Old 02-21-2006, 06:24 PM   #1
blindstuff
Member#: 100767
2005 Impreza WRX CGM
Enginuity Tuned Stg 2
Default Accessport compatibility.
Well, I tried Cobb customer support in order to find out if my car will be compatible with the Accessport but there response did not help me at all, so i will try you guys out.
I have an 05 WRX, but i live in Venezuela South america, I am not
clear if my vehicle is USDM spec or is produced with some diferences.
What do i have to look for in my car in order to determine its origin
and if it will be compatible with you accessport, im talking about maybe a ECU code or similar. I really dont want to buy something that has to be protuned and I know as much about tuning as a frog, so self tune is in no way possible.
TIA,
Stefano
blindstuff is offline   Reply With Quote
Old 02-21-2006, 06:37 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....you may have to lift the carpet on the passengers side floor and take the access panel out(3 bolts) and write down all the nunbers on the ECU and post them....that would be a start
Old 02-21-2006, 06:38 PM   #3
-Kevlar-
Member#: 82378
should be the same, arent yours left hand drive? there might be some differences but.... i dont know if its enough that it wouldnt work. what did Cobb say?
-Kevlar- is offline   Reply With Quote
Old 02-21-2006, 07:15 PM   #4
blindstuff
Member#: 100767
Yes they are LHD, so exactly my thougts...
Stefano,
I think you would know if your car was USDM spec or not. I do not think
we offer an AccessPORT that is compatible with your ECU at this time.
Cheers,
Justin
COBB Tuning
www.cobbtuning.com
Will do, have it up tomorrow or after tomorrow at the latest, my car is a the shop at the time and i dont know if i have time to go over there and check tomorrow.
Old 02-21-2006, 07:54 PM   #5
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Stefano,
Uncle Scotty is correct, finding out what ECU you have is key. It may also be important to note what octane gas you will be using to see if that is compatible also. (likely it will be) I also sent you a PM
Good luck,
Louis
www.dentsport.com
781-551-3399
dentsport is offline   Reply With Quote
Old 02-21-2006, 08:16 PM   #6
blindstuff
Member#: 100767
Thank you, read your PM, will get back to you as soon as I can.
95 Octane, city height ranges around 2700ft.
Old 02-21-2006, 09:28 PM   #7
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Originally Posted by blindstuff
95 Octane
Lucky!!!! (Napoleon Dynamite voice)
kingtut12 is offline   Reply With Quote
Old 02-21-2006, 09:57 PM   #8
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
95 Octane.
Do you know if that is RON or RON+MON/2? In the US we rate our gas as R+M/2 so your 95 could be higher than our 93 octane or lower say equivalent to our 91 octane for example. I will see if i can find out with a quick google search if you don't know. Hope this helps
Louis
www.dentsport.com
781-551-3399
Old 02-22-2006, 10:46 AM   #9
blindstuff
Member#: 100767
Originally Posted by dentsport
Do you know if that is RON or RON+MON/2? ... I will see if i can find out with a quick google search if you don't know.
Good luck with the search, i have been at it for the last hours...
This : Check out page 6 of this article makes me think it is 91 octane (RON+MON/2), Other articles then state "Número de octano comercial = (RON + MON)/2" wich literally translates into: "The comercial number for octane rating is (R+M)/2", therefore it should be 95 RON+MON/2 at the pump.
The unavailability of information in this country sucks...
I will keep looking after i get back from class...
Old 02-22-2006, 01:07 PM   #10
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Yes i'd tend to agree for two reasons. 1) Most countries to rate their gas in RON. 2) I also found this proposal to eliminate leaded gas at the pump in Venezuela amongst other countries....seems they propose to have 95RON by 2005 in unleaded form and 85 MON. That jives with your findings of ~91 octane (MON+RON/2)
http://www.cleanairnet.org/ssa/1414/...-36185_pdf.pdf
(Page 27)
Hope this helps
Louis
www.dentsport.com
781-551-3399
Old 02-22-2006, 10:17 PM   #11
blindstuff
Member#: 100767
To make things a little more confusing, i just got off the phone with the top tuner in the country, he claims gas is rated (m+r)/2, seing that he has a selftuned 1000hp supra and has been in business for over 10 years, i doubt hes wrong...
Edit: We only have unleaded now, the change was done at the beggining of 05.
Old 02-28-2012, 03:10 PM   #12
Cullis1
Member#: 311302
Did anyone ever figure out a right answer for this?? I just bought a 2006 WRX in Peru and am having the same dilemma
Cullis1 is offline   Reply With Quote
Old 02-29-2012, 11:16 AM   #13
Cobb Tuning
Member#: 4803
In our experience, the vehicles in South America are not US spec vehicles. Therefore, the AccessPORT will most likely not work on your car. Sorry for the bad news!
Ian
05' WRX Accessport compatible with a 05' WRX STI? grimwagon Rocky Mountains Impreza Club Forum -- RMIC 4 06-21-2009 08:19 PM
Accessport Compatibility liljon350 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-14-2008 04:15 PM
AccessPort Compatability hemoglowen AccessPort 2 07-12-2008 02:35 PM
Accessport compatability question Trigun001 AccessPort 0 08-07-2006 03:08 PM
CA: WTT Utec Rev. 3 for 02 compatible AccessPort Lemon Herb Private 'For Sale' Classifieds 25 12-20-2004 01:13 PM
