Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-22-2006, 04:11 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default why you need a real tuner vs tune it your self
why you need a real tuner vs tune it yourself
Old 02-22-2006, 05:47 PM   #2
dmross
Member#: 2818
2000 2.5RS
Turn down the boost, 170 psi is a lot.
dmross is offline   Reply With Quote
Old 02-22-2006, 10:07 PM   #3
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
I don't understand.
THAWA is offline   Reply With Quote
Old 02-23-2006, 12:00 AM   #4
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Originally Posted by THAWA
I don't understand.
I am glad I wasnt the only one??
Scoobie Steve is offline   Reply With Quote
Old 02-23-2006, 12:12 AM   #5
silvialost
Member#: 91021
1997 impreza
red
to much timing would account for knock but what afr is the car running.
silvialost is offline   Reply With Quote
Old 02-23-2006, 12:13 AM   #6
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
lots of knock - thats the point
Hitokiri is offline   Reply With Quote
Old 02-23-2006, 12:54 AM   #7
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
read a tuning book? have proper monitoring tools? you could tune that no problem having that log yourself.
Ben
Old 02-23-2006, 02:27 AM   #8
bbbwrx
Member#: 32734
Yeah more info on what the values are would help reading it.
What are you using to tune the car?
Boost seems to fluctate alot seems like the turbo is being pushed pretty hard or the ecu is trying to pull boost down to help prevent knock.
That torque graph is all over the place def a very bad tune
bbbwrx is offline   Reply With Quote
Old 02-23-2006, 02:42 AM   #9
wrx13oy
Member#: 60529
2002 PSM Bugeye stg6
07 Kawasaki ZX6R
are you using data log lab?
wrx13oy is offline   Reply With Quote
Old 02-23-2006, 01:11 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
lets see here
main point is hugh hole where knock is
tec2 -dyno log lab
afr ..mid 11s.. is difficult to tune and drive need to make op amp circuit to log wide band afr (the only way with a tec2 and lm1)
boost mbc ball/spring
actually not sure what the proublem is the blue line is timing i know i am not running enough at the top end most of the flat line is 9deg thus the HUGE drop off at 5500
was also ~20deg F outside when i made this run
this is my first real expirence with dynologlab
getting a good overlay like this with standard tec logs is difficult
Old 02-23-2006, 10:47 PM   #11
Scoobie Steve
Member#: 2289
1998 11.87@112mph
9 degs?? Knock from lack of timing?? lol That is a sad timing map. Dip in power just doesnt jive with other data recorded. A knock event alone wont cause that kind of power loss, and it didnt pull timing(not that it could run much less then 9 degs)
EGT'S? My guess is very hot!
Why you need to pay off your debt before investing Subie Doobie Off-Topic 7 12-18-2006 10:28 AM
Do it your self Tranny and Diff Fluid Change?? daveorama Service & Maintenance 23 02-28-2006 05:35 PM
modded stock grille on an 03 you can do it your self DEXSPTS Interior & Exterior Modification 13 02-22-2006 09:35 PM
#1 reason why you need to replace your drivetrain mounts incognito351 New England Impreza Club Forum -- NESIC 49 10-26-2004 05:18 PM
Why you need some "deadband" in your VC unit Orson Transmission (AT/MT) & Driveline 13 04-25-2003 07:46 PM
