Old 02-21-2006, 06:25 PM   #1
J.Yo
Member#: 26383
Default Road Dyno spreadsheet
I pulled together a spreadsheet that can estimate the wheel horsepower and torque, using datalogs from TARI DL1. I read the forum file attachment FAQ, and it seems Excel spreadsheets are not a file format that can be attached to a thread. Anyone have a suggestion on how I can share this spreadsheet with everyone?
J.Yo is offline   Reply With Quote
Old 02-21-2006, 07:22 PM   #2
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
I sent you a PM. Send me the file and I'll host it for you. Will it work with ECuexplorer data logs too?
STirocket is offline   Reply With Quote
Old 02-21-2006, 08:24 PM   #3
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Please post it or would you mind emailing it to me? I'm definitely interested.
Don Arm is offline   Reply With Quote
Old 02-21-2006, 08:36 PM   #4
colby
Member#: 15918
08 STI/02 PGT WRX
DGM / Orange
can you zip the file and attach that? otherwise, you are welcome to post it on the openecu.org website.
colby
colby is offline   Reply With Quote
Old 02-21-2006, 10:53 PM   #5
J.Yo
Member#: 26383
I emailed the file to STirocket. I hope he will be able to host it for everyone to try out. The description and instructions are on the first sheet of the workbook. This spreadsheet can be used for any datalogging program that can log a time stamp, vehicle speed, and engine rpm. I think you'll understand when you see it. I included some sample data from a run I did the other day. It was a 2nd gear pull from 2000 rpm up until about redline. I'm sure there will be a fair amount of discussion about what I'm calling the Road Dyno compared to other dyno plots. Perhaps we should call it the Poor Man's Dyno (PMD). It should be a fun tool for everyone.
Old 02-21-2006, 11:02 PM   #6
STirocket
Member#: 84006
WRB with Goldies
Here's the file... Let's see if I can link to it on my web site.
Road Dyno
Give that a try. It worked for me, automatically downloaded it when I clicked on the link. Let me know if others have trouble and I can try something else.
Old 02-21-2006, 11:22 PM   #7
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
works for me.
Bishop is offline   Reply With Quote
Old 02-22-2006, 07:45 PM   #8
Jeramie
Member#: 56995
2016 WRX
WR Blue
Subscribe
Jeramie is offline   Reply With Quote
Old 02-22-2006, 07:53 PM   #9
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Were you in first gear or is the speed wrong? Try a 4th gear. On a closed course of course
rjrutzky is offline   Reply With Quote
Old 02-22-2006, 07:56 PM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Are the results better than DeltaDash's built-in road dyno?
The problem with Deltadash is the jaggies in the data that result from their crappy smoothing algorithm...
Example:
nhluhr is offline   Reply With Quote
Old 02-22-2006, 07:59 PM   #11
hondaeater69
Member#: 60324
so the formula basically extrapolates HP and TQ from time elapsed, vehicle speed and RPM?
Old 02-22-2006, 07:59 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
also, as a suggestion, why not have an input for the gear ratio, final drive, and tire diameter thus allowing you to calculate the vehicle speed instead of having to log it... this would give you faster logging and more datapoints for smoother plots.
Old 02-22-2006, 08:41 PM   #13
Wazazell
Member#: 84284
2006 Subaru WRX STi
WRB/Gold
since the data is in Excel you can add a trendline to the graph. I don't know if that's really what you're looking for, but it makes a nice smooth line. Here's a 6th order polynomial fitted to the HP curve. It would probably look a lot better if there were more data points.
I just tried out the ecuExplorer program! Man, it's awesome, it tells you everything! I'm really amazed by the info it can gather from the ecu. Can't wait till I get my car running again!
Wazazell is offline   Reply With Quote
Old 02-22-2006, 09:58 PM   #14
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Yeah.....this may get you in the ball park, but without gear ratios and final drive ratio, and even taking into account wind resistance, it's not going to be overly accurate.
This thing probably does the same thing, but accounts for the things I've mentioned.
http://www.charm.net/~mchaney/roaddyno/
I have one, however never got it to read engine rpm properly with the tachometer pickup.....and I haven't really found the initiative to tap into the ignition signal, but I'm sure if I did that, it'd work.
Legacy777 is offline   Reply With Quote
Old 02-22-2006, 11:02 PM   #15
STirocket
Member#: 84006
WRB with Goldies
I'm thinking the price of J.Yo's software and a Tactrix or AP cable is a better deal than $149.00... Even if you have to add some variables to improve the accuracy (variables not being too expensive on the open market).
