Old 12-27-2000, 01:20 PM   #1
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Believe the bolt pattern is the same year to year. The 205-55/16 should fit and be very close for Speedo calibration as +2 fitment. The folks at TireRack are always very helpful on fitment questions and the call is free! 1-888-374-8473
nuburu2 is offline   Reply With Quote
Old 12-27-2000, 01:47 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
It'll work just fine if you've got the right size tires.
I've got 16" GT wheels on my 93 with 205/50s and it's just fine.
DLC is offline   Reply With Quote
Old 12-27-2000, 03:02 PM   #3
iceman
Member#: 1546
95 Legacy L
Question
how do i find out what size is the right size?
iceman is offline   Reply With Quote
Old 12-27-2000, 08:14 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Unfortunately, www.tirerack.com is not cooperating with me right now. So, I'll just have to give you the math and let you figure it out (if I had tirerack.com available, I could find out your stock tire size and work it out for you).
I will guess that your car has 195/70R-14 tires on it now (go take a look at the sidewalls of your current tires). That means the overall diameter of the tire is:
(195mm * 0.70 * 2) + (14in * 25.4mm/in) = 628.6mm.
If you're not familiar with tire size calculations, here's where all that comes from: 195mm is the tire's section width; the "70" is the aspect ratio - each sidewall is 70% of 195mm tall, and you have 2 sidewalls; and the 14 is the diameter of the rim in inches (which you already know). You want to maintain the same rolling diameter, but now you'll have a 16" rim, so your sidewalls need to be smaller.
So, we take that 628.6mm and we subtract the big wheel hole in the middle:
628.6mm - (16in * 25.4mm/in) = 222.2mm
You need your 2 sidewalls combined to be about 222mm tall to maintain the proper overall tire height. Let's assume we want to use a 205mm wide tire (the width that comes stock on the 2.5GT 16" rim). We need to figure out what aspect ratio is now that we know the total sidewall height we want and the section width we want:
222.2mm/2 = 111.1mm (we want each sidewall to be 111.1mm tall)
Now divide that by the section width to get the desired aspect ratio:
111.1mm/205mm = 0.542
Well, they don't make 205/54R-16 tires, but they do make 205/55R-16 tires, so that's what you want. Strangely enough, that's the stock tire size used on the '97-99 2.5GT with the 16" rims. (Secretly, I worked the problem backwards in order to guess that your car has 195/70-14 tires on it, which is why the problem worked out so well ).
If your stock tire size is not 195/70-14, well, you can just plug in the proper numbers and do exactly what I did above and you can figure out what size will be right for the 16" rims.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 12-27-2000, 08:17 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Of course, now that I'm done typing all of that, the Tire Rack site is working just fine. It tells me that the '96 Legacy L used a 185/70-14 rather than a 195, so my numbers are off a bit. It looks like DLC is right, then - a 205/50-16 is the best fit.
Pat
Old 12-27-2000, 08:27 PM   #6
iceman
Member#: 1546
95 Legacy L
Talking
well damn patrick you know your stuff! thanx a lot!!
ice
Old 12-27-2000, 09:06 PM   #7
iceman
Member#: 1546
95 Legacy L
Post
hey
thats a hard tire size to find tires for what are you guys running? not to many to choose from!
ice
[This message has been edited by iceman (edited December 27, 2000).]
Old 12-28-2000, 12:24 AM   #8
iceman
Member#: 1546
95 Legacy L
Question 99 Legacy wheel on a 96 Legacy?
the 96 has a 14in rim and the 99 has a 16. is the stud pattern the same? im alomst sure it is, but im double checking. is there any porblems with it clearing the caliper or rubbing? what size tires do you guys think i should use? how will this affect the speedo?
thanx
ice
Old 12-28-2000, 06:28 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
I just did a search for 205/50-16s over on the Tire Rack. I'm not sure what exactly you're looking for, so I'm assuming you want a high performance summer tire. In that case I would say your best bets are the Potenza RE730 and the Kumho ECSTA 712. Both are pretty new tires, both are quite inexspensive for a performance tire, and both have received very good reviews by fellow iClubbers. If you do a search for "712" or "RE730" in the Suspension, Rims, and Tires Forum I'm sure you'll turn up lots of good feedback.
Pat
Old 12-28-2000, 09:02 AM   #10
iceman
Member#: 1546
95 Legacy L
Unhappy
see i was looking for a hi pro all seasons. i dont have the funds for 2 sets of tires as of yet but we will see. i was looking at the dunlop sp sport 5000, but they dont come in that size.(205/50-16)
thanx though,
ice
Old 12-28-2000, 01:55 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
You might want to think about bumping up to a 205/55-16. There are way more tire options in that size - a very popular OEM tire size for a number of car makers.
I doubt you would have any sort of clearance problems at all - your '96 body style is identical to my '97, which came with 205/55-16s stock. If anything my 2.5GT may ride a bit lower than a "regular" Legacy, since the GT is supposed to be more sporting. So clearance shouldn't be a problem.
