Old 02-22-2006, 10:54 AM   #1
redrr
Member#: 108221
Default USDM STI shortblock USDM wrx heads. ?s
I have a brand new usdm sti shortblock that i am going to put in my 02 wrx. i am going to use the wrx heads. the first thing that i noticed is that the sti block has a port of some kind coming out of the top of the block. it would be under the throttle body if the intake manifold was on. Is this a coolant passage? do i need to use it? or can i just plug it? What else am i going to need for this block swap? i have thicker cometic head gaskets already and arp head studs. what else?
redrr is offline   Reply With Quote
Old 02-22-2006, 11:40 AM   #2
06Rex
Member#: 105209
2006 WRX
You might want to move this thread to 2.0L or 2.5l youll have more peps see it
06Rex is offline   Reply With Quote
Old 02-23-2006, 06:55 PM   #3
legacy2003
Member#: 38338
2003 Outback Sdn H6
i can answer this, as i went through the same thing. the 2 ports coming out of the top of the block are for breather hoses that would normally run into the avcs heads. they spit oil. since you don't have avcs with the wrx heads, you can do one of 2 things, either a) cap the ends of them, or b) modify the black ports on the top of the heads where the breather hoses on the wrx originally go in to accept 2 hoses. that's what i did and it worked great.
cometic head gaskets are a good idea to lower compression to 8:1 like you said; while arp studs aren't necessary it's not a bad idea. i was using both.
get engine management or else your setup will go boom.
sounds like you have what you need to have a good running motor. do not use a td04 on it though (wayyy too small).
any other questions? i have lots and lots of experience with the hybrid motors, so pm me.
legacy2003 is offline   Reply With Quote
Old 02-24-2006, 08:09 PM   #4
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
so with this swap you want to keep the compression around 8:1 (w/cometic head gaskets)? not the 8.6:1 (w/stock ej257 gaskets)
StarDogChampion is offline   Reply With Quote
new sti shortblock with wrx heads. COMPLETE thebasicnecessities Engine/Power/Exhaust 5 02-01-2010 08:55 PM
STI shortblock, 2.0 Heads, 04 WRX SilverSpool Subaru Conversions 11 10-28-2007 10:16 PM
USDM STi shortblock with WRX heads... couple questions vipernj Subaru Conversions 18 02-27-2006 05:12 PM
WTT JDM v7 shortblock for USDM STi shortblock werkInProgress Private 'Wanted' Classifieds 2 05-23-2005 05:32 PM
USDM STi Shortblock, STi Heads kaos200 Private 'For Sale' Classifieds 33 10-25-2004 05:56 PM
Message Board Statistics All times are GMT -4. The time now is 11:52 PM.