Old 02-23-2006, 12:20 PM   #16
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
[email protected] mph
I am having trouble with the spreadsheet because I have multiple samples at the same vehicle speed. I am using EcuExplorer and speed is an integer - no decimal places. With my sample speed (not all that fast because I am sampling a lot of items) I get 2 or 3 samples at a given mph. That totally messes up the spreadsheet (no delta speed to calculate from).
Anyone else having the same problem?
IndyRacer is offline   Reply With Quote
Old 02-23-2006, 12:54 PM   #17
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
did you read the "READ ME" tab?
Quack is offline   Reply With Quote
Old 02-23-2006, 01:09 PM   #18
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
^ Now I did. With EcuExplorer, the vehicle speed samples aren't always 2 per second. I was getting 2 or 3 samples per mph. I tried deleting all but the first instance of each speed, but then I get very wavy results. Maybe I will try inserting decimal places into the speed values to improve the resolution.
Old 02-23-2006, 01:22 PM   #19
Jeramie
Member#: 56995
2016 WRX
WR Blue
Did you read the instructions. It says delete, the dups.
EDIT: Oppps suppose it too me to long to post, pesky "work" getting in the way.
Old 02-23-2006, 02:06 PM   #20
IndyRacer
Member#: 15439
2002 WRX Cobb Stg 2
Okay - I found a way to create smooth plots from the full data set. Try this:
1. Plot speed vs time for the full data set that you want to use for road dyno (include all duplicate speeds) using Excel's x-y chart option.
2. Fit a 3rd order polynomial trendline to the speed data.
3. Use the coefficients from the trendline to create new speed values as a funtion of time (time samples from your data set). This will produce vehicle speed values with much more resolution (and no duplicate values)
4. Use the new speed values along with all time and rpm data for the road dyno calculations.
I did this and was able to produce the following graph from a 3rd gear pull:
The graph I produced using the receommended method of deleting the duplicate speed values was very wavy. This new method eliminated the waves.
My next step is to try to automate the process of generating the new speed data within the spreadsheet. If I can get that done, I'll let you know.
Old 02-23-2006, 02:15 PM   #21
Jeramie
Member#: 56995
2016 WRX
WR Blue
Can you post what you have? If needed I can host.
jcavanaugh at computercablestore.com
Old 02-23-2006, 02:23 PM   #22
J.Yo
Member#: 26383
Default Poor Man's Road Dyno Rev 2
I just wanted to let everyone know that I revised the spreadsheet to include an "rpm only" based calculation. Thanks to nhluhr for the suggestion. I have asked STirocket to host the new file, and I will post an explanation soon after. I really like what Indyracer did, and I think we might be able to utilize that in a future revision.
Old 02-23-2006, 02:29 PM   #23
Freon
Member#: 88322
2009 BMW 135i
There is always a limitation of the speed of the logging and accuracy/precision of the speed or RPM log. I long ago gave up on UTEC logs, but may try again with NBS's fast-speed enabled logger.
I created several windowing function to smooth data when I was playing with this for my SMT-6 logs on my last car. Same problem there, not fast enough for how inaccurate the RPM logs were. If RPM jumps around and doesnt seem to increase smoothly (if you see it go DOWN between two log points under WOT for instance), you'll either need to fix it, or log at incredibly speed.
If some people want to post a few good Tari logs with ONLY time, RPM, and speed, I'd like to experiment with two different models for calculating this. One is to solve for HP via delta of total kinetic energy, the other is to solve for torque by calculating the forward force. I know exactly how to accomplish both, with gear ratios and everything, I just need a few good logs to play with.
Freon is offline   Reply With Quote
Old 02-23-2006, 04:50 PM   #24
Freon
Member#: 88322
2009 BMW 135i
There is no reason an equal or better plot than Deltadash cannot be created by a log generated from Tari. They both have access to the same information, gathered at the same speed and from the same ECU. The data speed and quality are the limitations. The models are the easy part.
Old 02-23-2006, 05:25 PM   #25
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I have horsepower/torque calculations in mind when coding my fast-logging. I actually spent about 4 hours today going over the fast-logging code. The UTEC is not as constant as most people probably think it is.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Hand fabbed 30R Road Dyno Spreadsheet TDagen Proven Power Bragging 15 07-12-2009 06:21 PM
Road Dyno Spreadsheet mpggomd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-23-2007 11:31 PM
Home Dyno/Road Dyno Thumper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-20-2002 09:23 PM
Road Dyno Opinions Stavros g Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-24-2001 08:56 AM
Road Dyno? Anyone heard of this? Necromancer Bay Area Impreza Club Forum -- BAIC 4 02-15-2001 12:42 AM
