Old 02-23-2006, 10:00 PM   #1
plus plus plus
Member#: 102013
Default help on 850cc injectors and utec
Mods: 2002 wrx
fmic
20g turbo
lightweight pulleys
headers straight exhaust
2.5" upipe
3'"downpipe
ppg gearset
850cc injectors
255 pump
etc.
I have left all the parameters at default settings except adjusted to 850cc fo injectors......Should I run car in stock switch 0 setting for the ecu to learn...even though the car runs rough appearing to run very rich........what to do?
where to start? Any suggestion would be appreciated
Damn, I need a tuner that knows more than me in my area of OK..TX..KS
plus plus plus is offline   Reply With Quote
Old 02-23-2006, 10:42 PM   #2
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Originally Posted by +++
2002 wrx
I would probably rescale the injectors down a bit - say 650 ish and begin there instead of 850. I have the PE800's and when scaled at 800 - the car will run like total poop. Also, check wrxhackers.com for a starting point map (at your own risk) and then carefully drive yourself to a tuner. Just my opinion.
kingtut12 is offline   Reply With Quote
Old 02-23-2006, 10:45 PM   #3
plus plus plus
Member#: 102013
Man, I know what you mean by total poop...will scale back....
Old 02-23-2006, 10:47 PM   #4
plus plus plus
Member#: 102013
I am having a hard time finding knowledgable folks in this area...driving me nuts.....I will travel and trailor to get pointed in the right direction...any suggestions....
Old 02-23-2006, 11:03 PM   #5
plus plus plus
Member#: 102013
Can you run stock mode w/ these mods?
Old 02-24-2006, 12:10 AM   #6
duc748s
Member#: 44050
Lead paint chips....
.....delicious but deadly
If the injectors are PE I would start near the stock settings and work up from there. That being said, the PE's are a dual stage injector that flow like stock at idle and low IDC's but flow more as IDC's increase.
YMMV
ShaneV
duc748s is offline   Reply With Quote
Old 02-24-2006, 04:10 PM   #7
entropy138
Member#: 87446
2005 STI
3 second start club
With my 850s I started at 800 and worked up by watching my fuel trims with an ODBII scanner... . The car ended up being fairly happy with them set to 860cc...
Also- when set to map 0 but the injector compensation scaled to 860cc my car ran PIG rich - way out of range for the fuel trims to correct. I'm not certian - but I made the assumption that map 0 - being stock ecu control - also meant injector compensation wasn't applied... In other words you're on the stock ecu entirely. But maybe someone can confirm / correct this...
That being said I was never really satisfied with the UTECs control of them. The scaling is great but it would have been REALLY nice to have dead time compensation as PEs have about double the response speed of stock/modified injectors...
entropy138 is offline   Reply With Quote
Old 02-24-2006, 08:25 PM   #8
RossWRX
Member#: 19808
2005 WRX STI
Obsidian Black Pearl
Really?
I'm trying to figure this out right now... the general agreement is that the dead time is identical to stock?
http://forums.nasioc.com/forums/show...t=scaling+dead
RossWRX is offline   Reply With Quote
Old 02-24-2006, 10:27 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
They say the PE top feeds are slow. The side feeds work ok with the UTEC.
Originally Posted by azscoobie
Only the Top feed 650/800's are 1.6 ms which is around twice as slow. If you use a Utec with PE Top feeds you will skip pulses. Meaning the Utec (or ECU) will say CLOSE and the injector is still open. On STI Side feeds the time is the same and there is no issue.
cdvma is offline   Reply With Quote
WTB: DW side feed 850cc injectors and aeromotive fuel rail Diabolus Private 'Wanted' Classifieds 1 11-17-2009 08:20 AM
Power Enterprise 850cc injectors and APS 3" inlet (zaksti) Engine/Power/Exhaust 23 05-08-2009 02:39 PM
2 Sets of 850cc injectors and STi heads medrad_man Engine/Power/Exhaust 18 03-26-2009 01:39 PM
VF39, 850cc injectors, and Walbro Pump subawrxtasy Engine/Power/Exhaust 25 09-07-2006 07:54 AM
