Old 02-23-2006, 11:33 AM   #1
spoonfedb18a1
Member#: 51273
1998 EJ20G RS 345whp
black
Default help me out guys
i have a 98 rs with a jdm ej20g in it, with the jdm ecu and harness.
everything is stock, but i want more power...alot.......and i need help on deciding what i should do next .......to get more power.....i have $4000 to spend on anything.
what do u guys think i should get....bigger turbo swap....ect...or should i just go on the looks a little bit...like go for that jdm look..lol
by the way the car has a 2001 front end conversion, the car is black on gold stockers.
also the car may be up for sale in about a couple months........what do you think it may be worth.....with only about 34,000 on the motor.
with swap and four grand into it...?
thanks,
Andrew
spoonfedb18a1 is offline   Reply With Quote
Old 02-23-2006, 11:56 AM   #2
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
APS DR650 FMIC painted stealth black.
If you already have a VF30 or VF34, sell it and move up to a 20g or equvilant.
APS 3.5" turboback.
Utec and a tune.
Do you already have the JDM STI 6spd? If not, get one. If so...
340 whp = Done.
chrisarella is offline   Reply With Quote
Old 02-23-2006, 12:15 PM   #3
spoonfedb18a1
Member#: 51273
black
nice input
no six speed. using my tranny and diff
the car is basicly stock other than jdm suspension.
thinking of switching to frontmount and turning up the boost.
also i really want to dyno the car just to see how much power and torque the stock motor really has......the i wnt to go utec and tune everthing.
Old 02-23-2006, 12:54 PM   #4
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
^^^what turbo do you have? VF30? VF34?
And which injectors ? WRX 480s? STI 550s?
Old 02-24-2006, 12:36 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
888-457-2559 Every day!
I think this should go in the conversion forum...
Anyway let me see if I can shed some light on this subject.
Ej20G eh? is it from a WRX Wagon or Sedan? It will either have a TD04 if it is a Wagon or Automatic(i think) It will have a TD05 16g if it is a Sedan.
Upgrades.. What do you want to do with this car? Have it as a street terror? Track? Show??
If it were my car, and I wanted more power I would upgrade......
Turbo- If you have a TD05 you can do some magical things with that lil' snail. Contact some of the Turbo Vendors on this ask them what they can do to the turbo. I smell 18G. Also your Turbo has a 90 degree inlet, so if you want a bigger or aftermarket turbo, that will be an issue that will have to be adressed.
Injectors - Your stock injectors are okay at best. There are some campanies that make injectors for the older jdm engines such as Power Enterprise. You can get up to 800cc injectors or as low as 550cc, dependiing on what you want. You will want an Upgraded fuel pump(if you dont already have one)
Engine management - umm... Power FC? You can run piggy backs, but if you want real power you will need to go full standalone on the older engines. Piggybacks are great for mostly stock set-ups, but if you go with a bigger turbo or injectors I think you would want something more powerful than a piggyback. The Apexi Power FC for the EJ20G is a plug and play unit.
Intercooler - Go Front Mount if possible. You can go with something like the APS unit that is specific for GC.
Or you could always just make a custom one, usually pretty cheap option.
Exhaust- Any WRX Turboback will fit nicely.
I would recomend upgrading the brakes and suspension also, but that is up to you.
Please let me know if you have any questions regarding your project.
Thanks
Rick
AIM: RickatRSD
801.619.1779
RallySport Direct is offline   Reply With Quote
Old 02-25-2006, 12:20 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
i say you do suspention and brakes...before you cango 120mph in less then 15sec. you need to be able to slow down 2X as fast and corner 2x as hard.
my .o2
snowman4us is offline   Reply With Quote
Old 02-25-2006, 01:38 PM   #7
spoonfedb18a1
Member#: 51273
black
thanks guys....
i am going with a bigger turbo, but i was looking toward something like a 20g...?!?!?
bigger injectors and also front mount.
as far as engine management i was leanin toward the new greddy e1 and have it wired in. what do you think....it is cheaper than the apexi power fc.
as far as brakes......brembo...?!?!? suspension......some jdm version5...or JIC coilovers.
if you guys can tell me anything else...it would be greatly appreciated.
Old 02-26-2006, 04:09 PM   #8
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
If you want something like the Greddy EM, you should just get the HKS F-con, It will be much better if you want a 20g and big injectors.
Rick
scoobydorift is offline   Reply With Quote
Old 02-26-2006, 04:35 PM   #9
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
an tod05 18G/20 is a simple upgrade as you can have deadbolt put the larger wheel in the existing housing ... other than that your are looking at a rotated mount due to the upturned inlet
a 30/34 (and vf-22) is smaller than what you have if your motor is from a manual sedan (auto and wagon have much smaller turbos)
i am running usdm sti injectors in a modified 1.8 fuel rail ~25% larger than stock
Help Me Out Guys...(Wedge Bulb Question) BigElm Interior & Exterior Modification 5 01-25-2002 09:02 PM
help me out guys! TurboWRX Car Audio, Video & Security 7 12-07-2001 08:54 AM
Slipping Gears? Broken Clutch? Help me out guys!!! IMPREZAmike Normally Aspirated Powertrain 20 12-20-2000 08:26 AM
Help me out guys....what do I want for christmas??? IMPREZAmike New England Impreza Club Forum -- NESIC 9 11-20-2000 11:33 AM
Help me out guys...got the estimate for my car... Overtime General Forum Archive 4 10-24-2000 10:32 PM
Message Board Statistics All times are GMT -4. The time now is 03:50 AM.
