Old 09-23-2001, 06:56 PM   #1
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default Check Engine Light
Well, I've finally seen the dreaded CEL. Must admit to running the GT Wagon to 112mph for about 5 miles on a light traffic night last week on South Bound I-5. Won't go into the reasons why at this point. The car was running flawlessly when I noticed the CEL and immediately slowed down and checked everything under the hood a couple of miles later at a fuel stop. Everything was OK, with no overheating or low oil level, coolant, etc. I did an ECU reset that night at my destination and have had no more warnings over the 200 mi home or 200 more since. Any ideas?
Car has 95K-miles on it, running Mobil1 and NGK plugs. Think I may have just overheated the CAT Converter or something running so hard?
Glenn O
nuburu2 is offline   Reply With Quote
Old 09-23-2001, 09:17 PM   #2
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
For the last two years, I'd had a problem where fast highway running on a cooler night (early fall) would cause the CEL light to come on after 5-10 miles. Code always read EGR; wouldn't happen but two-three times a year. Finally I replaced the EGR solenoid ($170 or so) and it hasn't happened since. I think I had 70k miles when it started and ~100k miles when I replaced the solenoid. Have a friendly dealer read the code and see what it says.
rrubel is offline   Reply With Quote
Old 09-23-2001, 11:39 PM   #3
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Default CEL
Thanks rrubel, If it recurs I'll live with the CEL til I can get the codes out of it. Just couldn't stand running a couple hundred miles home with that light telling me something was wrong!
Glenn O
Old 09-24-2001, 09:26 AM   #4
98legacygt117
Member#: 8386
1998 Legacy GT 2.5
Red
Check engine light........ I got that a couple times last winter. I checked the engine...made sure it was still there . It was... heheh Usually when that light goes on from what I heard its dirty injectors or a sensor thats shiznitting out.
98legacygt117 is offline   Reply With Quote
Old 09-24-2001, 11:25 AM   #5
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default CEL
@ over 120mph no check engine light, but at an auto-x event it popped up and the engine temp was high reset the car that night and the next day fine and flawless!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 09-25-2001, 12:14 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
how do u get rid of a CEL?
ben
Benjamin Tang is offline   Reply With Quote
Old 09-25-2001, 08:31 PM   #7
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
See my post in this thread: http://www.i-club.com/forums/showthr...threadid=94998
Old 09-26-2001, 11:46 PM   #8
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default HOW TO GET RID OF CEL
I got home late around 8pm...popped my hood ...took off the neg. connector to my battery... went inside ...ate dinner...watched TV...slept...woke up...did my thang...went back outside ...connected the neg. connector back to the battery...started my car...went back inside...ate breakfast...went back outside and saw that the engine temp was normal ... turned the engine off ... kissed my wife...closed the garage...started the car back up and went to work!!!
If that wasn't the right way...I don't care...all I know is it worked!!!
CRAZY KEN
Old 09-27-2001, 09:27 PM   #9
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Default Re: HOW TO GET RID OF CEL
CRAZY KEN
Well, that's MOSTLY the correct way. I think you forgot to brush your teeth, twice. That's a sure invitation for the CEL to come again soon.
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
