Old 02-21-2006, 06:30 PM   #1
Discjoshie
Member#: 43717
2000 2.5 RS
Default EJ257 Shortblock in RS
I am thinking about swapping in an EJ257 block and internals into my 2000 2.5RS for boostability (supercharger....). Can I directly swap this in, reusing my stock intake manifold, SOHC heads, accessories, etc. Also, I am going to buy an upgraded clutch and I wanted to be clear what sort I would need; one designed for the RS or does the block require a pull-style clutch as if I were buying an aftermarket clutch for an STi? (maybe a stupid question). Any info you could give me would really help me get started, this could be a very exciting build. Thanks.
Discjoshie is offline   Reply With Quote
Old 02-21-2006, 06:35 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Direct bolt on, and the clutch is specific to the tranny, not the block. Legarus...
Old 02-21-2006, 07:35 PM   #3
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
What you might need to look at is the final compression with the swapped.
west_minist is offline   Reply With Quote
Old 02-21-2006, 08:14 PM   #4
Discjoshie
Member#: 43717
2000 2.5 RS
I figured that was the case, Matt. How could I find out the final compression with this block/head combination?
Old 02-21-2006, 08:15 PM   #5
west_minist
Member#: 53451
w/ AVCS Silver
I guess a final compression test should do it.
Old 02-21-2006, 08:36 PM   #6
Discjoshie
Member#: 43717
2000 2.5 RS
I would assume so, thanks. I was wondering if someone already knows the compression from experience with this block so I would know going into the project.
Old 02-23-2006, 10:16 PM   #7
legacy2003
Member#: 38338
2003 Outback Sdn H6
i want to say the cr would be 7.8:1.
legacy2003 is offline   Reply With Quote
Old 02-23-2006, 10:19 PM   #8
west_minist
Member#: 53451
w/ AVCS Silver
Why so low?
Old 02-24-2006, 11:16 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
I am not sure that it is actually that low. IIRC, EJ205 heads onto an EJ257 block is 8.5 or 8.6:1. The Ej25 heads have a few more cc's than those heads, so I would GUESS around 8.2 or 8.3:1. I could caculate it all out and give you a dead-on number but I am lazy and know a number of guys running the set up, so know that it works, and that's enough for me...
Old 02-24-2006, 11:52 AM   #10
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Ding
http://forums.nasioc.com/forums/showthread.php?t=601588
EJ257 with SOHC heads approx 8.4:1
Old 02-24-2006, 03:24 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
FTW
Old 02-24-2006, 05:20 PM   #12
Discjoshie
Member#: 43717
2000 2.5 RS
Nice find. Thanks.
Old 02-24-2006, 05:28 PM   #13
west_minist
Member#: 53451
w/ AVCS Silver
Out of curiousity, would you have to use the EJ25 gasket or you can change to the STI gasket?
I want to do a swapped in the future with a EJ20 NA head that was on a 10.8:1 compression to the EJ257. To be honest, like how the car feel, sometimes I swear that I am over 11.0:1. JDM makes a simlar engine with 11.5:1, so I do not know if that would be more now but what gasket would I have to use?
Also, would the swapped affect cam timing due to the compression change?
Old 02-24-2006, 05:38 PM   #14
Master2192
Member#: 83254
98 2.5 RS
04 WRX
In the thread I linked it recommended using the STI headgaskets. I think it will change the cam timing but I am not sure in your swap. I know if you use the thinner SOHC gaskets on the 98 DOHC engine it bumps the compression up to approx. 10.5:1. This is how my RS is and I believe it throws off the timing on the left side by 3 degrees, but to verify that I'd have to find the thread again.
Old 02-24-2006, 09:17 PM   #15
Discjoshie
Member#: 43717
2000 2.5 RS
How does one correct for the timing change? Does anyone know if there is a change when used with the SOHC RS heads?
Anyone know of a working EJ257 shortblock in the area? blacklist NESIC Private Classifieds 16 05-05-2009 03:58 PM
NEED HELP!! .Doing a USDM EJ257 shortblock in my 04 WRX. BallzToTheWallz Built Motor Discussion 6 08-31-2007 11:11 AM
FS: MA - EJ257 Shortblock/SOHC RS Heads/RS Intake Manifold/Alt & PS Aphex28 Engine/Power/Exhaust 21 07-30-2007 01:23 PM
FS/FT: in MA. 1999 RBP RS with JDM Swap Motor/EJ257 Shortblock. XyKo Private Vehicle 'For Sale' Classifieds 13 05-01-2007 05:47 PM
ej257 shortblock in a WRX.. questions. PeteDucati Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-21-2004 09:59 PM
