Old 02-22-2006, 03:39 PM   #1
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Default Any aftermarket turbo with VF39 spool that makes more power and torque?
Hi all, got a question for all you guru.
I got a 04' STi, only mods are catted TBE, 1 step colder NGK and Ecutek.
I absolutely LOVES the powerband with the instant 300 wtq @ 3200rpm punch.
My question to you all is, if the only thing I want to change is the turbo and retune the Ecutek, is there any different turbo out there that retain 100% of the low end punch of the VF39 while providing any gain of power?
In another words, any turbo that can provide a bigger area under the curve without the curve dipping down the stock curve anywhere especially between 1k~4k rpm?
My intention is trying to find out if there is a better turbo out there when my stock VF39 is due for replacement. I have a feeling the stock VF39 is the best for my preference. If I can't find a better turbo, I'll just get another new VF39.
I drove my friend's STi with the same exact mods as my car but he has a TD06 20G, while it does pull noticably harder in the higher rpm range, I absolutely hate the fact that it lost the low end punch. So is there a turbo that are size between the VF39 and the 20G. How about a modified/ported VF39? Or a VF34?
And is there a turbo out there that makes more low end torque and power then the VF39?
I know what I really want is a 911 Turbo, 500 lb-ft @ 2k rpm and 500 hp @ 6k rpm
I want a REALLY quick off the line street car
JDM addict is offline   Reply With Quote
Old 02-22-2006, 04:12 PM   #2
06WRXTR
Member#: 96668
2006 WRX TR
td06-18G ported
06WRXTR is offline   Reply With Quote
Old 02-22-2006, 04:15 PM   #3
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
You can run a TD05 or 5h hot side... they will spool quite quickly, but not have much up top.
The td06 (non clipped) should be the best balance... and with the 18g compressor, you should be able to see similar spool, maybe even a tad better than the VF39... and still have some room left up top...
BigJ04STi is offline   Reply With Quote
Old 02-22-2006, 04:28 PM   #4
mikeyg
Member#: 86497
04 STI
tdo6h 20g. I have the stocker and my bro has this turbo. Very similar spool except 150 more whp with the 20g. Don't forget that the new 911 turbo has Variable Area Turbine Nozzle turbos (they call it variable geometry). That's how it has a 2000rpm boost threashold. It's a freak show, I'd love to drive one.
I don't know about your 20g experience but IMO, the 20g has a pretty violent low end hit. It shares that lack of smoothness with the VF39 that isn't there with the bigger turbos (Green, Red, SZ49, SZ55) My bros setup and tune feels very stock-like in terms of boost threashold and such. Good luck
mikeyg is offline   Reply With Quote
Old 02-22-2006, 04:44 PM   #5
Davenow
Member#: 23676
Yeah TD06 18G will spool at least as fast as stock but make a good bit more power
Old 02-22-2006, 04:51 PM   #6
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
I imagine almost any larger turbo, including the 18G which seems the best choice, you're gonna need new injectors.
Capt Crunch is offline   Reply With Quote
Old 02-22-2006, 04:53 PM   #7
klattery
Member#: 48503
2004 STi ATP3071
A td06-20g with 3" inlet would probably outspool your current VF39 with TBE, and give you a lot more up top. It would definitely outspool it if you added water/alky injection.
klattery is offline   Reply With Quote
Old 02-22-2006, 05:58 PM   #8
black06wagon
Member#: 97270
vs.
is the difference in the tune or the butt dyno?
black06wagon is offline   Reply With Quote
Old 02-22-2006, 07:14 PM   #9
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Originally Posted by black06wagon
vs.
I am wondering about the same thing.
I think it depends on the tune, the butt dyno and also there are different trim in a TD06 20G, like klattery mention, a 3" inlet, I think there are different inlet size, wheel size.......etc......
So confusing, I just know the 20G STi I drove completely lost the low end punch of the VF39. My VF39 hit hard at 3200 rpm, where this particular 20G STi I drove, full power come on much more softly/linearly at 3800~4000 rpm or so.
The owner of that 20G STi didn't like it over time too and put the VF39 back on.
Old 02-22-2006, 07:17 PM   #10
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Originally Posted by 06WRXTR
td06-18G ported
This is one of the one I will look into, since it is size in between a 20G and VF39. You just never know until you tried it
Old 02-22-2006, 07:19 PM   #11
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
I can handle buying a set of bigger injectors, I just don't want any FMIC, this, that....etc.
Thanks for the reminder though
Old 02-22-2006, 07:31 PM   #12
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
No water/alky injection to minimized cost, hassle and headache
I need to look into all the different trims and configurations of the TD05, TD06 family, if anyone would be kind to point me in the right direction to look (links), I would really appreciate it
Old 02-22-2006, 08:01 PM   #13
mikeyg
Member#: 86497
04 STI
Default top mount?
