Old 02-22-2006, 01:28 PM   #1
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
Default Question about my Perrin CEL Fix
Just received it for my 05 STi, as I am going to install a race TBE.
I didn't realize, but the Perrin CEL fix is really a O2 simulator.
So I'm confused on how this works. I'm keeping my stock O2 sensor, but just relocating it from the factory position. (using the bung location on the TurboXS TBE)
Isn't this Perrin CEL fix supposed to 'act' like a factory O2 sensor by fooling the computer in thinking that the O2 sensor still works?
Can someone explain why I would need this O2 sim if I'm using my factory O2 sensor? (other than preventing the P code)
Vampyr is offline   Reply With Quote
Old 02-22-2006, 01:52 PM   #2
AaronWRX
Member#: 7194
2011 997.2 Turbo
search for mechanical o2 cel fix and dont even bother with that perrin fix as it only simulates the o2 and not the heater element.
AaronWRX is offline   Reply With Quote
Old 02-23-2006, 07:51 PM   #3
Vampyr
Member#: 31761
2005 sold! STi
mechanical?! Heater element?!
First off, 05's can't use mechanical (from searching on here).
Second... I know it simulates the O2, my question is, why would a O2 sim be considered a CEL fix?!
I've always understood that you use O2 sims when you are unable to use a stock O2 sensor (due to no bungs to put it in).
Anyone else have some resourceful information for me?
Old 02-23-2006, 10:35 PM   #4
Gethin
Member#: 2998
the readings the rear o2 sees when you remove the cats are different, so you need the electrical fix to fool the ecu into thinking all is well with the rear o2. The mechanical fix does the same by taking the o2 out of the direct exhaust stream to achieve the same thing.
Gethin is offline   Reply With Quote
Old 02-23-2006, 10:44 PM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
You are wrong about the mechanical fix.
Old 04-10-2006, 04:12 PM   #6
Vampyr
Member#: 31761
2005 sold! STi
Ok.. update to this thread...
I finally installed my TBE.... and after about a day of driving around, I finally got the CEL with the cruise light blinking at me.
My question is... for now, can this be ignored?
I'd like to wait to put my Perrin CEL Fix in over the weekend.
Old 04-10-2006, 05:43 PM   #7
AaronWRX
Member#: 7194
2011 997.2 Turbo
you can ignore your CEL all you want. of course you may have another more serious issue pop up and not know it so it's best to get that fixed as soon as possible.
it's too bad you didnt listen to me. you could have easily installed the mechanical fix while you were installing your exhaust and been done with it.
now you get to
-waste money
-waste time by getting under the car again
-hack up your wiring for no good reason
Old 04-10-2006, 11:27 PM   #8
Vampyr
Member#: 31761
2005 sold! STi
now you get to
-waste money
Hey now.. you ignored me first.
I just asked how the mechanical fix works. I understand that splicing the wires will basically allow me to fool the car in thinking the O2 works fine.
So I'm still asking, what is it that the mechanical fix does? My O2 senses that my Catalytic Converter isn't working... How does a mechanical O2 fix change that?
Nonetheless, thanks for the advice Aaron, but I already bought my Perrin CEL Fix.
Old 04-11-2006, 03:44 AM   #9
AaronWRX
Member#: 7194
2011 997.2 Turbo
here is the thread. not too late to sell the perrin:
http://forums.nasioc.com/forums/show...96&postcount=7
this will work for you 05.
Old 04-12-2006, 05:15 PM   #10
metoo
Member#: 4764
2004 STi sold :(
forizzle
Do the spacers stop the P0139 code?
metoo is offline   Reply With Quote
Old 04-23-2006, 06:15 AM   #11
hatchy
Member#: 36852
2004 STI
Nothing stops P0139.
hatchy is offline   Reply With Quote
Old 04-23-2006, 11:21 AM   #12
JRSCCivic98
Member#: 67080
Proper EM does...
JRSCCivic98 is offline   Reply With Quote
FS NJ- perrin CEL fix ACLerok Tri-State Area Forum 0 06-20-2005 11:35 PM
FS Perrin cel fix cesaro Private 'For Sale' Classifieds 0 11-27-2004 01:47 PM
perrin cel fix codered North West Impreza Club Forum -- NWIC 6 11-19-2004 09:00 PM
Another question about my dead comp. New hardrive didn't fix it garface Off-Topic 11 12-01-2003 01:32 AM
ECU needs to be re-programmed- a few questions about my CEL codes Slvrblt New England Impreza Club Forum -- NESIC 6 04-26-2003 04:12 AM
