Old 01-04-2001, 10:12 AM   #1
GTMAN
Member#: 480
1998 Legacy GT Wagon
Question How do get softer ride?
Is there a way to get a softer ride with Eibachs (or any other perfromance springs)? I don't really care about any height increases that would come about in the process of softening the ride of the springs.
I'm running the Eibach/AGX set at 1/1 and still seeking for the softer ride. May be softer tires.....?
But I would like to have the choice of taking out myself whatever mod to take it back to stiffer ride.
Thanks,
GTMAN
GTMAN is offline   Reply With Quote
Old 01-04-2001, 10:57 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
the spring rate is not necessarily what dictates the softness... it's all in the dampening...
the dms is fully adjustable... before i hosed my car.. i had just adjusted the rebound on the front of the car and the ride got even better!!!
if the agx's are on the softest setting... likely that's as soft as you are going to be able to get it without swapping your suspension out...
j. www.subiegal.com
Old 01-04-2001, 02:50 PM   #3
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
Man! Softer than the 1/1 setting? What Eibachs are you running? I though the Pro-Kits with the AGXs on 2/4 was kinda plush, actually.
I'm with Subie Gal. I think you might be out of luck on this one, unless you run some WS-series Blizzaks at about 32 psi. Soft and squishy, baby!
Just out of curiosity, why the need for a softer ride?
Kevin
gtguy is offline   Reply With Quote
Old 01-04-2001, 07:03 PM   #4
GTMAN
Member#: 480
Post
Well, the body is getting old...can't be a young hardbody stud forever you know . Noooo... Well after driving my sis's 99 Galant 3.0V6, one softly sprung beast of a car, long distance, if feel as though that I would fatigue alot more with my wagon. Its nice to not feel the road so much in long 3 hr straight cruises. I can feel almost every single bump, crack....and I hate potholes...feels like I need to avoid them all the time. On the big dips, they're primo, but city driving with some not so great roads....pretty uncool with the old folks.
BTW the Mitsubishi V6 is very nice, at 110mph, it still had plenty juice....looks like a ~140mph car easy. But driving the subie is more like playing an arcade game.
Anyways, I really need to go sit in one of your cars to get myself calibrated to what the definition is stiff/soft is.
Here's a thaught,what is KYB messed up the sticker/knob or valving placement.....nah...could they?
Gtguy, whats your setting on your KYB's if you would want to make it ride like stock?
GTMAN
Old 01-05-2001, 01:09 AM   #5
gtguy
Member#: 2184
Post
Dunno. I've never tried to get a stock feel. I still have mine on 2/4 though, since I'm running the stock springs.
This is a thought. Do you still have your stock GT wagon springs? That's sure to soften things up, if you do. You'll also go back to the stock ride height, which will help in the plushness department.
I would imagine that the stock springs and the AGXs set on 1/1, should be just about what you're after.
Kevin
Old 01-05-2001, 10:33 AM   #6
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Springs and strut characteristics must be be matched to compliment each other, putting in a softer spring won't necessarily give you a softer ride since you may be compressing the strut faster, and thus making it stiffer. That's why you generally buy a suspension package, not just individual components.
If you have the struts on the softest setting, and are still not happy, you probably have springs that are not very well matched to the struts. I'd call a good suspension shop and see what springs they recommend for your strut kit, or just go back to stock all the way around. My stock outback is pretty cushy.
You could also try a tire with more sidewall. Anything you do to soften the ride, BTW, will compromise handling, but you probably already know that.
gavin is offline   Reply With Quote
Old 01-05-2001, 10:54 AM   #7
Scottie
Member#: 2080
06 Impreza Wagon
Red
Post
Digressive(sp) dampening.
I think low speed dampening (speed meaning shock/strut shaft velocity) has the greatest effect on handling and high speed dampening the greatest impact on subjective harshness. Unfortunately, with linear dampening, any increase in low speed dampening means an increase in high speed dampening as well.
I think the AGXs are somewhat linear in their dampening.
Digressive dampening somewhat addresses this issue. At lower velocities, the slope of the dampening force vs velocity curve is steep, but as the velocity increases the slope of the curve tapers off. This gives you good dampening down low for handling, yet the high speed dampening stays within reason.
Bilstein is known for its' digressive valving. The Prodrive GT suspension kit available for the Impreza use Bilsteins, and many owners of that kit claim that the ride quality is as good as, if not better than, stock yet still provides significantly better handling. Unfortunately I'm not aware of any Prodrive kits for the Legacy.
The only thing I've seen for the Legacy that uses Bilsteins is the SYMS/Bilstein kit, but that is likely tuned for Japanese roads and Japanese taste. Are their any Legacy owners who have this kit?
The other problem is that a lot of suspension vendors don't provide any dampening curves. The most you usually get is the dampening rate at one particular velocity, so it's really hard to know or even get a rough idea of how the subject ride quality of one set-up may compare to another or stock without actually trying it.
Your cheapest route would be to revert back to stock. If you have two grand or so, then something adjustable like the DMS Gold might be an option. I believe their adjustment has 21 positions. The Gold however, just became available for the Impreza, I'm not sure if they have it yet for the older or newer Legacies. I'd send Dave Clark an Email.
Scottie is offline   Reply With Quote
Old 01-05-2001, 11:29 AM   #8
GTMAN
Member#: 480
Post
Well, I really don't want to revert back to stock springs coz I'll loose that tight look and gain the large lean angles around the turns.
I agree with the theories (sp) mentioned.
Maybe I need to turn the struts up to 4/8 and other combos and drive on them for a while...then go back to 1/1 and see how it feels. Sometime you get used to one thing all the time...need a change to get things into perspective. May be I need to a ride in some ones tuned car to recalibrate myself.
Thanks for you inputs guys and gal.
GTMAN
Old 01-06-2001, 12:01 AM   #9
gumball
Member#: 1209
Talking
I've got stock springs w/ AGX on my GT sedan and its very close to stock at 1 Front / 2 or 3 rear.
gumball is offline   Reply With Quote
how do you make ride less bumpy (Swift springs on GR2s) qualityracer Brakes, Steering & Suspension 35 05-21-2009 09:34 AM
how to get a softer ride afstevie68 Brakes, Steering & Suspension 7 08-24-2005 09:44 PM
How do get a hold of Subaru rep for warranty(CA)? Drews_WRX Warranty Issues & SOA Problems 2 07-05-2003 02:11 PM
How do get a hold of ALAN from ASR? Stranger Bay Area Impreza Club Forum -- BAIC 3 02-25-2002 11:49 PM
'98 Turbo; How do get the EGT's down? SYMS GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-29-2001 04:21 AM
