Old 02-23-2006, 10:21 AM   #1
kbahus
Member#: 70256
2000 STI V2 Swapped
Default Scanning an obd1 JDM ecu?
Posted this over at rs25 but didn't get any reply so thought I would try it here.
What is it gonna take to communicate with an obd1 jdm ecu? Will any scan tool retreive/clear codes or am I going to be totally hosed if I need to scan it and see what is going on? I am not worried about flashes, tuning, etc but just seeing what is happening and being able to check and clear cel's.
Please let me know what can be done about this situation as this is hopefully the final hold up before I order my engine (v2 sti).
kbahus is offline   Reply With Quote
Old 02-23-2006, 10:52 AM   #2
Lachlan
Member#: 19470
1981 Brat GL
If you have an obdI harness there should be some little connectors under the driver's side of the dash. Plug them together and the CEL will start to flash. The order of flashes and pauses will tell you the trouble code.
Lachlan is offline   Reply With Quote
Old 02-23-2006, 12:42 PM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
theUSscanerswillreadthecodes....spacebuttonbroken: (
snowman4us is offline   Reply With Quote
Old 02-23-2006, 12:52 PM   #4
swapstar
Member#: 102779
1998 PM if u need
JDM bits.....
its a normal OBD1 setup like any USDM. if u google serach surreal mirage or somthing like that theres a website with all the codes and how to check/clear/reset ecu. its really simple, jdm codes are same as usdm.
swapstar is offline   Reply With Quote
Old 02-23-2006, 01:06 PM   #5
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
www.surrealmirage.com/subaru/engine.html
Should be the same/similar as the legacy codes.
VRG3 (Vikash's) scan tool may even work
http://www.graphics.cornell.edu/~v/bcbfscan/
Legacy777 is offline   Reply With Quote
Old 02-23-2006, 01:35 PM   #6
97sptsti
Member#: 100755
1997 impreza sti
red/black
what about obdII? will a us scan tool communicate with an obdII jdm ecm. i tryed with my generic scan tool and it refused. i even tryed world wide communication where you type in the vin.
97sptsti is offline   Reply With Quote
Old 02-23-2006, 04:09 PM   #7
kbahus
Member#: 70256
2000 STI V2 Swapped
Thanks for that info on the obd1 stuff guys!
Old 02-23-2006, 06:40 PM   #8
Legacy777
Member#: 4800
OBD2 is a standardized comunication protocol. There are standards, as well as proprietary pins.
I would think a scanner is a scanner and should be able to read OBD2, regardless of where it was sold.
Old 02-24-2006, 10:16 AM   #9
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
2nd that.
Old 02-24-2006, 05:28 PM   #10
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
hahahahahaha omg thats funny. good to know too.
Hurley 2.5 WRS is offline   Reply With Quote
anyone repinned a obd1 ej18 ecu plugs to work with obd1 ej22 ecu mellow65 Subaru Conversions 0 03-18-2009 08:50 PM
Need a NoVA shop to read an OBD1 CEL Mikey52 Mid Atlantic Impreza Club -- MAIC 6 03-14-2008 04:08 PM
saw an OBD1 ej25 ecu on ebay? 2slofouru Subaru Conversions 1 09-25-2006 10:48 PM
JDM ECU passes IM240 OBD II scan test! downshift1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-22-2005 01:40 PM
02/03 Unichip on an 04 JDM ECU? Brian Broz Engine Management & Tuning 1 11-11-2004 05:00 PM
