Old 01-02-2001, 02:44 PM   #1
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post What does a dying wheel bearing sound like?
I have this persistent squeak coming from the left front area of the car, and it squeaks with every rotation of the wheel.
It sounds a little like when I had a bent dust shield, but not so severe and I've checked the dust shield this time.
Time to take it to dealer?
remarcable is offline   Reply With Quote
Old 01-02-2001, 03:12 PM   #2
iceman
Member#: 1546
95 Legacy L
Post
a wheel bearing sound like a humming or maybe even a groan? from what you are say it sounds like brake pads....
hope this helps,
ice
iceman is offline   Reply With Quote
Old 01-03-2001, 07:58 AM   #3
motorob
Member#: 2878
06 Evo IX MR
Post
99% that's not a wheel brg. Like the man siad, prob. pads, or V. slightly warped rotor. Do you only hear it with windows down, at very slow speeds etc? Or do you hear it while you're going down the road? If you don't, then ignore it, that basically could be considered "normal."
motorob is offline   Reply With Quote
Old 01-04-2001, 09:29 AM   #4
remarcable
Member#: 2362
1999 Legacy Outback
Post
I hear it at low speeds, at highway speeds the road noise and wind cover it up. My brakes do need work on them, I'm pretty sure the rotors are BOTH warped up front. Kind of dissapointing on a car with only 23k miles on it.
Old 01-04-2001, 03:30 PM   #5
iceman
Member#: 1546
95 Legacy L
Unhappy
id have to say it is your brakes then?
ice
Old 01-04-2001, 06:02 PM   #6
slide
Member#: 1130
2013 STI Hatch
Post
There is a metal e clip on the hub, that, when it comes of, squeeks.
slide is online now   Reply With Quote
What does a bad rear wheel bearing sound like? AWDsubie Normally Aspirated Powertrain 11 10-07-2008 06:07 PM
What does a bad rear bearing sound like? stephan Brakes, Steering & Suspension 4 09-21-2006 09:56 AM
What does a worn wheel bearing sound like... huckedup16 Legacy Forum 19 09-27-2005 06:22 PM
What does a bad wheel bearing sound like? speed_freak27 Brakes, Steering & Suspension 9 07-15-2003 01:53 PM
What does a bad wheel bearing sound like? Corey Technical Forum Archive 7 06-13-2000 06:40 AM