Was the 20g you drove with a FMIC? With the top mount, the characteristics will be different. Just a variable to consider. Also, maybe try to get a ride in someone elses just to verify. Tunes and such can vary greatly.
Also keep in mind that the bigger turbos have a smoother power delivery. I have at times wondered if the 20g on my bros car really spooled as fast as stock because it felt smoother. He is also running a Blow through MAF.
But ultimately I have never considered the 20g to be a compromise in any way or fashion compared to the stocker in terms of threashold or lag. Especially when it was mated with a top mount.
Old 02-22-2006, 08:22 PM   #14
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Keep the 39 and go with ALKY. Most of todays systems are very reliable and hassle free, offer fail safes, don't require injector upgrade and will give you 80-100whp over stock with flat hp and tq curves and fast spool. It's a win win.
silver arrow is offline   Reply With Quote
Old 02-22-2006, 08:45 PM   #15
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Easy answer, VF34. Someone on the forums has already done it with surprisingly good results. Take a look around and see if you can find his post.
HerculesPeanut is offline   Reply With Quote
Old 02-22-2006, 08:45 PM   #16
th1rd3y3
Member#: 83054
'11 SWP
STI
I'll be having my 05 STi with a ported TD06-18g dyno tuned on Monday, keep an eye out for it.
th1rd3y3 is offline   Reply With Quote
Old 02-22-2006, 11:11 PM   #17
Capt Crunch
Member#: 10852
The vf34 and the vf39 are so close to exchange one for the other would be pointless. Hell, going from a vf3x to a vf22 is almost pointless. Go 18G or keep the vf39.
Old 02-22-2006, 11:17 PM   #18
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Not according to this guy:
http://forums.nasioc.com/forums/show...highlight=vf34
Old 02-23-2006, 12:39 AM   #19
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
Subscribed Like this thread what I am looking for a good track turbo. Quick spool with some nice HP/Torque!!!!
18G sounds like a good bet.
How much HP/Troque are you lookin get with an 18G with the proper supporting mods?
For 93 octane?
For Race Gas?
Thanks,
Matt
PA04STI is offline   Reply With Quote
Old 02-23-2006, 01:54 AM   #20
Capt Crunch
Member#: 10852
butt dynos vary from person to person. He even put a header and inlet on at the same time, so I wouldn't say it was all due to the turbo. In fact, I bet most of it wasn't due to the turbo. Hell, we just had a guy claim he gained top end by adding a fuel pump, so I wouldn't just go by word of mouth.
Thing is, on paper the vf39 and the vf34 are very, very close. If you get a butt dyno reading from the swap, then you're liable to get a butt dyno reading from intercooler hoses. Whoop de do.
VF3x<VF22<18G<20G<fpgreen
lets say each turbos is about 15-20 hp up from the previous one... 20 hp isn't worth the turbo upgrade, a fraction of that even less so.
Old 02-23-2006, 03:35 AM   #21
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
So a few of you guys mention a H, I need to look into what that means. Sorry guys, I am not very familar with all the different trim of turbos, that is why I am asking now.
So TD05h-18g, or TD06-18g is what I need to look into.
Old 02-23-2006, 03:44 AM   #22
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Yes I know. Like I said, the 20g STi I drove has the exact same mods as my car except the 20G. He also had the stock STi top mount, TBE and Ecutek tuned. He had bigger injectors too to support the bigger turbo, but that is not a factor, you know.
Yeah true. I tried when I can. I actually rode in some other guy's STi with a 20G and a FMIC, weak low end, I was blaming it on the FMIC, then I tried a 20G with the stock TMIC, same feeling from my butt.
That is one of the reason why I think that a 20G car feel weaker in the low end because the power delivery is much smoother. The biggest feeling I got from the 20g STi I drove with the TMIC is it just feels so smooth. You know how a smooth car make it feels slower, less exciting, even though it is a faster car.
I don't know what that is, do you mind explaining?
Maybe you are correct, but the extra smoothness made it feels slower.
Thanks a bunch for your valuable inputs
Old 02-23-2006, 03:45 AM   #23
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Sounds great, but I really don't want to get into extra stuff. I am a all boost kinda guy
Old 02-23-2006, 03:46 AM   #24
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
I hear some people think the VF34 is great, but I also hear some people think it is no different then a VF39.........
If you can find the link for me, I would appreciate it
Old 02-23-2006, 03:46 AM   #25
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Definitely, good luck and thanks for letting me know
vf23 or vf39 - which makes more power? SketchINoc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 05-26-2015 06:26 PM
making more power with stock axleback jmbwrx2004 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-11-2009 01:20 PM
Any turbos with faster spool than stock TD04? Ernest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 12-17-2007 06:30 AM
what turbo makes more power? hangten93 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-24-2004 08:28 PM
Would you go out with a girl that makes more than you? Gobi Off-Topic 53 12-24-2002 11:57 AM
