Old 02-22-2006, 07:04 PM   #1
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Default 485hp Pumpgas/Meth with an FP-Red
Just finished up another customer car, this car we actually did a baseline run on before we did any mods. The customer brought us and bone stock 2005 STI (dyno run#2). We then unstrapped it off the dyno and began adding on a list of parts, which include: Fp-Red, perrin Big Maf, helix injectors, perrin 3" inlet pipe, SMC meth injection, APS turbo back exhaust, Turbo XS fmic, walboro fuel pump, tgv delete, act clutch, and topspeed protune. We then put her back onto the dyno to see what kinda of numbers we could get (dyno #7). Boost would spike 28psi then fall to around 26 (Internal Wastegate wouldn't hold anymore). The AFR's were 10.9 to redline, we didn't want to push it to hard on pump. I was amazed that even with the big maf we were hitting 4.86 volts. I would imagine with and external gate and some race gas this turbo would have no problem hitting 500hp.
Enjoy
Doug
TopSpeed is offline   Reply With Quote
Old 02-22-2006, 07:05 PM   #2
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
nice, looks like it really hits
and great hp plateau
LatentWagen is offline   Reply With Quote
Old 02-22-2006, 07:35 PM   #3
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
newb question; doesn't a new clutch have to be broken in first?
Nice numbers
Paul is online now   Reply With Quote
Old 02-22-2006, 07:43 PM   #4
pux888
Member#: 8356
02 STi swap
12 WRX limited
how lagy is that setup on the road?
pux888 is offline   Reply With Quote
Old 02-22-2006, 07:44 PM   #5
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
is it me or are you posting corrected numbers?
if so why?
BREWPUBEAVER is offline   Reply With Quote
Old 02-22-2006, 08:02 PM   #6
TopSpeed
Member#: 78884
Go faster
at TopSpeed
if so why?
SAE is the national standard, it is what is used so that weather conditions such as humidity, temp and barometric pressure are all acounted for. SAE is the most common correction used since you can dyno a car on two different days and have the real gains shown, not just a gain in power because its colder out. Since we didn't dyno this car on the same day it only makes since to use the SAE correction to rule out any additional power gained because of the weather.
To be honest the uncorrected numbers are higher due to the fact its cold outside, and IIRC the uncorrected numbers were around 495ish...
p.s congrats on your car, those are some sick numbers.
Doug
Old 02-22-2006, 08:04 PM   #7
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
wow very nice numbers, when are you seeing full boost with this setup? the red is starting to look tempting!!
trbowrx is offline   Reply With Quote
Old 02-22-2006, 08:23 PM   #8
BigBoosting
Member#: 48553
After i get my new clutch put in, ill be back for another tune and hopfully i get some numbers like that.
awsome, looks good.
BigBoosting is offline   Reply With Quote
Old 02-22-2006, 08:28 PM   #9
Seranin
Member#: 54409
2006 Forester
Hmm, 245hp not enough for you? Okay, let's double that. ha
Seranin is offline   Reply With Quote
Old 02-22-2006, 08:37 PM   #10
moorebl
Member#: 59238
topspeed which act clutch did he use with that setup race disc 6 puck unsprung or what. just a little curious
moorebl is offline   Reply With Quote
Old 02-22-2006, 08:47 PM   #11
2k2_turbo_egg
Member#: 108104
05' hawnda S2000
new formula red
Damn, slower than stock until 3.2k and then all hell breaks loose. How big are FP reds/greens?
2k2_turbo_egg is offline   Reply With Quote
Old 02-22-2006, 08:53 PM   #12
scooby_x
Member#: 73130
2005 WRX sedan
all this on a stock block? do you have plans of throwing in a built motor? or will the 2.5 take that much of a beating stock
scooby_x is offline   Reply With Quote
Old 02-22-2006, 09:01 PM   #13
InfamousDX
Member#: 25413
Wow... once again TopSpeed proves power. A baseline BONE STOCK dyno, then installed parts, then a tuned dyno... you can't get any more accurate than that!! Almost 100% increase!! Sickness.....
Old 02-22-2006, 09:15 PM   #14
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
cool Doug, just curious.
thanks on my car. too bad im not in the South any more. or i would be inclined to run your Evo (and get smoked)
Old 02-22-2006, 10:21 PM   #15
javid
Member#: 54304
04 STi
TopSpeed-dAng!
<golf clap>
Nice work Doug and congrates to who ever the lucky owner is!
javid is offline   Reply With Quote
Old 02-22-2006, 10:51 PM   #16
burnin4
Member#: 59764
10 sec STi
10 sec Z06
holy smokes! great numbers!
burnin4 is offline   Reply With Quote
Old 02-22-2006, 11:41 PM   #17
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Congratulation ... What is the EGT at redline?
WRX-Blue-Mica is offline   Reply With Quote
Old 02-23-2006, 12:07 AM   #18
LuSTi
Member#: 99184
Well I just got back to Charlotte. Driveablility is awsome with this turbo! I havnt had a chance to test out the power too much since its so wet outside. I get no traction so I couldnt test it out. This is on the stock block, I am planning on putting in a built motor after the summer. The car is smooth as can be, runs great!
LuSTi is offline   Reply With Quote
Old 02-23-2006, 01:15 AM   #19
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default nice comparo...
Congrats on the performance. Appreciate you letting your shop perform this experiment and thank you TopSpeed for doing it!
ka mano is offline   Reply With Quote
Old 02-23-2006, 10:07 AM   #20
chrisfranklin
Member#: 59737
2004 sti
crappy subaru white
No blow thru maf on this one doug?
Congrats on the #'s.
chrisfranklin is offline   Reply With Quote
Old 02-23-2006, 12:34 PM   #21
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
thats a great comparo for this turbo against a stock STI.
really nice improvement over the stock baseline. (area under the curve and not just peak)
Illusive is offline   Reply With Quote
Old 02-24-2006, 02:12 AM   #22
LuSTi
Member#: 99184
They didnt have any of the bungs for the blow through maf in stock when I was there. The drivability is BEAUTIFUL without it though. I may add it on later, but it doesnt seem nessesary so far.
Yea the area under the curve really shows how great this turbo and setup are. Not just top end horsepower, this setup makes some KILLER torque to throw you back in your seat in ALL gears!
Old 02-24-2006, 04:01 PM   #23
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Hey Doug, any impression on tuning using the Helix injectors? Are they really a straight drop in and as easy or easier to tune than PE's?
offset
offset is offline   Reply With Quote
Old 02-24-2006, 08:55 PM   #24
ImposSTiR
Member#: 106513
2005 Impreza WRX
+1 for this
ImposSTiR is offline   Reply With Quote
Old 02-24-2006, 09:05 PM   #25
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
isnt 10.9 a bit rich for having Meth injection? Were you able to run it a bit leaner for more power?
Golfa is offline   Reply With Quote
New Results with the FP Red! alcrudojr #00 Proven Power Bragging 40 12-26-2007 04:25 PM
510 lb-ft with the FP Red (Part 2) PDXTuning Proven Power Bragging 24 04-14-2007 03:10 PM
Anyone looking to buy an FP Red and goodies? ride_the_pony69 Engine/Power/Exhaust 2 12-03-2006 04:06 PM
1/8 and 1/4 trap speeds for an FP Red Shabib67 Proven Power Bragging 7 03-09-2006 08:24 AM
FP Green into an FP Red 03scubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-19-2005 02:07 AM
