Old 02-23-2006, 02:23 AM   #1
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Default Maximum HP on JDM EJ207
What is the maximum HP on a JDM STI EJ207 (version 10) with stock internals?
Also, at what point should you upgrade the 565cc injectors?
STI8U is offline   Reply With Quote
Old 02-23-2006, 03:09 AM   #2
SSFWRX
Member#: 31789
Now with 100% more
V8 Spec C and 6MT
I dont think anyone knows the limits of the stock internals on the JDM EJ207 all to well. As far as injectors go....the stock JDM 565cc's arent gonna do much more than simple bolt ons.
SSFWRX is offline   Reply With Quote
Old 02-23-2006, 08:42 AM   #3
jtanoyo1
Member#: 102050
2004 JDM WRX STi
Diamond White
Haha, I think I will find out what that "limit" will be with my car sometime this year, before I switch to a 2.5L shortblock.... Keep u guys posted.
jtanoyo1 is offline   Reply With Quote
Old 02-23-2006, 08:56 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i've seen a couple of 500whp ej207s floating around, fwiw.
Old 02-23-2006, 11:14 AM   #5
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
yeah, there's that guy running the ultimate performance GT35R kit who I think made 500 whp.
Capt Crunch is offline   Reply With Quote
Old 02-23-2006, 11:41 AM   #6
Blackboxracing
Member#: 90106
is that with a completely stock engine? heads, internals, etc
Blackboxracing is offline   Reply With Quote
Old 02-23-2006, 11:49 AM   #7
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Thread:
http://forums.nasioc.com/forums/showthread.php?t=842346
I made 504 WHP on a dynapak running 32psi through a stock JDM STi v7 motor. I've daily driven the car since then and the motor leak down tested perfect as of 2 weeks ago. Keep in mind on pump gas everyday i don't beat on it very much. I mostly run 18-19psi and not the 23psi i was tuned for on pump gas. I have run about 30-35 gallons of C-16 through it though since the tune, as well as a couple drag passes.
This was stock heads/cams. Some headwork and cams would really help out.
I did not expect the motor to last me many miles. I know it can go anyday, but i do feel it's a somewhat reliable setup if you give it some good high octane fuel and don't beat it on pump gas.
Hope this helps,
Louis
Soon2Bgreat is offline   Reply With Quote
Old 02-23-2006, 01:43 PM   #8
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
I overboosted my ej207 accidentally to over 30psi and blew a headgasket.... The internals just laughed at me and asked for more
Javier is offline   Reply With Quote
Old 02-23-2006, 01:48 PM   #9
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Originally Posted by Soon2Bgreat
Thread:
Louis
504HHP?(Hub Horse Power)
Kingpin is offline   Reply With Quote
Old 02-23-2006, 02:28 PM   #10
justboosted02
Member#: 78285
2003 EVO
red and black
thats still at least 470 whp on most other dynos
justboosted02 is offline   Reply With Quote
Old 02-23-2006, 02:33 PM   #11
cronic
Member#: 9749
I know but i like busting his balls..lol
cronic is offline   Reply With Quote
Old 02-24-2006, 04:09 AM   #12
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Hmmm, a local tuner here that does Motecs for a lot of rally cars in Australia reckons the stock internals on STI Spec Cs are only good for 400lbft torque (flywheel). Says the pistons since v8 have gone down a grade and they have problems with the spacing between the rings or something...
Old 02-24-2006, 12:03 PM   #13
Javier
Member#: 19346
2003 MBP WRX
The V8 pistons are made the same as the usdm sti pistons so that's not surprising. Most would agree that the V7 STI pistons are more hearty and can take more abuse...
Diagnosis on jdm ej207 heads pls? rip_sti_ra Built Motor Discussion 15 08-13-2008 02:38 PM
EJ5-40T on a JDM EJ207 Kreeger Proven Power Bragging 49 10-02-2005 10:43 AM
Maximum HP from STi engines? Stevo88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-06-2004 10:51 PM
what is the maximum hp the STi 6speed can handle? trinydex Transmission (AT/MT) & Driveline 7 02-11-2004 06:48 PM
Maximum HP on stock RS fuel system with walbro fuel pump Chav Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-17-2002 03:42 PM
