Old 02-21-2006, 07:56 PM   #1
DriveFast
Member#: 86939
2006 GTI
Default Nylon Tubing OK in the Engine Compartment?
Can i use this nylon tubing in the engine compartment? I am afraid of water, salt, fuel, gas, getting on the tube and destroying it. This is Sunpro automotive nylon tubing. I would use it for boost gauge.
http://www.sunpro.com/product_detail.php?pid=16358
DriveFast is offline   Reply With Quote
Old 02-22-2006, 11:45 AM   #2
Scoobie Noobie
Member#: 65498
Scoobie Noobie is offline   Reply With Quote
Old 02-22-2006, 11:55 AM   #3
05wrxmatt
Member#: 87169
2007 STI Limited
My Autometer boost gauge came with that kind of tubing. It sucked big time. First off, the tubing wants to stay coiled, so its a bitch to route throughout your car. Second, if you bend it too much, it will kink, and you will have to replace that section of tubing.
I went to a hardware store and got a tee barb fitting, and bought a brass barb that fit onto the back of the gauge. I ran some vacuum line between the tee at the BPV and the back of the boost gauge.
Just my $.02
05wrxmatt is offline   Reply With Quote
Old 02-22-2006, 04:09 PM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
that tubing will be fine, provided you install it properly. it is rigid (which is ideal for a pressure signal line) and very abrasion resistant.
Old 02-22-2006, 04:13 PM   #5
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Make sure you route it away from heat sources.
Mmmmmmm. Melty..
VpointVick is online now   Reply With Quote
Old 02-22-2006, 05:58 PM   #6
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I use nylon tubing from home depot for my Water injection. It sustains over 100psi and i've never had any problems. It is very sturdy and inexpensive!
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 02-22-2006, 07:22 PM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I've had that kind of tubing in there for 4 years now for my boost gauge, and no problems. You do need to be careful not to kink it as you are instaling it.
wrxdrvr is offline   Reply With Quote
What's the best way to clean the engine compartment under the hood? rabbit92x Car Care & Detailing 4 11-27-2008 09:06 PM
Tire foam in the engine compartment?!?? plunk10 Interior & Exterior Modification 5 06-19-2006 04:03 PM
Knocking in the engine compartment when slipping sedonawrx General Community 17 01-11-2005 02:34 PM
oil in my engine compartment boka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-26-2002 06:50 PM
Washing the engine compartment Overtime General Forum Archive 4 07-22-2000 06:46 PM