What probably will be a bit off is your speedo - it will read about 3.3% off. That means that when your speedo indicates 70mph, you'd actually be doing 72.5mph or something like that. Not a huge deal. And this may not be a problem at all anyway. I've read that a number of guys with 2.5RSs have gone from the stock 205/55s down to 205/50s and they've then clocked the car using mile markers on the highway. For some reason, the speedo was still right, even though technically it should be off by a couple percent. Kinda strange, but I've heard this from a few different people.
Pat
Old 12-28-2000, 03:21 PM   #12
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Thumbs up
Iceman, Try taking a look at the Yoko AVS db decibel for $101 ea in 205/55 16 from TireRack. There was a recent member post raving about the all around performance of this tire and the price is not bad!! Good wear index and very good performer in the rain. my $.02. I'll be looking at these when my Pirellis are used up.
Glenn O
Old 12-28-2000, 06:37 PM   #13
iceman
Member#: 1546
95 Legacy L
Unhappy
yea they look good but they dont come in the size i need 205/50-16! thats the problem i have, looks like if i choose this plan im look at the "pirelli p7000 supersports". does anyone know if the 205/55-16 will fit on the 96 with enough clearence? i would rather do that because i would have a lot more tires to choose from, but right now its not looking to good.
thank you all for your help!
ice
Old 12-28-2000, 08:47 PM   #14
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Exclamation
Ice, One more time....Call TireRack 1-888-374-8473(FREE CALL)with your concerns about fitment. From everything I've read on this post there would be NO PROBLEM with clearance on the 205/55 16 on your Legacy, That's what we're all running (stock) on the 16" rims.... only a VERY SLIGHT speedo error.
Glenn O
Old 12-28-2000, 09:07 PM   #15
iceman
Member#: 1546
95 Legacy L
Unhappy
Glenn im sorry, but im not sure as of yet what im doing. i already PMed pat because i already posted before i read the current posts. im just to tired to be doin this! im kinda making all my plans ahead of time. i will get my 96 in a week or less. when im sure of what im doin ill let you guys know. im sure ill end up running 205/55-16s, but im not sure yet. i was just scared of rubbing. thanx a lot for your help and im also sorry.
ice
Old 12-28-2000, 09:17 PM   #16
iceman
Member#: 1546
95 Legacy L
Unhappy
ice
Old 12-28-2000, 10:10 PM   #17
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Hey guy, I wasn't riding ya!! Sorry if it sounded that way. Looks like you gathered lots of good info on this post and I guess I was just anxious to see you get the right stuff together. Must be the DAD in me! Again, Sorry if I sounded a little harsh or impatient. Come on back when you've had some rest! Just lookin' to help.
Glenn O
Old 12-29-2000, 02:51 PM   #18
iceman
Member#: 1546
95 Legacy L
Talking
hey no problem man crap happens. yea i was just wanting to do this right because there are about 6 people wating for me to screw up and go "i told ya so" lmao!!
thanx for all the info though.
ice
Old 12-29-2000, 04:13 PM   #19
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Talking
I don't think you can screw up that bad!! You're buying a Legacy aren't you? You came to this board lookin' for info right? Two outta two ain't bad!! You'll do the right thing. Cool?
Glenn O
Old 12-29-2000, 06:43 PM   #20
iceman
Member#: 1546
95 Legacy L
Exclamation
thanx buddie!! im looking into some driving lights now that have my tire info.
thanx
ice
Old 12-29-2000, 06:47 PM   #21
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Have you looked here? http://catalog.com/susq/index.htm
Old 12-29-2000, 07:34 PM   #22
iceman
Member#: 1546
95 Legacy L
Wink
http://www.piaa.com/displayLamp.php3?inc=90pro.html
there ya go bud these are what im looking into and what i want, but 500 smackers is a bit much for me!! i already checked out that site you are talking about it had good info. however im leaning away from hella to piaas now.
ice
Old 12-29-2000, 09:01 PM   #23
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
Post
Well, you might want to upgrade the HORNS too!! I can recommend the Hella SuperTones. I replaced the stockers on our Legacy, and these babies will peel paint!! Not very pricey either!
Hey Ice, Have a very Happy New Year. May 2001 get those nay-sayers off your back!!
Glenn O
Old 12-30-2000, 09:27 AM   #24
iceman
Member#: 1546
95 Legacy L
Talking
ill get them off soon!! have a happy new year too. well im off to work now. its gona be nuts today.
ice
02-03 WRX wheels on a 96 Legacy L ebayking90 Tire & Wheel 3 09-28-2007 10:30 AM
01 rs bumper on a 96 legacy? serious Legacy Forum 3 04-08-2004 02:25 PM
uni chip on a 96 legacy with turbo? serious Engine Management & Tuning 11 02-04-2003 04:42 PM
Engine control on a 96 legacy with turbo 2.2? serious Engine Management & Tuning 0 10-31-2002 12:50 PM
98-99 RS wheels on a Legacy? quentinberg007 Legacy Forum 15 02-26-2002 03:19 PM
