that reduce the problem or..?
Soren
Tullin is offline   Reply With Quote
Old 02-21-2006, 06:35 PM   #2
MY00Forest
Member#: 75451
2000 Forester
black
is everything tightened properly, did you do the install yourself and what install method did you use
i did my clutch and flywheel and sti tranny mount all in one and when i was done i had some vibrating coming from some bolts on the tranny crossmember that needed to be tightened down
MY00Forest is offline   Reply With Quote
Old 02-21-2006, 06:41 PM   #3
Tullin
Member#: 66658
I had the local Subaru dealer doing the install. As far as I've read, the deceleration noise (gear box?) is a common problem, in particular with a lightened flywheel.
Old 02-21-2006, 09:54 PM   #4
MY00Forest
Member#: 75451
2000 Forester
black
hmm, which flywheel did you get and how much did it weigh. i have the streelight flywheel (ACT) the 14 lb one. havent really noticed the sound that you desribed but my car makes so many noises i tend to block them out
Old 02-22-2006, 07:33 AM   #5
salem
Member#: 56143
Fit is Go
I had an Act clutch w/ resurfaced flywheel installed a few weeks ago. Mine is making the same grinding sound while decelerating (mostly in 3/4 gear). Check out this other thread as well:
other thread
salem is offline   Reply With Quote
Old 02-22-2006, 04:18 PM   #6
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
folks, this is what LW flywheels DO.
you live with it, or you go back to heavy. those are your two options.
Old 02-22-2006, 04:35 PM   #7
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
100% correct! I am going back to standard flwheel as soon as I can!
Crazykev is offline   Reply With Quote
Old 02-22-2006, 04:59 PM   #8
Tullin
Member#: 66658
I just read a post where someone used NeoRHD gear oil to cure the problem. Is this the easy fix I am searching for. Also it seems that some people got rid of the problem by using a lower pressure in the rear tires (I will try that tomorrow).
Old 02-22-2006, 05:04 PM   #9
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Running heavier fluid helps, but won't get rid of it.
Don't run two different tire pressures. This noise isn't hurting anything, but running two different tire pressures will.
Old 02-23-2006, 06:50 AM   #10
salem
Member#: 56143
Fit is Go
I had my stock flywheel resurfaced. It makes the same grinding noise.
Old 02-23-2006, 08:12 AM   #11
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you took off too much metal then, making it lighter.
this "problem" existed on the early 02s. subaru "fixed" it by putting in heavier flywheels.
Old 02-23-2006, 04:59 PM   #12
qwkwrx
Member#: 56096
2005 WRX
psm
my flywheel is stock and my car does it
qwkwrx is offline   Reply With Quote
Old 03-12-2006, 10:47 PM   #13
daprez
Visiting NASIOC Timeout
Member#: 105645
2002 WRX Sedan
WRBP
Yup, my entirely stock, early '02 has done it for all 125k miles I have driven her. It hasn't turned out to be a real problem.
daprez is offline   Reply With Quote
Old 03-12-2006, 11:26 PM   #14
gc835
Member#: 78080
2001 impreza
red biatch
i got a new oem fw and clutch and i put in a sti tranny mnt and i have a vibration with a rattle at 3400-2800 in anygear on decel
gc835 is offline   Reply With Quote
Old 03-13-2006, 09:51 AM   #15
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Replaced stock clutch w/ Act Street and resurfaced stock flywheel two weeks ago. Same prob: a grinding/turning sound just below front seats (possibly) when I let the gas off and decelerate while in gear (3rd/4th/5th) in the 2200-3K range.
I don't think this is a problem with any specific make of any clutch, it is just a byproduct of having a sport clutch on stock bearings.
Valhakar is offline   Reply With Quote
Old 06-13-2006, 05:59 PM   #16
Porter
Member#: 486
2004 Forester XT
bug spattered
Subaru specifies a tire pressure differential between front and rear for a reason.
There has even been a TSB on this from Subaru. On any Subaru, the front tires should have ~3-4psi higher than the rear tires.
Porter is offline   Reply With Quote
WRX deceleration noise update TheWRX Warranty Issues & SOA Problems 429 05-12-2016 11:25 PM
Deceleration Noise Issues: Clutch Only. WRX Pilot Warranty Issues & SOA Problems 147 12-20-2002 08:41 PM
Deceleration noise problem THEMUSH Warranty Issues & SOA Problems 0 06-03-2002 04:46 PM
Deceleration noise similar to WRX liberty Warranty Issues & SOA Problems 1 02-13-2002 09:44 PM
Deceleration Noise Poll (popular demand) FargoRS Warranty Issues & SOA Problems 0 12-06-2001 11:43 AM
