Old 02-23-2006, 04:55 PM   #1
yellowmustang94
Member#: 92189
Default How to modify the wastegate spring?
Anyone know the best way to modify the wastegate spring to LOWER the boost? I am putting a turbo off of my friend's WRX that we parted out onto another friend's S10 4-cylinder, but we only want to run around 5-6 psi if we can. I might just let it run the way it is at 7-8 psi, but I don't wanna screw up his truck! Is there anybody who makes a replacement spring for these turbos that would bring the boost down? Thanks!
yellowmustang94 is offline   Reply With Quote
Old 02-23-2006, 05:03 PM   #2
hondaeater69
Member#: 60324
what's WG boost on a stock td04? If that's low enough you can just loosen the C clip or run a hose stright from the compressor to the WG.
If it's not low enough just get a cheap MBC and turn it down.
Old 02-23-2006, 05:08 PM   #3
yellowmustang94
Member#: 92189
From what I've read on other posts the stock TD04 WG runs 7-8 psi, which MAY be okay.....So when you say to get a MBC, how can that turn it down? I thought those can only raise the boost over what the WG allows? I'm still learning but that is what I've gathered from what I've read so far. I'm getting a cheapo MBC anyway just in case we want to tune around with the boost!
Old 02-23-2006, 05:45 PM   #4
hondaeater69
Member#: 60324
yea you're right about the mbc. on the stock turbo you can play around with the length of the WG arm, it's adjustable.
Old 02-23-2006, 05:50 PM   #5
yellowmustang94
Member#: 92189
I had read about that, but won't that cause problems if I mess with that? Which way do I need to turn it to lower boost? I know if you are adjusting it to raise boost you have a chance of getting boost spike, but are there any problems with adjusting it down? Seems to me like it could cause a problem, but I dunno.....Thanks!
Old 02-23-2006, 06:11 PM   #6
hondaeater69
Member#: 60324
i don't know if it's clockwise or counter, but you'll know which is which when you start to turn it. honestly i'm not entirely sure what kind of results it would produce.
Regarding your original question, there are companies that make aftermarket WG assembelies, but i don't see them having WG tensions of less than 8psi. your only shot at that may be finding a smaller turbo with a weaker WG and swapping it's WG assembely (if that's even possible).
Old 02-24-2006, 08:32 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
simple way to do it:
take a look at the many "helper spring" threads on this website.
just like all those threads, hook the spring on the wastegate flapper arm.
instead of pulling it towards the wastegate actuator, keeping the gate closed tighter, you pull it in the opposite direction (netting the opposite effect).
instant lower wastegate tension.
i would not try extending the wastegate actuator arm length, since this may prevent the wastegate from ever closing completely (ie rattling around).
Old 02-24-2006, 04:24 PM   #8
yellowmustang94
Member#: 92189
That was my point about the wastegate not closing....is there a certain limit on how many turns to take the arm down before it starts to not close? I suppose I could just mess with it now since it's off the car and see how far I can go until the wastegate opens, right? I like the helper spring idea, but what do I clamp the spring onto? Thanks!
Old 02-24-2006, 05:32 PM   #9
JRsleeper
Member#: 94791
2002 WRX wagon WRB
Ver 8 EJ207 4.44's
One of my buddy just picked up a used late 90's Volvo tdo4-13 turbo for his toyota. He has Alldata at work, so he look up the factory wastegate actuator for Volvo. Alldata stated that his tdo4 volvo turbo has a 1.5 lbs wastegate actuator spring.
JRsleeper is offline   Reply With Quote
How to modify the stock dummy water temp gauge to real water temp gauge? SuperTurbo Normally Aspirated Powertrain 14 02-01-2008 06:38 PM
How to choose your own spring rates (and get the spring frequencies correct) stretchsje Brakes, Steering & Suspension 2 05-16-2007 01:55 PM
how to adjust the turbo wastegate shaneconaway Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-10-2006 03:12 PM
how to modify 55w fog wiring to handle 100w? subyguy25rs Electrical & Lighting 8 09-20-2004 12:03 PM
('93-'01) How should I begin to modify the RS with $500? jImp Impreza Forum 22 08-08-2001 09:31 AM
