Old 02-23-2006, 06:44 PM   #1
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Default 06 WRX Injectors Flow Tested to 560cc
06 WRX injector was flow tested by RC to 560cc at 43.5 PSI.
Just for reference, STi pinks do 525cc at RC.
I'll scan the sheet in tomorrow as proof.
blinguskahn is offline   Reply With Quote
Old 02-23-2006, 06:59 PM   #2
JRSCCivic98
Member#: 67080
Edited for incorrect info, fed by the masses...
JRSCCivic98 is offline   Reply With Quote
Old 02-23-2006, 07:03 PM   #3
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
They are completely different. THe USDM STi injectors are SIDE FEED and the 06 USDM WRX are TOP FEED.
Old 02-23-2006, 07:05 PM   #4
JRSCCivic98
Member#: 67080
Last I had heard they were side feed as well.... humm, someone fibed on the info it apears.
Old 02-23-2006, 07:06 PM   #5
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
All you have to do is stick your head under the hood of an 06 WRX to see
Old 02-23-2006, 07:08 PM   #6
hondaeater69
Member#: 60324
different color too aren't they?
and that's the first i've heard of pinks flowing 525. . i know 525 is stamped on the box, but from all i have heard they actually flow ~560. . .
Old 02-23-2006, 07:08 PM   #7
5spdfrk
Member#: 46407
blew
Yeh, since everyone can do that. x2
5spdfrk is offline   Reply With Quote
Old 02-23-2006, 07:09 PM   #8
JRSCCivic98
Member#: 67080
Haven't had the oppertunity to do so as of yet... local Subie dealer decided to go belly up.
Old 02-23-2006, 07:12 PM   #9
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Well i mean that was the first thing I did when I saw the first one at the dealer. I was surprised because I expected to see side feeds as well. This and cobb's initial testing is what led me to really wonder what the injectors were.
I mean it didnt make much sense that they would go with the 02-05 WRX injectors since IMO they were too small to safely operate even stock power levels on the 06. Glad to know that 06 WRX owners have up to 20G swaps to look forward to without doing any injector upgrades!
Old 02-23-2006, 07:13 PM   #10
wrx13oy
Member#: 60529
2002 PSM Bugeye stg6
07 Kawasaki ZX6R
anyone wtt sti pinks for stock 06 injectors? haha
wrx13oy is offline   Reply With Quote
Old 02-23-2006, 07:14 PM   #11
JRSCCivic98
Member#: 67080
^^^ And the fact that it now apears we 2.0L owners have access to bigger injectors at maybe a cheaper or free pricetag. That's always good.
Old 02-23-2006, 07:20 PM   #12
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
I got a set of STi pink that you can have for 06 WRX injectors...
That is what you meant right
Old 02-23-2006, 08:29 PM   #13
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Now the question becomes whether 06 WRX injectors can fit an 00 rail with minimal mods, and whether you can get them cheaper than the STi pinks...
kgb is offline   Reply With Quote
Old 02-24-2006, 02:06 PM   #14
CALISTIYLIN
Member#: 106026
05 STi
Sell them to me!!!111one1!
CALISTIYLIN is offline   Reply With Quote
Old 02-24-2006, 03:04 PM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
20G
2.5L
560cc
No.
jblaine is offline   Reply With Quote
Old 02-24-2006, 03:05 PM   #16
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Alright guru... lets see how wrong you are.
Old 02-24-2006, 03:10 PM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
My 520s are at 100% with a small 16G and 2.0L @ 18psi and 11:1 AFR.
40cc is jack crap.
I'm sure it will be an excellent, reasonable, and well-tuned safe setup. Go for it.
Old 02-24-2006, 03:14 PM   #18
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Or is this where you, out of the blue, bring up information about intending to jack up the static fuel pressure? Water/meth/alky injection? Etc. Save it.
Old 02-24-2006, 03:15 PM   #19
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
Dude, what crawled up your ass and died? And yes, there are many mays to get around this including but not limited to statice FP, meth injection, less agressive tune.
Man this site is just full of fools. Where is the "Thanks Blingus for testing an injector". Bunch of self ritegous ignorant morons.
Old 02-24-2006, 03:16 PM   #20
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Sorry, pissy mood
Old 02-24-2006, 03:17 PM   #21
theicewall
Member#: 70532
2004 WRX
Whats involved in an injector upgrade in an 04 to the 06 top feds? Does it physically fit with just the injectors swapped or do things like fuel rails and connective pieces need to be swapped as well?
theicewall is offline   Reply With Quote
Old 02-24-2006, 03:39 PM   #22
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
In order to change the feed type, you must change the rails. After all, the injectors plug into the rails which is where the "feed" part comes into.
The specifics are covered here on NASIOC, just search.
TypeC is offline   Reply With Quote
Old 02-24-2006, 04:18 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
My comment was directed at only one thing - your suggestion that 560cc injectors, without "getting around limitations", would be fine for a 20G on a 2.5L engine. If you want to take that comment as a general overall attack on your efforts, that's on you. I saw a bogus suggestion and commented on it. Nobody should be expecting or buying 560cc injectors to be a proper solution for a 20G on a 2.5L engine.
Old 02-24-2006, 04:21 PM   #24
hondaeater69
Member#: 60324
or a 2.0l engine for that matter
Old 02-24-2006, 04:22 PM   #25
blinguskahn
Member#: 39301
STi 05 8cm FPRed
WRX 06 Blue FP20G
haha, watch.
06 WRX Injectors Flow Tested to 560cc with Sheet blinguskahn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 06-17-2008 11:18 PM
FS: 4 sets of Modded WRX Injectors-Flow tested and cleaned with flow sheet ScoobyNubieToo! Engine/Power/Exhaust 22 05-19-2008 10:11 PM
06 modded stock injectors flow tested to 820 ryanviola Engine/Power/Exhaust 17 12-02-2007 11:58 AM
06 WRX injectors flow tested at RC at 560cc blinguskahn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 03-09-2006 07:53 PM
Gauging Interest: Modded WRX Injectors, flow-tested at 845cc kennyvb Private 'For Sale' Classifieds 7 06-09-2005 04:16 PM
