Old 02-22-2006, 10:25 PM   #1
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
Default Continued boost problems
K im somewhat new here but i think my old post got deleteted...
I have a 04 wrx, & i just realized that for about 5 mo. now I have not been hitting stock boost. In all gears it get to about 9.8 and maybe 10psi if i am lucky.
I Have Tried
Checking for boost leaks
Resetting my ecu
checking to make sure the "pill" in the turbo hose is there(it is)
checking my BOV
Mods I Have
turbo xs RFL BOV
Accessport stage1/91
Hks cat back
I DID have a mbc and then an ebc, but i took them both off for safety reasons.
Next Steps I Plan on Taking
1.) remove/clean FBC
2.) adjust wastegate arm?
3.) buy a new solenoid???
I really dont know what to do next, i have had this problem for so long and just want to get it over with without spending any $$$$$. I only have 26K mi. on the car so i diddnt think the solenoid would be bad. Any help would be great. Thanks!
redrex04 is offline   Reply With Quote
Old 02-22-2006, 10:29 PM   #2
hondaeater69
Member#: 60324
did you try a stock BPV yet?
Old 02-22-2006, 10:33 PM   #3
JRSCCivic98
Member#: 67080
Make sure the pill is between the turbo nipple and T in the hose... NOT between the T and the wastegate nipple. If that's correct, change the BOV back to the stock one... the RFL might just be leaking or something.
Before you do all of that though, revert to stock on the AP. See where you are at with a stock map... if it's boosting well with that (12.5-13.5) then it's the tune on the AP map.
JRSCCivic98 is offline   Reply With Quote
Old 02-22-2006, 11:13 PM   #4
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
I tried putting the stock bov back on, no help, tried reverting to stock, no help, now that i think about it, i had this problem before the accessport.
so now i have 2 q's
1.)hondaeater69 did you mean BOV?/what is a bpv?
2.)ok, looking from the passenger side of the motor...
Wastegate ----(hose w/pill)--------T -----too other part
Towards the right side of the car (down in diagram) goes to FBC
IS this right?
Old 02-22-2006, 11:41 PM   #5
redrex04
Member#: 53788
2004 Impreza wrx
San Remo Red
Sorry ima dumba$$!, JRSCCivic98 , youwere right, i had the pill in the wrong place, its fixed, fast ass hell compared to before, JRSCCivic98, u fixed a problem ii have had for over a year, thanks man!!
continuous smoking problem mannyOlicious Built Motor Discussion 4 07-10-2008 03:09 AM
So, due to continued tranny problems, I am no longer a suby owner BGPunk2001 Texas Impreza Club Forum -- TXIC 41 05-08-2006 12:10 PM
Boost problem...did i fry my stock boost controller brazymstrp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-30-2004 02:14 PM
oddest boost problems continue kcwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-11-2003 06:24 PM
Help with boost upgrade - high boost problem alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-06-2001 06:15 AM
